Tekin RS/RS PRO on 1s Lipo Q&A
#241
But, you can get 2C receiver packs down to 150 mAh and they work fine. You are running higher voltage than what most receivers and servo's are designed for unless you have a regulator. In the end it's easier to run a booster and about the same cost if you go with a cheap one.
I haven't had any balance issues with the booster or receiver packs because the car's a little under weight anyways. I just add a little where I need it.
Personally, I would recommend spending the money and getting the Novak booster. It's 6 volts and can easily handle the newer digital servo's.
#242
I think more and more people are running a booster instead of a receiver pack.
i'm running a Spektrum receiver, so i'm concerened about the voltage dropping issues. I have to double-check, but i think the Spektrum has its own internal regulator to handle the 7.4 input voltage (someone correct me if i'm wrong). Last, i want to leave the main battery alone so the motor can use all of that wonderfull 3.7volts .. that all us ROAR members have succumbed to.
#244
#246
You have mentioned this before about the Novak booster. Is the full 6 volts giving you a performance advantage over the TQ booster?
#247
Ran mine in GT10 today outdoors with 1s lipo.
Novak 10.5SS with 2mm of added timing?
On ESC;
Max Timing
Max turbo
Motor never got above 45degC (it never seems to change no matter what I do! )
After turbo had finished kicking in I was on par with most of the 4cell cars.
Skiddins
On ESC;
Max Timing
Max turbo
Skiddins
#248
Thanks Fred,
My LiPo receiver pack was worthless after a few months. I don't think they like the high draw of the new servo's (most are 10C). That was a couple of years ago though.
Oh, plus the whole Novak customer service thing. Maybe Tekin will release a simple booster...
#249
If I remember the receiver is fine with the higher voltage but they pass the receiver pack voltage directly to the speedo and servo. This is a little iffy with some speedos and servos. I'm too old and lazy to mess with charging a receiver pack any more. I'd rather switch it on and go.
You'll notice a little difference with the servo being faster and holding better in the high speed sweepers. It's a matter of preference as to what you like.
#250
#251
Has anyone had a problem with the Tekin RS Pro and the Novak Booster?
I was running yesterday and a couple of times I got what appeared to be a small glitch when under load, then in a later race, I lost it all for a second or so....just enough to crash at high speed and damage the car.
I didn't get this when running the LRP SPX.
Anyone have any ideas?
Skiddins
Skiddins
#252
I asked a while back and Randy said probably not as it would increase the footprint of the controller and increase manufacturing costs. The software already can do 1S and the the voltage cutoff can be set for 3.0V and up if you select custom in the slider. Soldering in the TQ booster was pretty painless, so I'm not complaining and ordered another SMC 1S and TQ booster combo from TQ.
#253
Skiddins
Skiddins
I think my esc receiver plug wires were a little tiny bit loose in the harness. I run with a TQ booster and leave my esc switch off. I think when I would enter a corner or get on power hard, the wire would create an open circuit turning the car off for a fraction of a second. Then it would reconnect, but the esc would have to go through its "recognizing" phase before you get control again. It was driving me nuts! I swapped out receivers, reset the VR on my radio, rebound the receivers, differerent lipo transmitter pack, reset the esc software, everything! I would be running well, go into a corner and then it would just pile drive into the boards. I'd pick it up once I got off the stand and everything was working perfect. I will be leaving my esc switch on now from now on and rewiring my esc receiver plugs to make sure I don't get this any more. Your mileage might vary!
#254
Skiddins
Skiddins
Ive run both the TQ and novak one without any problems. Make sure all your connections are solid.
