Old 09-21-2009, 03:43 AM   #1111
Callahan_88,
What paint is that? Looks nice.
Bodywerx_rc is offline   Reply With Quote
Old 09-21-2009, 09:35 AM   #1112
Callahan_88's Avatar
http://www.kyoshobutiken.com/car-col...html?cPath=195
Backed with this!
Then this!
Go big or go home! :)
Callahan_88 is offline   Reply With Quote
Old 09-21-2009, 10:45 AM   #1113
First post!
I have a 510 on the way! Should be here tomorow and I can't wait to start building! I've been drooling over the cup racer since it was announced and its finally time to get one.
Just want to say, there are some good looking rides on here, great job everyone!
I've read through almost this whole thread in anticipation of my project, taking notes on what to look out for and what to pay close attention to while building. Thanks to everyone for the tips and pointers!
Adale4130
adale4130 is offline   Reply With Quote
Old 09-21-2009, 11:53 AM   #1114
Raman's Avatar
Trader Rating: 50 (100%+)
I just sold my M04 and picked up the Cup Racer. Will use the 510 as the runner and when stored, will have the Tamiya Alfa Romeo GTA on it. I can't bring myself to run the Alfa body.. I wish Tamiya would stop being lame and put the body kit back into production.. they sell the kit but not the body..
My next bodies will be the ABC Hobby Celica 1600 and HPI Porsche 911 RSR.
I hope HPI starts making to some vintage Italian race bodies like Alfa 1750 GTAM with fender flares, Lancia Fulvia, Fiat Abarth 600, and how about a Ferrari GTO swb! Nice
Raman is offline   Reply With Quote
Old 09-21-2009, 05:59 PM   #1115
Old 09-21-2009, 06:24 PM   #1116
k_bojar's Avatar
Trader Rating: 30 (100%+)
Send a message via ICQ to k_bojar Send a message via AIM to k_bojar
Originally Posted by andyh View Post
Here are the part numbers for the Hot Bodies D4 WCE Diff
Currently there is not a complete set with a single part number
Also the diff below is made for the D4 WCE Offroad Race Buggy so a tad overkill for the Cup Racer. Although you will most likely never break a diff screw since it has the oversized diff screw and metal diff halves.
etc...
(working on more Cup Racer specific parts )
In the meantime for the ultimate super CR diff:
#61538 DIFFERENTIAL SCREW/HEAVY-DUTY NUT SET (2.6mm)
#61148 DIFF THRUST WASHER 2.8x5.8x1mm (2pcs)
#61149 DIFFERENTIAL THRUST BALL 1/16"
#B130 BALL BEARING 10x15x4mm (RUBBER SHIELD/2pcs)
#Z892 WASHER 10x12x0.2mm (10pcs)
#Z891 WASHER 10x12x0.1mm (COPPER/10pcs)
#61450 DIFFERENTIAL CUP JOINT SET
#A164 DIFFERENTIAL RING (13x19mm) (2 pcs)
#61433 BEVEL GEAR SET (39T/16T)
#A157 CARBIDE DIFFERENTIAL BALLS (3/32 ) 2.4mm (12 pcs)
#A165 SPRING 6x7x1.5mm (DIFFERENTIAL) BLACK (2 pcs)
Thanks,
AH
Hey andy - i'm assuming this diff will fit in the front and rear??
Any option to the front drive shaft cup/holder? the plastic 'nipples' and the metal 'nipples' don't always like playing together nice and the plastic ones break...
the is the plastic piece that hold the drive shaft and connect to the front diff bevel gear
a metal one like the one in the rear would be nice - or else a composite bevel gear that would work in the car
Bodies By Bean | Team Belly
k_bojar is offline   Reply With Quote
Old 09-22-2009, 12:32 AM   #1117
let's not forget the bmw 2002. that would be a sweet shell.
khj94704 is offline   Reply With Quote
Old 09-22-2009, 06:08 AM   #1118
Callahan_88,
How do you like the Carbon goodies?
Do you notice a difference running all the CF plates?
I have the brakes coming in today I think, and a spare 240Z body
Old 09-22-2009, 07:23 AM   #1119
itchy b's Avatar
Got a question on the hpi bodies.
What wheel base do these cup racer bodies have?
Are they all the same, or do they vary in wheelbase length?
Cheers!
-Blitz-Rallyhawk-EX 1.5R-Xpress-P64 Tyrrell-Lotus79-Espirit VTA
EX1.5-SC10 4x4
itchy b is offline   Reply With Quote
Old 09-22-2009, 07:49 AM   #1120
litsluv's Avatar
Cheers!
So far the bodies are all 225mm, but the car itself can be either 210 or 225mm. We are running the ABC bodies on ours and they are all 210mm.
USN Retired and sponsored by me. Remember the troops still serving!!
litsluv is offline   Reply With Quote
Old 09-22-2009, 08:04 AM   #1121
andyh's Avatar
Default ...
Working on it...
andyh is offline   Reply With Quote
Old 09-22-2009, 09:02 AM   #1122
Originally Posted by Bodywerx_rc View Post
Callahan_88,
They are fine!
But i have orded the Exotek CRX chassie.
I have never tested the orginal chassie on the car.
Old 09-22-2009, 03:01 PM   #1123
Raman's Avatar
What's the purpose of the spacers underneath the gearbox?
Old 09-22-2009, 04:46 PM   #1124
Manny's Avatar
The spacers lower the bottom chassis plate when you use large diameter, 60mm tires. If you're using the smaller 55mm tires like the RP or HPI ones then leave the spacer off.
Hope this helps!
Manny is offline   Reply With Quote
Old 09-23-2009, 03:36 AM   #1125
I installed my brake kit last night.
WARNING
Anyone running any rims other than the HPI Cup Racer rims, you WILL have to grind down the spokes to clear the brake calipers.
A bit of work BUT they look awesome on the car!
Tamiya TRF415 JDM_DOHC_SiR Electric On-Road 21094 03-10-2016 11:02 AM
The Future of RC Racing (Your Opinions) rccarracer15 Nitro Off-Road 103 06-10-2011 09:25 PM
Bodies for sale, new, used & painted coastaltony R/C Items: For Sale/Trade 68 01-02-2007 03:45 PM
Belt Driven vs. Shaft Driven Allen Sondej Electric On-Road 69 11-05-2004 07:51 PM
