Old 02-16-2009, 04:06 PM   #1
Smile Help epic 27 turn overheatin
i have a tc4 with a epic 27turn motor with 29t and its overheating is the gearing too high or something is wrong with the motor
blackmafia is offline   Reply With Quote
Old 02-16-2009, 08:24 PM   #2
katfish317's Avatar
Probably overgeared, brushed motors like that are only made to run at six minutes max.
What FDR are you using??
katfish317 is offline   Reply With Quote
Old 02-17-2009, 03:01 AM   #3
tc3team's Avatar
The pinion gear sounds a little high for most situations. Just from the info you have given, I would suggest dropping to a 25 or 26 tooth pinion if it's 48dp.
+1 on asking what your current car/gear ratio is, and where you race (or do you just bash?)
Info like that should help give a better answer
In any case, it sounds like your motor might need a skim (if you're not sure of the process, ask an experienced racer at the track and they can fill you in with how it's done) and possibly some new brushes too if it's been overheating, as they will change colour and loose their performance, slowing the motor down...
Fusion Hobbies / www.horshamrc.org
The wife stops me being sane and the r/c stops me from going insane....
tc3team is offline   Reply With Quote
SEO by vBSEO 3.5.0
