Old 02-22-2009, 01:27 PM   #1
xxblackheartxx2's Avatar
Default gearing for a 10.5 motor *help*
watz a good starting off point for a 10.5 motor for a large track????
thanks.
ROWDY RACING
www.scrccc.com
www.harrisrc.com.au "WORLDS BEST CELLS"
xxblackheartxx2 is offline   Reply With Quote
Old 02-22-2009, 01:29 PM   #2
a_main_attendee's Avatar
Location: Colorado, USA, The land of the free and the home of the brave!
For rubber tires start at around a 5.0 FDR. Go from there based on temp, performance, etc.
Support your local tracks!--|--e-teamhobbyplex.com--|--corrc.org--|
NNFaN Paints - Add some pride to YOUR ride.
a_main_attendee is offline   Reply With Quote
Old 02-22-2009, 06:23 PM   #3
decibels's Avatar
It's going to depend on your motor. i recommend starting at 5.2 fdr(38.4m roll out). this is good for something like a novak. and i generally run speed passion and i run up to as much as 4.6 fdr(43.4m roll out). but when running high gearing like that you need a good fan heatsink and i recommend running fan at 7.2 volt if the weather is hot. also you can adjust timing on the esc depending on what esc you have usually somewhere between half and 3/4 of what the esc can do usually works good! on my gt1.1 i run 18.75 degrees religously.
Team Wave Speedies
Thunder power lipo's
flying fox rc
!!And an idiot with a controller!!
decibels is offline   Reply With Quote
AARCMCC Online! Darkman Australian Racing 5392 08-16-2017 05:44 AM
The Coliseum at HobbyTown USA rbenjamin Racing Forum 16793 10-13-2012 02:33 PM
Team Tekin New Speedos Drew_Cat Radio and Electronics 1521 10-05-2012 11:35 PM
The J82 Thread AndyMoore Electric Off-Road 461 01-16-2012 12:27 PM
Associated Factory Team TC5, Brushless, LiPo, Li-ion Nanophosphate, Tips and Tricks John Stranahan Electric On-Road 839 11-01-2011 03:31 PM
Novak havoc and Novak gtb brushless system difference sszzxx Electric On-Road 17 12-27-2008 04:13 PM
New to electrics... AllThrtl Rookie Zone 6 06-22-2007 08:07 AM
