Old 12-21-2009, 10:50 AM   #1306
PaPeRo's Avatar
Originally Posted by k_bojar View Post
the 'weakest' part of the entire kit is the plastic drive cups that attach to the bevel gears in each diff - those at the first part to break on everyone's car...as far as
Are these what you're refering too?
http://www.rcmart.com/catalog/rc-rac...t-p-29499.html
PaPeRo is offline   Reply With Quote
Old 12-21-2009, 12:01 PM   #1307
k_bojar's Avatar
Trader Rating: 30 (100%+)
Send a message via ICQ to k_bojar Send a message via AIM to k_bojar
not those - the plastic ones that attach to the drive/center shaft
Bodies By Bean | Team Belly
k_bojar is offline   Reply With Quote
Old 12-21-2009, 12:59 PM   #1308
I am going to be bashing so I don't care about track performance.
fishymamba is offline   Reply With Quote
Old 12-23-2009, 11:16 PM   #1309
myst38's Avatar
Send a message via ICQ to myst38
Default What motor for Cup Racer
removed
myst38 is offline   Reply With Quote
Old 12-25-2009, 12:46 PM   #1310
hi guys just assembling my cup racer Datsun 510 any ideas on front shocks what works better stand up or lay down? tires as well any recommendations on tires for asphalt that will fit standard rims? thanks.
dsr1967 is offline   Reply With Quote
Old 01-01-2010, 09:15 AM   #1311
Enzok's Avatar
Trader Rating: 42 (100%+)
Default Datsun 510
I have the Datsun cup racer and I really like the retro look,but in my opinion the stock wheels looked like balloon tires of a previous era gone bad so I am using the Tamiya wheels and M grip tires which fit much nicer under the body lowering my chassis and giving the car much better handling. I'm using the stand up setup for the shocks,frt pink springs,70 wgt shockoil and in the rear 50wgt shockoil with the blue springs
Enzok is offline   Reply With Quote
Old 01-03-2010, 06:21 PM   #1312
RMI
RMI's Avatar
I'm running on carpet, so this setup may not be much help.
I'm running the 510 with the front shocks laid down. One hole front piston with 60wt oil and stock copper spring. Three hole piston in the rear with 30wt oil and stock gold spring. I glued the edge of the box stock front tires to give them a little slide before I heard from others that FX traction compound was the ticket. So leaving the CA on the fronts and compounding all four tires completely worked out very well for me this weekend. Going to be tinkering with oil, springs and sway bars next to take some roll out of the chassis, but it is holding it's own out there, just about a tenth off the fastest car for now, but the consistency in the feel of the car is keeping it in or close to the front.
RMI is offline   Reply With Quote
Old 01-04-2010, 12:56 PM   #1313
Devlin's Avatar
Question for the Cup Racer Experts-
We are starting a spec class with the Cup Racers and we need to sort out the tires- as I understand it, HPI's rims are special and if you want to use their rims, you'd obviously be stuck with the tire range that HPI offers currently. Otherwise, you run the Mini rims that Tamiya designed with aftermarket tires. Problem is- if you have the Porsche you'd have to run non-offset Mini rims with a hub spacer if you wanted aftermarket tires right? Has anyone had luck with the optional Soft HPI tire?
Thanks!
Devlin
Devlin is offline   Reply With Quote
Old 01-04-2010, 01:22 PM   #1314
PaPeRo's Avatar
Thanks!
I don't have a Cup Racer but I do use HPI MX60 Soft slicks on my M04 and they offer lots of grip on pavement.
Old 01-12-2010, 05:16 AM   #1315
Callahan_88's Avatar
My new drifter!
Go big or go home! :)
Callahan_88 is offline   Reply With Quote
Old 01-12-2010, 05:43 AM   #1316
Callahan, what color is that? Looks like a light blue pearl?
Nice.
Bodywerx_rc is offline   Reply With Quote
Old 01-12-2010, 06:09 AM   #1317
The color is the following in that order!
RC Car color white pearl
RC Car color light blue
RC Car color silver met
RC Car color Black
Old 01-12-2010, 03:16 PM   #1318
Hi there....
I'm new to this scale and waiting the arrival of my Cup Racer.
I have a few questions that hope you can help me.
I need to buy a motor+ESC combo and I am thinking go brushless ,
What would be a fast (but controlable) motor choice for the Cup...?
12T...? , 9T...?
What about HPI 5600kV Flux Brushless System...? how many turns is ...?
I have seen 1:10 TT-01s running 5.5T 6000kV but I dont know if that is excesive for this small 1:10 chassis....
Other question , are the Tamiya M-chassis rims compatible with the Cup Racer...? somebody told me they also have 12mm hex hubs....
Any other interesting part compatibility...?
Many thanks..
danieluki is offline   Reply With Quote
Old 01-12-2010, 05:29 PM   #1319
PaPeRo's Avatar
Originally Posted by Callahan_88 View Post
My new drifter!
Wow...just wow.
Old 01-12-2010, 05:37 PM   #1320
Now in the ride height!
Tamiya TRF415 JDM_DOHC_SiR Electric On-Road 21094 03-10-2016 11:02 AM
The Future of RC Racing (Your Opinions) rccarracer15 Nitro Off-Road 103 06-10-2011 09:25 PM
Bodies for sale, new, used & painted coastaltony R/C Items: For Sale/Trade 68 01-02-2007 03:45 PM
Belt Driven vs. Shaft Driven Allen Sondej Electric On-Road 69 11-05-2004 07:51 PM
