Old 09-28-2009, 06:31 PM   #1141
BIG DADDY8's Avatar
Trader Rating: 62 (100%+)
Send a message via AIM to BIG DADDY8
Questions??
What's the performance/handling differance with the steering servo laying down or standing it up?
BIG DADDY8 is offline   Reply With Quote
Old 09-28-2009, 06:49 PM   #1142
komkit's Avatar
Send a message via ICQ to komkit Send a message via AIM to komkit Send a message via Yahoo to komkit
Originally Posted by cyclone x View Post
i think im still gunna try it and kit u dont even have a cup racer haha
Go take out all of your college found and we will bet on whether I have the CR or not.
Ok, will that be cash or check?
komkit is offline   Reply With Quote
Old 09-28-2009, 07:13 PM   #1143
litsluv's Avatar
Fed up with the ABC? I see Steve "O" has taken care of is driver with a brand spankin' new CR. Looks like the one from the 301 Challenge, LOL.
Kit, I believe Andy at one time posted on here that the Pro4 is a direct fit. Probably back a few pages. You could just pm him and ask, he'll tell you for sure.
USN Retired and sponsored by me. Remember the troops still serving!!
litsluv is offline   Reply With Quote
Old 09-29-2009, 03:00 AM   #1144
komkit's Avatar
Will try to put the thing together after the NATS. I ordered few more upgrades. Probably end up taking the diff from my Cyber 10 kit.
Still have ABC, I will get it to work. I went back to Mimi Sunday messed with ABC car for a bit and found out the diff screws were broken both front and rear. Will mod the diff halves and gotta use the bigger screws.
Old 09-29-2009, 07:23 AM   #1145
litsluv's Avatar
Hey they could be a problem
Old 09-29-2009, 08:16 AM   #1146
bvalistic's Avatar
Trader Rating: 31 (100%+)
Default diff
here's the diff that we are using in our car...it is so so smooth
Originally Posted by andyh View Post
Here are the part numbers for the Hot Bodies D4 WCE Diff
Currently there is not a complete set with a single part number
Also the diff below is made for the D4 WCE Offroad Race Buggy so a tad overkill for the Cup Racer. Although you will most likely never break a diff screw since it has the oversized diff screw and metal diff halves.
etc...
(working on more Cup Racer specific parts )
In the meantime for the ultimate super CR diff:
#61538 DIFFERENTIAL SCREW/HEAVY-DUTY NUT SET (2.6mm)
#61148 DIFF THRUST WASHER 2.8x5.8x1mm (2pcs)
#61149 DIFFERENTIAL THRUST BALL 1/16"
#B130 BALL BEARING 10x15x4mm (RUBBER SHIELD/2pcs)
#Z892 WASHER 10x12x0.2mm (10pcs)
#Z891 WASHER 10x12x0.1mm (COPPER/10pcs)
#61450 DIFFERENTIAL CUP JOINT SET
#A164 DIFFERENTIAL RING (13x19mm) (2 pcs)
#61433 BEVEL GEAR SET (39T/16T)
#A157 CARBIDE DIFFERENTIAL BALLS (3/32 ) 2.4mm (12 pcs)
#A165 SPRING 6x7x1.5mm (DIFFERENTIAL) BLACK (2 pcs)
Thanks,
AH
bvalistic is offline   Reply With Quote
Old 09-29-2009, 08:23 AM   #1147
bvalistic's Avatar
Default spool
here's the cup with pro 4 spool...just file the opening for dog bone pin and don't forget to use anti wear grease ...and we are also using hpi shocks
Old 09-29-2009, 10:27 PM   #1148
Callahan_88's Avatar
Go big or go home! :)
Callahan_88 is offline   Reply With Quote
Old 09-30-2009, 01:37 AM   #1149
itchy b's Avatar
Bodies look great Callahan!
Isnt the paint coats you sprayed on a bit thin though??
Cant quite make out the colour choice!!!
-Blitz-Rallyhawk-EX 1.5R-Xpress-P64 Tyrrell-Lotus79-Espirit VTA
EX1.5-SC10 4x4
itchy b is offline   Reply With Quote
Old 09-30-2009, 03:45 AM   #1150
Love the rims on that. Those are sedan ones correct?
Andy, can you tell me if the Switch bodies & rims will be coming to the US / Canada
I really like the new Alfa
Bodywerx_rc is offline   Reply With Quote
Old 09-30-2009, 04:16 AM   #1151
k_bojar's Avatar
Trader Rating: 30 (100%+)
Send a message via ICQ to k_bojar Send a message via AIM to k_bojar
+1
Bodies By Bean | Team Belly
k_bojar is offline   Reply With Quote
Old 09-30-2009, 05:40 AM   #1152
MikeXray's Avatar
Trader Rating: 73 (100%+)
Is that porsche from the tamtech 1/12th kit?
Mike L. Awesomatixusa.com | TQWire.com | Islandraceway.com |JacksonRCracing.com | Horsham RC | Sweepracingusa.com
MikeXray is offline   Reply With Quote
Old 09-30-2009, 10:33 AM   #1153
Raman's Avatar
Trader Rating: 56 (100%+)
ALFA!!!!!! Oh its the Mito.. also an Fiat 500 Abarth.. bodies don't look as impressive as the cup racers..
Raman is offline   Reply With Quote
Old 09-30-2009, 10:36 AM   #1154
Raman's Avatar
You're right.. That is the tamtech Porsche, I think rims as well..
Old 09-30-2009, 10:45 AM   #1155
Manny's Avatar
It looks like the HPI RSR. My buddy tried the 1/12 tamiya 934 body on a mini chassis and it doesn't fit.
Manny is offline   Reply With Quote
Tamiya TRF415 JDM_DOHC_SiR Electric On-Road 21094 03-10-2016 11:02 AM
The Future of RC Racing (Your Opinions) rccarracer15 Nitro Off-Road 103 06-10-2011 09:25 PM
Bodies for sale, new, used & painted coastaltony R/C Items: For Sale/Trade 68 01-02-2007 03:45 PM
Belt Driven vs. Shaft Driven Allen Sondej Electric On-Road 69 11-05-2004 07:51 PM
