New Yokomo TC, the BD-5
#1876
Front wheel wear-ANTONI
Hi I have a problem, the car wears me out the front wheels, as I can fix that, I'm using your settings antoni, what is the problem of wear
#1877
Not too sure, as track condition, tyre etc all make a difference. Maybe the car is understeering and causeing excessive wear or the car has too much front grip. Experiment with a harder front oil, and/or maybe a softer spring
#1879
Hey Frank,
Yeah i was running it on the outer hole on the hub. I found the car carried better corner speed and had more mid-exit steering. Also the track had a lot of fast sweepers, and the long rear link really gave it good steering into and around them.
Hope this helps, if you have any more questions, let me know,
Ryan.
Ryan.
#1881
Hey Frank,
Ryan.
Ryan.
#1882
Thanks Ryan !
I will for sure give it a try this weekend.
Just was wondering, haven't seen anyone using this option before.
#1883
Hello
Is the BD5 shocks / dampers available as sets? If yes, can anyone let me know the part no.? I wanna have additional dampers for testing different degree of oil easier but I don't wanna buy them piece by piece
Thanks.
Thanks.
#1884
yokomo bd-5w
Hi I have a friend of the circuit that sells all its electrical equipment touring with a kit w Yokomo, here is the link of the sale, the Spanish-language greetings
http://cochesrc.com/foros/vendo-o-ca...-vt216449.html
#1885
Wheel desgate photos-Antoni and kschu
Here I put the pictures of the wheels and their desgate
* Front
*Rear
and the track is that you see in the video, someone tell me if it is technical
http://www.youtube.com/watch?v=wCHHyhX4xDE
*TRACK PHOTO
* Front
*Rear
*TRACK PHOTO
#1886
* Front
*Rear
*TRACK PHOTO
* Front
*Rear
*TRACK PHOTO
#1887
* Front
*Rear
*TRACK PHOTO
* Front
*Rear
*TRACK PHOTO
is it your car have too much roll?
#1888
I reckon two things:
the track is pretty low traction right?
wrong addative / tiretreatment /wrong tire
need more info on that though
#1889
Hello;
I ride a BD5 W and I have a doubt about the set-up.
What is the difference in behavior between long and short rear arms?? "
I understand that the shorts provide more grip,
Regards
Regards
#1890
@Martin
Is that picture shows he is using too soft tyres?
Or Does old inserts cause this ? (We re-use inserts)
Cheers
Cheers
