Old 11-17-2003, 08:48 PM   #1
xray racer's Avatar
Trader Rating: 22 (100%+)
Default Getting stock motors to go well, making winners!!!
hey everyone
i was wondering if someone could give me some tips on g etting these motors to go better, and the ideal gear ratios for them:
1: Trinity Monster Horsepower Pro
2: Matrix v10
3: P2K2
4: P2k- fantom tuned
if you could give me some tips on getting those motors to perform at their best please let me know
the tracks i race on are big and flowing and also tight and small
i have a major race meeting coming up at a small tight track with a really tight infield, so smaller track help would be more appropriate now, but i also need info for larger faster tracks
any help would be great
robbie lloyd
Robbie Lloyd
Yokomo * HobbyWing * Sanwa
xray racer is offline   Reply With Quote
Old 11-17-2003, 09:01 PM   #2
jrighter's Avatar
I assume you are running an EVO2 or a T1r. First off, get 128T Kimbrough spur and the 1.77 pully set. I would stick with the monster for most tracks.
Tight tracks= stick with a .95-1.02 rollout.
motor= run either red+/red- springs or Purple+/Red- (just depends on how much torque you want). Putnam green brush on negative with trailing edge trimmed, blue on postive with trailing edge trimmed. That should get you in the ballpark. With a P2k2 or P2k run a 769 on the postive (767 with a hole) and a trinity E brush on the negative. Don't take anything off the trailing edges of the brushes. Same spring combo but gear up 2-3 teeth on the pinion.
Large tracks= 1.08-1.16 rollout. Same brush combos on both but run a red postive spring and green negative spring regarless.
I'm sure you will get a million different opinions but these seem to work best for me. Good luck!
jrighter is offline   Reply With Quote
Old 11-18-2003, 07:05 AM   #3
Cole Trickle's Avatar
It might not be nessecary to mention, but remember cleaning, oiling and comm cut. If you got the tool, align the brush hood. That makes a huge difference, as far as I understand.
I believe the choise of motor, depends quite a lot on personal driving style - unless you're able to adapt to the proper motor for the track.
Schumacher Mi5 - Sanwa MT-4 / RX-462 / KO Propo PDS-2123 - Nosram 5600 X-treme Saddle Pack - LRP SPX Zero/X12 17,5 - Nosram Stealth Touch Evolution - MAAS SPS 9250
Cole Trickle is offline   Reply With Quote
Old 11-18-2003, 07:33 AM   #4
Fuzzy's Avatar
One more tip. After you cut the comm, run a ball point pen along the three cuts in the comm to smooth the edges. Before you put the arm back in the can, try reaming the bushings with a .125" reamer. Do it by hand, nice and easy. Use constant, light pressure while turning the reamer clockwise. It's amazing what a difference this makes.
Fuzzy is offline   Reply With Quote
Old 11-18-2003, 07:41 AM   #5
BigDogRacing's Avatar
R/C Tech Charter Subscriber
Send a message via MSN to BigDogRacing
If you are using a metric rollout and need to convert to inches to compare with what these guys are telling you, just multiply your metric rollout by .0394 and you will have the equivalent in inches.(25.25*.0394=.995) By the same token, if you want to convert the standard rollout to metric, simply divide the standard rollout by .0394. (1.02/.0394=25.88)
Hope this helps!!
BigDogRacing is offline   Reply With Quote
Making the switch from stock to something quicker. tc3team Electric On-Road 8 02-06-2008 04:31 AM
Trinity Co27 Monster Stock Pro Motors & Reedy Neo 2* BL Motors For Sale Leodis R/C Items: For Sale/Trade 17 05-11-2007 05:03 PM
Mod Motors, Stock Motors, Rubber Tires and a Novak Syns. Module Team Speedy R/C Items: For Sale/Trade 1 07-13-2006 06:28 PM
4 stock motors for trade 3 EXPRESS MOTORSPORTS,TEAM STOCK FANTOM speedemall R/C Items: For Sale/Trade 0 04-25-2006 05:14 PM
8 brand new trinity stock motors paradox blue endbell#2104 & new monster stock #2140 jason cheng R/C Items: For Sale/Trade 11 05-08-2003 05:33 PM
SEO by vBSEO 3.5.0
