Like Tree16Likes
Old 05-02-2016, 10:27 AM   #601
Originally Posted by RollingChicane2 View Post
Are you looking for blue or gunmetal? The gun metal ones are available in a few different placed I have found online.
the gun metal ones would be fine, I found some online but the price for 2 sets is about the same as what I paid for the whole carů.
Gurneyflap is offline   Reply With Quote
Old 05-10-2016, 12:26 AM   #602
A F201 with 3Racing chassis just arrived, it needs option rockers now, I'm still looking for them, thanks.
Old 05-10-2016, 08:10 AM   #603
Hey Gurney - you and I might be the only two people active on this thread any more, ha!
I still need BLUE rockers as well but have not had any luck finding them. As you noted, the gunmetal ones are still somewhat readily available but I'm still holding out for blue ones.
I have been able to find quite a bit of original and aftermarket parts for the F201 at various places throughout the world. Only problem is that I'm spending almost as much in shipping as I am parts since I can only get a part or two from the same online shop.
I will snap some pics of my car in the next few weeks and get them posted. I'm taking the approach of building the F201 as if it were a current production car. I'm having to fab quite a few parts to get it where I want it.
Are there any other parts other than rockers that you are needing?
I have wondered if the TA06 rockers could be made to fit? Looks like they are at 90░ rather than ~110░ so I'm not sure if that effects the geometry enough to cause an issue or not.
Nice to know there is someone else out there building one of these.
Awesomatix A800 x2, VBC D08 / D07, CRC WTF16 F1
National Points Member 201
RollingChicane2 is offline   Reply With Quote
Old 05-10-2016, 09:01 AM   #604
I thought the same about TA06 rockers but they seem to be too big, the bearing is the same but the TA06 rocker got 2 of them and look much more thick. I'd like to try the car in 2WD and see how it can compete against new F1 chassis on a carpet track, but first I need wheels that can fit the Pit or the other tires for F104 type chassis. Except the rockers I could find the needed parts, also need new bodies, Ferrari and Williams ones as I have Williams and Sauber spare decals, TBG bodies would be fine.
Except Tamiya wheels, which ones fit ?
Old 05-10-2016, 11:43 AM   #605
I'll read through the previous pages of this forum this week and see if I can find out about the wheels. I'm positive I have read somewhere what wheels are usable with the Pit tires. I'm pretty sure the Sakura FX wheels are an option but I will verify.
Are you going to run the stock type battery pack or are you converting everything over to a shorty?
How are you going to deal with gearing? (2.6 FDR)
I've had a few F1's over the years (2wd) and I'm not thinking the F201 will be overly compatable with them in 2wd mode but I could be wrong. I think weight and gearing will be stacked against you pretty heavily.
Regardless, the F201 is the coolest design I've seen yet and definitely worth the time to revive even if it won't be on the top of the podium.
I'm planning on setting mine up with a 17.5 and will run with a full body to protect the suspension. Our 17.5 class is small and fairly laid back so I'm going to try it out there for fun.
Old 05-10-2016, 12:31 PM   #606
I did a little bit of research and it looks like the original HPI 10 rims will work with the Pit tires. Ride also makes one set of wheels that will work on the F201 with the Pit tires as well as the Ride F1 tires.
http://rc-ride.co.jp/en/products/wheels/wheels-f1
Old 05-10-2016, 11:07 PM   #607
I still have a bunch of F201 parts left over from my web shop. Pretty sure I don't have the blue rockers but I might have the 3Racing ones. I think I have wheels too.
Apex RC
www.apexrc.com - Hawaii's #1 RC Proshop
Share & Like Our Page:https://www.facebook.com/ApexRCProshop
Win free stuff!
Old 05-11-2016, 12:28 AM   #608
I'm interested in the rockers and wheels, send you a PM
Old 05-11-2016, 12:40 AM   #609
yes, thanks, I saw the same. Gearing and weight are the low points of course but with the new light packs there's room for improvement, I even found packs which could sit beside the engine.
Old 05-11-2016, 04:33 AM   #610
Hi InspGadgt, other than the rockers and wheels, do you have a list of what all parts you have? I'd def be interested in a CF rear damper stay if you have one. Open to any other parts as well.
Old 05-16-2016, 07:03 AM   #611
How is your car coming along Gurney? I am probably 1-2 weeks away from getting mine ready to go. I have a few parts left to make and then I will take some pics and post them.
Old 05-16-2016, 07:21 AM   #612
Not before months for mine, I'm still waiting for InspGadgt answer for the rockers/wheels, I weighed the car with 3racing chassis, could be about 1150 Gr in 2WD.
Old 05-16-2016, 11:12 AM   #613
Have you seen the low profile shorty packs? They are 156g. I have one on the way.
I purchased some CF sheets and am working on a few parts. I am also working on getting 64P spurs to work. If everything works, i think I can easily get gearing in the 3.7 range.
Im still looking for the Blue rockers but I cant find them anywhere.
Old 05-16-2016, 11:57 AM   #614
I use LRP LCG shorty packs since last year, they are 170 Gr, I like the idea of shorty saddle, heavier but with a length of 57 mm you could put one beside the motor. There's a carbon chassis by TechRacing if you can find one, without upper deck.
Old 05-16-2016, 12:46 PM   #615
Here is a list of what I have done so far:
3Racing CF chassis conversion
CF Front Damper Stay
CF Rear Damper Stay
CF shorty Lipo thin battery brackets
CG front A-Arm brace
(I could not find these so I purchased a sheet of CF and made all of my own)
TB03 spur gear holder, modified to accept 64P spur gears
Blue shock bodies with true pistons
Aftermarket springs
Tamiya blue adjustable links in all locations
Blue servo saver
Low profile shorty battery
I still need the Blue Rocker arms and a small ESC to get it complete. I am also trying to find xceed wide rear foam tires but I can't find anyone who sells them. These are not critical to finish the project however.
Tamiya F201 scarymonster Northwest Racers 0 03-20-2007 08:14 PM
Tamiya F201 Tyler O. R/C Items: Wanted to Buy 9 10-30-2006 12:35 PM
FS: Tamiya F201 with Hop-ups! Denso R/C Items: For Sale/Trade 8 05-03-2005 07:16 PM
Tamiya 414m , Tamiya F201 for Sale Apexman R/C Items: For Sale/Trade 1 04-30-2005 10:45 AM
Tamiya F201 with Hop-ups rayhuang R/C Items: For Sale/Trade 29 02-01-2005 10:59 AM
