Old 02-26-2009, 01:20 PM   #1
Default R/C Glitches Heavily
Hi all,
For some reason, my car is glitching heavily. Basically, I cannot drive it b/c it glitches with throttle and steering. I changed the radio batteries and reset the ESC multiple times. What would cause this issue? bad transmitter? bad cyrstals? bad receiver? From experience, what is usually the cause of this issue b/c I don't really have spare equipment to test. I'm thinking about grabbing crystals from a friend..I don't want them to dismantle their car and borrow their remote and receiver though.
ddzc is offline   Reply With Quote
Old 02-26-2009, 02:20 PM   #2
flatspunout's Avatar
Location: Somewhere between raising hell and Amazing Grace
Trader Rating: 34 (100%+)
What motor, esc, transmitter, and receiver are you using?
flatspunout is offline   Reply With Quote
Old 02-26-2009, 02:41 PM   #3
There are so many things that could be causing that, more information is needed. You could have the wrong crystals, have cut the antenna on the reciever, have the reciever too close to the ESC, have the motor and battery wires too close to the antenna...any number of things.
Old 02-26-2009, 05:46 PM   #4
GTRtuned's Avatar
You can try moving your electronics around, rewiring, and separate any of the power wires from the antenna wire.
Walter Cosico
RC America/ X-ray/ Express Motorsports/ Hudy/ Team Boca Bearings
GTRtuned is offline   Reply With Quote
Old 02-26-2009, 06:13 PM   #5
sickjamminracer's Avatar
Trader Rating: 23 (100%+)
is your car shaft driven?? my buddy had this problem and it turns out his pack was rubbing the drive shaft and short circuting the battery and causing it to glitch
W.P.A.C crawlers
The Raceway
sickjamminracer is offline   Reply With Quote
Old 02-27-2009, 08:39 AM   #6
MIke Clark's Avatar
Interferrence can come from a multitude of places. How is your antenna mounted? close to any power cables? There are three items you never want to forget,
(1) Never overlap the antenna on itself. Shortens range
(2) Never run your antenna parrelle with power cables.
Capacitive coupling induces white noise.
(3) Always make sure you antenna base or holder is real
tight. plain old vibration.
If you are running a brushed setup you'll need to check your motor for the following problems
(1) Brushes arching on the motor comm.
(2) Motor capacitors broken or missing.
(3) wire connections to the motor. Bad connections will
make the motor pull highter current thus making more
(4) Check battery connections.
(5) Receiver location, how it is also mounted.
(6) Crystals are usually the last to create problems, unless
the cases are dented in or rusty looking.
Since I don't know your model Transmitter/Receiver you can at least check these items first.
What type system do you have? Give us some more decent info so we can help you out better.
From Hueytown, Alabama The home of
some of the best NASCAR racers ever!
Bobby, Donnie, Davey, Clifford Allison
Red Farmer & Neil Bonnett
MIke Clark is offline   Reply With Quote
SEO by vBSEO 3.5.0
