Old 08-18-2009, 12:07 PM   #1021
1555Racing's Avatar
Default much appreciated.
Originally Posted by andyh View Post
http://www.ultimatehobbies.com
Orange County but...checked both part numbers and showed in stock
Andy, thank you.
It's a little ways from the Pasadena area, but worth the drive....
Regards,
1555Racing is offline   Reply With Quote
Old 08-18-2009, 03:55 PM   #1022
speedracer1129's Avatar
Trader Rating: 19 (100%+)
Originally Posted by k_bojar View Post
silly question - did you built the diff with the screw in the correct way?? If you build it with the diff screw in 'backwards', then it will loosen when it runs
Hmmmm...............I would like to say yes but I guess anything is possible!! I am assuming you are referring to the long main screw that holds the diff together correct??
I will have to check it out again......Good point!!
Want to know how to have better health tailored just for you?? Visit www.mygenewize.com/lchirino
speedracer1129 is offline   Reply With Quote
Old 08-18-2009, 05:24 PM   #1023
k_bojar's Avatar
Trader Rating: 30 (100%+)
Send a message via ICQ to k_bojar Send a message via AIM to k_bojar
that would be correct!
Bodies By Bean | Team Belly
k_bojar is offline   Reply With Quote
Old 08-18-2009, 09:22 PM   #1024
Shop Owner
rcmart's Avatar
Dear all cup racer fans,
Cup Racer parts have just arrived rcMart, check out the following list for any parts that you need.
100629 HPI (#100629) MX60 T-Drift (60×25mm) Tire For Cup Racer (2pcs)
100630 HPI (#100630) MX60 Slick Tire (60×26mm) for SWitch/Cup Racer (2pcs)
85267 HPI (#85267) CR Gear Box Set A For Cup Racer
85269 HPI (#85269) CR Diff. Outdrive Set For Cup Racer
85270 HPI (#85270) CR Hub Carrier Set For Cup Racer (2sets)
85271 HPI (#85271) CR Spur Gear Cover Set For Cup Racer
85274 HPI (#85274) Bumper Set For HPI Cup Racer
85277 HPI (#85277) Body Mounting Set For HPI Cup Racer For Cup Racer (2pcs)
85278 HPI (#85278) Servo / Shock Tower / Rocker Mount For Cup Racer
85279 HPI (#85279) Front Body Mount & Wheel Hub Set For Cup Racer
85280 HPI (#85280) CR Suspension Arm Set For Cup Racer (2sets)
85281 HPI (#85281) CR Steering Parts Set For Cup Racer
85282 HPI (#85282) CR Shock Parts Set For Cup Racer
85284 HPI (#85284) CR Gear Box Set B/Chassis Spacer For Cup Racer
85285 HPI (#85285) CR Axle Shaft For Cup Racer (4pcs)
86014 HPI (#86014) Gear Diff Bevel Gears 13 & 10T
86180 HPI (#86180) CR Diff. Shaft (9.8×24.7mm) (2pcs) For Cup Racer
86194 HPI (#86194) CR Spur Gear Hub For Cup Racer
86219 HPI (#86219) CR Spur Gear Hub Nut For Cup Racer
86220 HPI (#86220) CR King Pin Ball (4pcs) For Cup Racer
86262 HPI (#86262) CR Suspension Shaft For Cup Racer (2pcs)
86263 HPI (#86263) CR Steering Linkage Shaft (2pcs) For Cup Racer
86264 HPI (#86264) CR Sus. Shaft (3×29mm) (2pcs) For Cup Racer
86265 HPI (#86265) CR Sus. Shaft (3×44mm) (4pcs) For Cup Racer
86335 HPI (#86335) CR Steering Post for Cup Racer (2pcs)
86351 HPI (#86351) CR Step Screw For Cup Racer
86392 HPI (#86392) CR Diff. Screw (M2×32mm) (2pcs) For Cup Racer
86985 HPI (#86985) Wheel Washer for Switch/Cup Racer (4pcs)
86992 HPI (#86992) CR Sus. Mount B (38mm) (OR) For Cup Racer
86998 HPI (#86998) CR Bevel Gear (16T) For Cup Racer
86999 HPI (#86999) CR Bevel Gear 39T (Ball Diff.) For Cup Racer
87064 HPI (#87064) CR Diff. D-Cut Ring (13.8×21mm) (4pcs) For Cup Racer
87170 HPI (#87170) CR Rear Shock Tower (Woven Graphite/3mm) For Cup Racer
87274 HPI (#87274) CR Steering Plate A For Cup Racer
87315 HPI (#87315) CR Diff. Gear Case Set (39T) For Cup Racer
87318 HPI (#87318) CR Shock Spring Set (Soft) For Cup Racer
87320 HPI (#87320) CR Shock Spring Set (Hard) For Cup Racer
87591 HPI (#87591) CR Gear Diff. Adjust Spring Set For Cup Racer
87594 HPI (#87594) CR Servo Saver Set for Cup Racer
rcMart.com - We Help People Have Fun with RC
Fast worldwide delivery & low shipping rates
WebStore: www.rcMart.com
Blog: blog.rcmart.com
FB: www.facebook.com/rcmart
IG: www.instagram.com/rcmart2001
rcmart is offline   Reply With Quote
Old 08-19-2009, 04:57 AM   #1025
Coldn's Avatar
Send a message via MSN to Coldn
owww!!
this is a good reason to buy one...
