4 cells on a 6-7 esc only
This is very important. I use to run a super rooster on 4 cells for a bit but then something happened and it stopped working. i don't know if it's because it's not ment to br run on 4 cells or something else. Now i'm buying a new ESC to use in my 12l3 and was considering the novak fusion. I also says you should use 6-7 cells with it. Is the ESC going to get runined if I only use 4 cells? What's the worst that can happen? Does it really matter any way, it's not like i'm using to many cells then recommended. is the warrenty voided if i use 4 cells?
Re: 4 cells on a 6-7 esc only
Originally posted by 70mph pan car This is very important. I use to run a super rooster on 4 cells for a bit but then something happened and it stopped working. i don't know if it's because it's not ment to br run on 4 cells or something else. Now i'm buying a new ESC to use in my 12l3 and was considering the novak fusion. I also says you should use 6-7 cells with it. Is the ESC going to get runined if I only use 4 cells? What's the worst that can happen? Does it really matter any way, it's not like i'm using to many cells then recommended. is the warrenty voided if i use 4 cells? |
it should work!
running 4 cell is like running a little bit dischaged 6 cell pack |
It's not like running a little bit discharged 6cell pack, it's running at 4.8v instead of 7.2v, if your 6 cell pack reaches 4.8v when running it will be heavily discharged. Some speedo's are capable of running on 4.2v and they will usualy say so in the specs, others just won't work at all, so it's best to get one thats got the specs you need.
