Tekin RS/RS PRO on 1s Lipo Q&A
#661
http://www.rcdynamics.co.uk/
Review written by me:
http://www.carsrcracing.co.uk/?p=183
I've yet to hear of one failing.
Trev
#662
Wanted to order the Epic Li-Fe 220mah receiver pack but they are out of stock. Where else can I get this pack or something similiar in the U.S.?
#663
My Novak booster worked for two heats after upgrading to version 203. A friend running oval also had problems running the booster in question. And there are multiple instances of other people having problems. I would recommend a LIFE receiver pack as it's almost the perfect voltage for the RX.
#666
you will never get 100% agreement. but I can tell you this. there is probably 100% that a rx pack will work with v203. the only thing you have to worry about with a rx pack is that the battery fails. generally you will find that out when you charge
#668
Neither. Use the booster here:
Trev
Trev
#669
Voltage would allow the cars to be faster than they are now. People are already saying that the slowest nationally recognized (U.S.) class is too fast for beginners. We are looking to draw in new racers, not keep them at bay.
#671
the slowest motor is a 21.5. last I heard that was as much wire they could put into the can. and I would bet with the torque the 21.5 generate with anything more then a 1cell (3.7) it will still be too fast.
#672
Moderator
I have a $4.00 HobbyCity booster (same thing as the TQcells...) that has worked great with my Tekin and Novak GTB before it for roughly 2 points series now (about 7 months of racing).
#673
Moderator
I have a novak smart boost that sucked right out of the gate. it would go into LiPo protection mode way easily with a 10.5T motor, and in general was heavy, and cumbersome. Just a pretty over the top design. Either that or mine is bad.
#674
Does anyone know if there's a US distributor importing the RC Dynamics booster? I might want to try one of those since the voltage output is a little higher, and I can't use a 2S LiPo receiver pack since my receiver won't handle the extra voltage w/o a regulator.
#675
I wanted to go with a RX pack but let a fellow racing friend talk me into buying a Smart Boost. Now that I am prepping to get a Tekin ESC for my car, the Boost will be useless and that is $30 more down the hole. That is a set of tires for my car I have to now look at in my pit box being unused.
