Old 02-06-2010, 04:55 AM   #1381
Callahan_88's Avatar
My wish list for the HPI Santa!
BMW e30 M3 Evo2
Opel Corsa OPC
Opel Astra OPC Estate
Opel Kadett Rally
Datsun 180 sss
Celica GT -75 (Top secret)
Honda CRX -90
Ford Escort MK1
Mazda MX3
Honda Civic VTI -00
AE86 Trueno/Levin Coupe (With a stage-d wide body kit)
Go big or go home! :)
Callahan_88 is offline   Reply With Quote
Old 02-06-2010, 06:28 AM   #1382
BIG DADDY8's Avatar
Trader Rating: 62 (100%+)
Send a message via AIM to BIG DADDY8
Originally Posted by BIG DADDY8 View Post
Just got the sway bar kit and need to know a good starting point for what color bars for the front and rear. Run on a medium bite outdoor asphalt preped track.
Anyone help out?
BIG DADDY8 is offline   Reply With Quote
Old 02-06-2010, 06:55 AM   #1383
Anyone help out?
Starting like a real race car: The more grip surface, more stiffnes you can use. If the car is too stiff but there isnīt enough grip it slides. If you have too much grip and the car is loose you can rollover. A good starting point is the lightest bar and donīt forget to balance front and rear to get under or oversteering according to you driving style.
conejo is offline   Reply With Quote
Old 02-06-2010, 06:59 AM   #1384
k_bojar's Avatar
Trader Rating: 30 (100%+)
Send a message via ICQ to k_bojar Send a message via AIM to k_bojar
Anyone help out?
if you don't mind waiting until Monday, I'll pull mine out of the shed and let you know what I have on mine - last time was on unprepped surface, but lots of grip
we got a 'little' bit of snow falling in Philadelphia today - something like 12-ish inches
Bodies By Bean | Team Belly
k_bojar is offline   Reply With Quote
Old 02-06-2010, 07:15 AM   #1385
BIG DADDY8's Avatar
Iv'e got tons of grip in the front just not so much in the rear. It's set up stock with the laydown front shocks. All i did was lay the rear shock down to the inner hole and had better results. Just trying to get a better feel in/out of the turns.
Old 02-06-2010, 08:04 AM   #1386
snoopyrc's Avatar
Need a Karman Ghia shell for the club racer. Release it in a kit with the Porsche wheels.
www.battlefieldraceway.com Racing videos at http://www.youtube.com/snoopyrc
snoopyrc is offline   Reply With Quote
Old 02-07-2010, 06:03 AM   #1387
Old 02-07-2010, 02:21 PM   #1388
1555Racing's Avatar
Default Ya gotta love So Cal after a soaking....
Jackie Robinson Center Pasadena (backdrop).
1555Racing is offline   Reply With Quote
Old 02-07-2010, 09:42 PM   #1389
Aparatchik's Avatar
Thumbs up
That 2002 Turbo body is a stunner!!
Aparatchik is offline   Reply With Quote
Old 02-08-2010, 05:49 AM   #1390
1555Racing's Avatar
Default agreed
thx
Old 02-08-2010, 06:18 AM   #1391
cyclone x's Avatar
how does the new HPI porshe body handle
Chase Chandler
Sponsors:HOTBODIES Express .The Track. Stevo Racing
Cars: VE8, F104 PRO, B4.1, HPI BLITZ, Losi SCTE
cyclone x is offline   Reply With Quote
Old 02-08-2010, 01:02 PM   #1392
LJH
The 2002 sure is pretty...just wish it had round tail lights . My first car was a '72 2002 with very friendly (ie. Rusty) fenders. Loved that car but boy did it teach me how to work on cars....Day two of ownership I blew up the differential, then the Tranny, head gaskets and who remembers what else. But boy was it fun with Stohl Headers, Webber 40DCOE's (?).
The Mini Lights look good but as mentioned a set Alpina's or maybe even the old ATS Classics would look great.
Well done...and keep the work up on the German cars, though I have always had a sweet spot in my heart for the Alfa GTA's...they are just so pretty.
Cheers,
Jim
LJH is offline   Reply With Quote
Old 02-08-2010, 01:48 PM   #1393
Hi guys,
Well, we had a clear weekend day here in norcal and thus I finally had the opportunity to have a run with my CR since I finished building it around xmas last year! I was out with a friend of mine who had a larger car with a 7.5 BL, but found that even though my 17.5 BL was down somewhat on power compared to him, my lighter weight and better handling allowed me to get the better of him on high bite asphalt. Definitely a sweet-running little car and a lot of fun!
I found some strange tire wear after returning to the workshop however; please see attached pics. This is after a run of perhaps 1.5 hours on the stock (non drift) tires included with the kit. We were running primarily in a CW direction and only had one left turn on our course, so the tires you see are the heavily loaded outsides. Insides are fine.
Is this normal to see a set of tires wear like this after only one run? I installed them as recommended with the foam inserts and glued them to the rims. Any clues on what the problem might be? I'd be pretty disappointed to see a set of tires like this after so little run time... Thanks for any thoughts,
ianc
ianc is offline   Reply With Quote
Old 02-08-2010, 02:23 PM   #1394
Pro10noob's Avatar
The tire wear is pretty normal these days with the non shaped and very soft inserts.
It gets even worse if you use non belted tires.
If you drive a Tamiya M03 with m grip,s grip or even the belted a slicks and you use the sponge inserts i distroy my tires within 6 to 8 runs of 8 minutes racing.
If (as i did) u use the hard shaped inserts and i mean very hard inserts the tired do much better and wear a lot more evenly.
Making them hard is using shaped inserts with on top of those a plane hard flat inserts that is a bit wider then the tire inside is.
You then get a perfect wear pattern and as i found out with the M03 a nice steady running car that has a lot of grip and good steering.
Hope this helps a bit for you.
cheers Roy
Originally Posted by ianc View Post
Hi guys,
ianc
l===/o\===l
[_]-###-[_] V-link proto type Pro10,JKMR P235-SE Pro10
P235-VL Pro10 comming soon
Sponsered by me,myself and i :)
Pro10noob is offline   Reply With Quote
Old 02-08-2010, 02:49 PM   #1395
Hmmm... Very interesting info. The foam inserts that came with the tire were indeed very soft. Where could harder inserts to fit these wheels and tires be purchase? What are they made of?
Thanks for the help,
ianc
Tamiya TRF415 JDM_DOHC_SiR Electric On-Road 21094 03-10-2016 11:02 AM
The Future of RC Racing (Your Opinions) rccarracer15 Nitro Off-Road 103 06-10-2011 09:25 PM
Bodies for sale, new, used & painted coastaltony R/C Items: For Sale/Trade 68 01-02-2007 03:45 PM
Belt Driven vs. Shaft Driven Allen Sondej Electric On-Road 69 11-05-2004 07:51 PM