Cyclone TC - Futaba 3PM Fasst
Speed Passio GT2.0 - MMM 10.5t
Nanotech 6000mah
Coldn is offline   Reply With Quote
Old 08-19-2009, 05:30 AM   #1026
Just got the newest RC DRIVER, and there is a 240Z in it. Any one from here?
Nice copper/orange color. Not a fan of the decals over the paint on the side.
But still NICE.
Here is a WIP of mine. This was a few weeks ago.
Bodywerx_rc is offline   Reply With Quote
Old 08-19-2009, 08:32 AM   #1027
Nope, everything was done as per instructions. I retightened it a few turns again and will test it out to see if it gets better or not....
Old 08-21-2009, 08:29 AM   #1028
redmike76's Avatar
Trader Rating: 36 (100%+)
Default Cup Racer gear question
Quick question for you Cup Racer guys. Does the Cup Racer use a regular 48P spur gear? The reason I ask is because I'm looking to see if anyone makes a 65T 48P spur gear, and my searches led me to the Cup Racer's spur.
I just need to know if it's the regular 48P (compatible with AE, etc) and if it has the standard mounting holes that a Kimbrough or Robinson spur gear would have.
Thanks guys.
redmike76 is offline   Reply With Quote
Old 08-21-2009, 08:54 AM   #1029
iPearl's Avatar
Trader Rating: 96 (100%+)
Send a message via AIM to iPearl Send a message via MSN to iPearl
yes they are this anoying loud Weeeeeee 48p lol.
Does any one know how i can get more suspension travel out of the Cup ?
Want to turn it into a rally LOL
Design Of Things !!!
iPearl is offline   Reply With Quote
Old 08-21-2009, 09:14 AM   #1030
Thanks guys.
All 48P is the same. The mounting holes between manufacturer may be different but I have personally never ran into not being able to mount a spur gear from brand x into car y yet.....
Old 08-21-2009, 09:15 AM   #1031
MikeR's Avatar
Trader Rating: 14 (100%+)
Thanks guys.
It is basically a regular Xenon spur gear in the CR.
www.exotekracing.com ☆ASSOCIATED☆DURANGO☆HPI☆HB RACING☆KYOSHO☆LOSI/TLR☆SERPENT☆TAMIYA☆XRAY☆
A picture with your post, when trouble shooting, will probably get more rctech help than without...
MikeR is offline   Reply With Quote
Old 08-21-2009, 09:15 AM   #1032
OK. tested it out last night and it ran much better!! I guess this diff likes to be torqued....
Old 08-21-2009, 09:27 AM   #1033
OSherman's Avatar
Questions?? Kit Specs
What is the difference between the Regular CupRacer kit and the Drift kit? Just body and Tires? I dont want to drift.. But i would like to have a CupRacer now.. Local Hobbystore has a Drift kit on the shelf, but i dont want to have to buy gobs of parts just to convert it for Asphalt Racing..
•KO Propo America
•EXOTEK
OSherman is offline   Reply With Quote
Old 08-21-2009, 09:30 AM   #1034
CSF0623's Avatar
Orlando, your correct on the differences with the kits. I have a drift kit I bought from a friend and just slapped on some rubber tires and a 210mm body and off to the track!
Carl F.
ACTIVRC.COM • P1BRAND
CSF0623 is offline   Reply With Quote
Old 08-21-2009, 09:37 AM   #1035
MikeR's Avatar
ORLANDO- Something to watch for is the stock racing tires a little funky and probably are more for show than go. Some good race slicks are in order. 60mm tires look best w/ the HPI Bodies. The ABC Hobby 55mm tires work pretty good but they look too small matched w/ an HPI body which is why most of us are running ABC Hobby type bodies
Tamiya TRF415 JDM_DOHC_SiR Electric On-Road 21094 03-10-2016 11:02 AM
The Future of RC Racing (Your Opinions) rccarracer15 Nitro Off-Road 103 06-10-2011 09:25 PM
Bodies for sale, new, used & painted coastaltony R/C Items: For Sale/Trade 68 01-02-2007 03:45 PM
Belt Driven vs. Shaft Driven Allen Sondej Electric On-Road 69 11-05-2004 07:51 PM
