New Yokomo TC, the BD-5 >
Old 08-30-2009, 06:22 AM
  #961
kschu's Avatar
Trader Rating: 16 (100%+)
Originally Posted by JimmyMac
I'm in contact with Elwyn on this one. He's been giving me good support. Can't beat his service! So far it's okay. I like the bottom end, mid-range, and brakes a lot better than a Tekin. But I'm not sure on the top end like the turbo on a Tekin. I was getting out motored on the straight on our outdoor track. But that was on Stock II with 22.5, I switched to Stock III with 18.75 and that seemed to help. I'd like to try higher, but my motor temp was 180° on my Ballistic 17.5. I did get fastest lap for the main today. So I'm at a good range on it. I'll play with it some more. If you have any useful info, shoot me a PM on it. Thanks.
the Orca TC SPec is very famous here...it's have d Dynamic TIming which like a NOS power...it's beat SPX and Speed Passion in performance and also d price......
kschu is offline
Old 08-31-2009, 11:27 AM
  #962
Martin Hofer's Avatar
the new topdeck is harder to go with the much softer 5cell plate
Martin Hofer is offline
Old 09-02-2009, 12:52 AM
  #963
JimmyMac's Avatar
For those who do not keep track of the team driver blogs.... here are some new bits, with pics, from Yokomo. Many, many new parts!
http://akira01.dtiblog.com/
JimmyMac is offline
Old 09-02-2009, 01:17 AM
  #964
kschu's Avatar
thanks
kschu is offline
Old 09-02-2009, 02:04 AM
  #965
RAL
RAL's Avatar
Trader Rating: 67 (100%+)
Originally Posted by SIRCC
Hi guys, coming to you from the Eastcoast NYC.
Been searching for 2 YOKOMO banners to hang at my track, any info on who or where can I find them.
get back to me, thanks - keep it sideways
[email protected]
RAL is offline
Old 09-03-2009, 07:24 AM
  #966
ROBORAT's Avatar
anyone know what size the BD5 diff balls and thrust balls are? thinking of changing to ceramics but dont know the size.... also, would anyone know if yokomo sells ceramic balls? if they do a part number would be great!
by the way, i have to give props to Elwyn Lee of Hobby Haven! .... Elwyn, you're service is awesome! I can't believe how fast you ship the part out! Fantastic!!! Thank you! Thank you! Thanks you!
if anyon here needs help with yokomo stuff, Elwyn @ Hobby Haven is the MAN!!! he'll hook you up for sure!
ROBORAT is offline
Old 09-03-2009, 08:17 AM
  #967
altreyx's Avatar
about the diff balls is 2,4mm ( 3/32" ), for the thrust balls i have no idea
altreyx is offline
Old 09-03-2009, 12:39 PM
  #968
RC MARKET's Avatar
Yes good link !
some parts tomorrow arrive !
RC MARKET is offline
Old 09-03-2009, 03:20 PM
  #969
JimmyMac's Avatar
Robotrat, I would contact RCMarket for ceramic diff balls. Yokomo ones seem to be overpriced, and I think, not sure... but think Yokomo only had tungsten balls for the thrust. At least, that's what I have in my diffs. I need to pick up a complete set of ceramics for my aluminum diff.
JimmyMac is offline
Old 09-03-2009, 03:26 PM
  #970
JimmyMac's Avatar
Here are the ceramic diff balls. But I can't find the ceramic thrusts balls.
http://rcmarket.com.hk/product_info....roducts_id=656
JimmyMac is offline
Old 09-03-2009, 04:42 PM
  #971
JimmyMac's Avatar
Hey Martin, or whoever. Shock question for those running the black bladders and single o-ring setup.... Are you running foam inserts on top of the bladders or nothing? Thanks.
JimmyMac is offline
Old 09-03-2009, 05:12 PM
  #972
kschu's Avatar
im running this setup without the the foam insert and also 0 rebound....this make d car feel stick to the track....and this is on low traction track...
kschu is offline
Old 09-03-2009, 05:26 PM
  #973
JimmyMac's Avatar
I'm not running foam insert either. But I'm running some rebound. I think I might try no-rebound. I ran this way when I had a 416 and it felt good.
JimmyMac is offline
Old 09-03-2009, 05:27 PM
  #974
kschu's Avatar
if the layout is technical, i will run some rebound on it and put the foam insert on top...to gain better response...
kschu is offline
Old 09-03-2009, 05:30 PM
  #975
JimmyMac's Avatar
Yeah, that's what I do on a local parking lot track. But I do not run my BD5 on it. That's what I save my TA05 for. No worry about tearing it up.
JimmyMac is offline
