Old 08-26-2009, 10:29 AM   #1051
MikeR's Avatar
Trader Rating: 15 (100%+)
I'll put my Type X up against you guys any day! See you guys Saturday.
www.exotekracing.com ☆ASSOCIATED☆DURANGO☆HPI☆HB RACING☆KYOSHO☆LOSI/TLR☆SERPENT☆TAMIYA☆XRAY☆
A picture with your post, when trouble shooting, will probably get more rctech help than without...
MikeR is offline   Reply With Quote
Old 08-26-2009, 10:38 AM   #1052
bvalistic's Avatar
Trader Rating: 31 (100%+)
Default hpi
Mike, no matter what type it is, your still driving a cr ...we can just show some peolple that this car works ...see you saturday
bvalistic is offline   Reply With Quote
Old 08-26-2009, 03:06 PM   #1053
pauld's Avatar
Can I get the set-up for my "Type PD"?
pauld is offline   Reply With Quote
Old 08-26-2009, 03:58 PM   #1054
MikeR's Avatar
YUP YUP!
It's the "Dont mount the house transponder in your roof because every time my car gets near yours, your car falls over because the transponder weighs more than the battery" set up! Sorry Paulie
Old 08-27-2009, 07:28 AM   #1055
bvalistic's Avatar
Default nope
nah...just drive it
Old 08-27-2009, 07:29 AM   #1056
bvalistic's Avatar
Default reminder
Originally Posted by andyh View Post
Remind me to get you the "Type R" spec parts for Saturday
just reminding ...and please the cnc ones ...thanks
Old 08-27-2009, 07:40 AM   #1057
HarryN's Avatar
Send a message via AIM to HarryN
Does anyone know if there is a One-way or spool in development for the HPI Cup Racer?
Sorry to interrupt this chat lounge with a question.
Car(s): Team Losi 22 1/10 Buggy, Team Losi 22 1/10 Stadium Truck
Motors/Engines: SP 13.5 v1.0, SP 17.5 v3.0 x2, RevTech 7.5
Radio: Spektrum DX3R, DX3S
Cars For Sale: FG 08-530 EVO w/ Sport Brakes!
Track(s): http://www.rctrack.com
HarryN is offline   Reply With Quote
Old 08-27-2009, 08:35 AM   #1058
MikeR's Avatar
You could use the Pro4 spool if you just shim out the steel outdrives 1mm on each side. The PRo4 gear is a match for the CR
Old 08-28-2009, 06:46 AM   #1059
1555Racing's Avatar
Thumbs up with proper equipment
We need to have those guys order more They had some when I initially checked
Thanks Andy
1555Racing is offline   Reply With Quote
Old 08-29-2009, 02:01 PM   #1060
andyh's Avatar
Default ...
FYI on Pro 4 Spool mod.
Also the slots on the diff is a tad undersized to fit the Cup Racer dogbone pins (need to file off .2-.3 mm or so). After doing so, you should also use anti wear grease (since the surface is no longer anodized).
I'm trying to get some Pro D (drift chassis from HPI Japan) to see if they would be a direct fit.
Also FYI the Hot Bodies D4 ball diff set is a perfect fit upgrade/replacement for the Cup Racer ball diff.
We are continuing to develop option parts and upgrades for the Cup Racer...stay tuned
Thanks,
AH
andyh is offline   Reply With Quote
Old 08-29-2009, 05:39 PM   #1061
1555Racing's Avatar
Default Andy, could you be a little more specific w/ the part no.?
Thanks,
AH
Old 08-29-2009, 06:44 PM   #1062
Manny's Avatar
Default lighter diff gear?
Is there a lighter diff gear (plastic like the Pro4 gear) in the works? I've heard that the Pro4 gear works but it isn't supported by the center bearings as well as the stock metal diff gear.
Manny is offline   Reply With Quote
Old 08-30-2009, 01:10 AM   #1063
CSF0623's Avatar
I just installed it the Pro4 gear and front spool and it fits with minor grinding. Just grind on the inside of the spool where the dog bone sits and its good!
Carl F.
ACTIVRC.COM P1BRAND
CSF0623 is offline   Reply With Quote
Old 09-01-2009, 04:08 PM   #1064
andyh's Avatar
Default ...
Originally Posted by 1555Racing View Post
Here are the part numbers for the Hot Bodies D4 WCE Diff
Currently there is not a complete set with a single part number
Also the diff below is made for the D4 WCE Offroad Race Buggy so a tad overkill for the Cup Racer. Although you will most likely never break a diff screw since it has the oversized diff screw and metal diff halves.
etc...
(working on more Cup Racer specific parts )
In the meantime for the ultimate super CR diff:
#61538 DIFFERENTIAL SCREW/HEAVY-DUTY NUT SET (2.6mm)
#61148 DIFF THRUST WASHER 2.8x5.8x1mm (2pcs)
#61149 DIFFERENTIAL THRUST BALL 1/16"
#B130 BALL BEARING 10x15x4mm (RUBBER SHIELD/2pcs)
#Z892 WASHER 10x12x0.2mm (10pcs)
#Z891 WASHER 10x12x0.1mm (COPPER/10pcs)
#61450 DIFFERENTIAL CUP JOINT SET
#A164 DIFFERENTIAL RING (13x19mm) (2 pcs)
#61433 BEVEL GEAR SET (39T/16T)
#A157 CARBIDE DIFFERENTIAL BALLS (3/32 ) 2.4mm (12 pcs)
#A165 SPRING 6x7x1.5mm (DIFFERENTIAL) BLACK (2 pcs)
Thanks,
AH
Old 09-01-2009, 04:21 PM   #1065
MikeR's Avatar
A spacer is included w/ the PRO4 gear to fit the center bearings of the ball dif.
Tamiya TRF415 JDM_DOHC_SiR Electric On-Road 21094 03-10-2016 11:02 AM
The Future of RC Racing (Your Opinions) rccarracer15 Nitro Off-Road 103 06-10-2011 09:25 PM
Bodies for sale, new, used & painted coastaltony R/C Items: For Sale/Trade 68 01-02-2007 03:45 PM
Belt Driven vs. Shaft Driven Allen Sondej Electric On-Road 69 11-05-2004 07:51 PM
