Old 11-08-2003, 03:42 AM   #1
Default Battery Charging Questions...>>>
I have a new (only charged 6 maybe 7 times) 3300 batt pack. In all previous charges, the pack would see upper 8 volt reading when completed. It has swung over 9, but for the most part has been in the 8.75 range.
The battery pack (and car) has sat for a week or 2. Now trying to charge that pack it will only get 8.08 - 8.10 volts. Also one of the center cells seems to be a little hotter (roughly 10-12 degrees on the Raytek) than the rest.
Could this one cell be bad already? I am a newby to electrics, and I just wanted some opinions of more experienced hobbists on this one.
My LHS will gladly check that pack and all that, it's just that I'd like to hear some thoughts prior to taking it in and having it checked.
Thanks in advance.
NitroJohnnyD is offline   Reply With Quote
Old 11-08-2003, 05:24 AM   #2
Super Steve's Avatar
Send a message via AIM to Super Steve
I guess the pack wasn't a matched pack?
I would suggest discharging the batteries on equalizing trays time to time.
Super Steve is offline   Reply With Quote
Old 11-08-2003, 06:05 AM   #3
danjoy25's Avatar
R/C Tech Charter Subscriber
Trader Rating: 37 (100%+)
Default batterys
Try to cycle the pack (discharge and charge) at least twice and hopefully it should charge properly.
Another thing I found was when i first assembled a pack, you need to use at least a 60 watts soldering iron as using anything lower will take to long and there is a chance of melting the seal in your cell.
danjoy25 is offline   Reply With Quote
Old 11-08-2003, 09:00 AM   #4
Send a message via AIM to Johnnytc3
Also try traying them to "equalize" them.
Johnnytc3 is offline   Reply With Quote
Lipo Charging Questions nickjames Radio and Electronics 3 02-03-2008 06:30 PM
Battery charging questions.. Sgrios Electric On-Road 4 09-25-2007 10:37 PM
battery questions v. charging and track procedures Blisster Rookie Zone 4 07-16-2007 03:00 PM
Battery and Charging questions Stevietd14 Rookie Zone 4 09-04-2005 05:26 AM
Battery Charging/ Discharging Questions quozl Australian Racing 7 03-01-2003 06:30 PM
SEO by vBSEO 3.5.0
