Old 08-13-2009, 05:36 AM   #1006
Originally Posted by t0p_sh0tta View Post
Can anyone recommend a reasonably priced (<$80) brushed ESC to run a silver can or other "scale" motor (20+ turns)?
My only requirement is that it have an intergrated li-po cutoff. If I can't find one in this price range, I'll just go brushless.
Thanks,
Lamar
I have a black can Tamiya motor, Futaba 230 ESC with an ebay Lipo cut off and it all works great.
Bodywerx_rc is offline   Reply With Quote
Old 08-13-2009, 08:56 AM   #1007
Default Hop Ups
Hello,
I am about to build my cup car, and was curious about what upgrades that people feel are "necessary". I was looking at the following items.
Graphite Ft. & Rr shock towers
Graphite upper and lower chassis plates
Ball Differential
Sway Bars
Aluminum Shock Bodies
Aluminum Steering Turnbuckle
-Thanks for the input!
scubag08 is offline   Reply With Quote
Old 08-13-2009, 09:23 AM   #1008
CSF0623's Avatar
IMHO all you need is the sway bar kit and spring kit. I have both items and the turnbuckle for the steering which I bought for cosmetic reasons...lol. My car works fairly well without the other stuff.
Carl F.
ACTIVRC.COM P1BRAND
CSF0623 is offline   Reply With Quote
Old 08-13-2009, 01:47 PM   #1009
MikeR's Avatar
Trader Rating: 14 (100%+)
Originally Posted by scubag08 View Post
Hello,
Ball Differential
Sway Bars
I agree w/ Carl but what are your plans with your car? Street or race track?
www.exotekracing.com ☆ASSOCIATED☆DURANGO☆HPI☆HB RACING☆KYOSHO☆LOSI/TLR☆SERPENT☆TAMIYA☆XRAY☆
A picture with your post, when trouble shooting, will probably get more rctech help than without...
MikeR is offline   Reply With Quote
Old 08-13-2009, 02:29 PM   #1010
Thanks for the replies. I will be doing some parking lot racing, and hopefully some indoor racing as well.
Old 08-13-2009, 05:49 PM   #1011
Callahan_88's Avatar
I want an One way diff!
Go big or go home! :)
Callahan_88 is offline   Reply With Quote
Old 08-14-2009, 08:37 AM   #1012
t0p_sh0tta's Avatar
Trader Rating: 35 (100%+)
Default =(
So, I began assembly yesterday and the front diff situation sucks. I was joking and having a good time with friends, when I realized that the screws are too long for the case. Oh well, I've backed them out a bit, but the damage is already done. It looks like it'll work as is though.
The amount of play in the spur gear assemble is =/ too.
On another note, is the "optional" ball diff on HPI's website for the rear?
Thanks,
Lamar
t0p_sh0tta is offline   Reply With Quote
Old 08-14-2009, 03:43 PM   #1013
live2crawl's Avatar
Send a message via MSN to live2crawl
all ive done so far is...
steering turnbuckle
CF upper chassis
CF rear shock tower
CF steering plates
all for cosmetics, iam going to pick up the aluminum shocks, sway bars and hard springs soon.
i was running black can, but i find them crap. so i went with a reedy 17T
www.rccontario.ca
www.rc4wd.com
live2crawl is offline   Reply With Quote
Old 08-15-2009, 09:08 AM   #1014
Thanks,
Lamar
Lamar,
I had this happen to me, too. But then I realized that I had not installed the shock mount (lay down), which would have made the screws the correct length. The manual can be a tad confusing if you're not paying really close attention... Lose focus for a minute and you'll be swearing up a storm (atleast I did!). Did the rear portion of the screw boss bulge out? If so, just use a flat-bladed screw driver to push it back in.
I'm just glad that HPI included extra e-clips for the shock shafts. I lost 3 of them in the carpet!
VT
VectoredThrust is offline   Reply With Quote
Old 08-15-2009, 10:20 AM   #1015
t0p_sh0tta's Avatar
Originally Posted by VectoredThrust View Post
Lamar,
VT
Yes, the rear portion of the boss came into contact with the inner diff gear. I pushed it back in, and I assume that it'll be fine. Since I'm anal, I already went ahead and purchased a replacement diff housing, along with stiffer springs and sways (whenever they're back in stock).
Hmm, I'll have to look back over that, I'm using the traditional stand-up mounting system. FWIW, the diff housing that you use for the lay-down setup is different from the stand-up version. The part of the housing that the bearing slides in is longer for the lay-down style.
FWIW, the rest of the kit has been a pleasure to build. I've run into zero issues (besides searching for screws).
-Lamar
Old 08-17-2009, 07:56 AM   #1016
I had mine out yesterday for the first real run. Nice drive....
I went with the box stock setup. I found it looping alot on power, but I have to still tune it.
I ran it with
Tamiya black can motor
Futaba 230
Duratrax 3600
Mini rims and HPI radials
I removed the shims that are installed for the 60D tires. Make sure you cover the hole where the spur is. :-) I did not wreck the spur, but there is lots of little pebbles in there, and lots of marks and noise now. :-(
I found the car got VERY hot running that combo. I am going to cut out the grille on my Z to allow more air into the chassis.
I love the car, just have to look at tuning it more..
Old 08-17-2009, 12:58 PM   #1017
1555Racing's Avatar
Default So Cal APB!!
Does, anyone know of a store front retailer located in the LA Count or Riverside County area that has in stock Cup Racer tires (M or S) and rims? Obviously I could order them online, however, I'd like to pick some up en mass w/out shipping time and cost..
1555Racing is offline   Reply With Quote
Old 08-17-2009, 02:37 PM   #1018
speedracer1129's Avatar
Trader Rating: 19 (100%+)
Anyone having issues with the rear ball diff?? I set mine up pretty good, but when I run the car it slips heavily. I haven't broken it in yet but I didn't expect it to be that bad....
Want to know how to have better health tailored just for you?? Visit www.mygenewize.com/lchirino
speedracer1129 is offline   Reply With Quote
Old 08-18-2009, 04:10 AM   #1019
k_bojar's Avatar
Trader Rating: 30 (100%+)
Send a message via ICQ to k_bojar Send a message via AIM to k_bojar
silly question - did you built the diff with the screw in the correct way?? If you build it with the diff screw in 'backwards', then it will loosen when it runs
Bodies By Bean | Team Belly
k_bojar is offline   Reply With Quote
Old 08-18-2009, 07:47 AM   #1020
andyh's Avatar
Default ...
http://www.ultimatehobbies.com
Orange County but...checked both part numbers and showed in stock
andyh is offline   Reply With Quote
Tamiya TRF415 JDM_DOHC_SiR Electric On-Road 21094 03-10-2016 11:02 AM
The Future of RC Racing (Your Opinions) rccarracer15 Nitro Off-Road 103 06-10-2011 09:25 PM
Bodies for sale, new, used & painted coastaltony R/C Items: For Sale/Trade 68 01-02-2007 03:45 PM
Belt Driven vs. Shaft Driven Allen Sondej Electric On-Road 69 11-05-2004 07:51 PM
