Old 08-07-2009, 09:37 PM   #976
k_bojar's Avatar
Trader Rating: 30 (100%+)
Send a message via ICQ to k_bojar Send a message via AIM to k_bojar
mike - what hitec servo are you running?
Bodies By Bean | Team Belly
k_bojar is offline   Reply With Quote
Old 08-07-2009, 11:12 PM   #977
snoopyrc's Avatar
Mike -- Can you still use the lay down position of the front shocks with that chassis? Looks like you could but I havent seen it configured that way.
www.battlefieldraceway.com Racing videos at http://www.youtube.com/snoopyrc
snoopyrc is offline   Reply With Quote
Old 08-08-2009, 02:40 PM   #978
MikeR's Avatar
Trader Rating: 14 (100%+)
KB- Hitec HS-5245MG
Snoopy- Yes, lay down shocks are good to go still with the CRX.
My new ABC lid
www.exotekracing.com ☆ASSOCIATED☆DURANGO☆HPI☆HB RACING☆KYOSHO☆LOSI/TLR☆SERPENT☆TAMIYA☆XRAY☆
A picture with your post, when trouble shooting, will probably get more rctech help than without...
MikeR is offline   Reply With Quote
Old 08-08-2009, 04:55 PM   #979
speedracer1129's Avatar
Trader Rating: 19 (100%+)
Originally Posted by MikeR View Post
KB- Hitec HS-5245MG
My new ABC lid
Mike,
Where do you get your ABC lids from??
Want to know how to have better health tailored just for you?? Visit www.mygenewize.com/lchirino
speedracer1129 is offline   Reply With Quote
Old 08-08-2009, 10:14 PM   #980
k_bojar's Avatar
i didn't know ABC made a Miata body
Old 08-09-2009, 06:40 AM   #981
Default 2wd
has anyone tried removing the front or rear diff/driveshafts to make a 2wd machine?
just wondering as I always thought that drifters are normally rear drive and the cup racers a 4wd and has a drift version. Im not particurlarly interested in drifting but it popped into my head anyway.
6677 is offline   Reply With Quote
Old 08-09-2009, 03:55 PM   #982
Callahan_88's Avatar
I wonder what HPI has up there sleeve!
If there are 0 3 6mm offset rims out and then the different hex.
Must come som much wider bodis in the future!
My set up!
Novak XBR 13.5
Go big or go home! :)
Callahan_88 is offline   Reply With Quote
Old 08-09-2009, 09:45 PM   #983
BIG DADDY8's Avatar
Trader Rating: 62 (100%+)
Send a message via AIM to BIG DADDY8
Questions??
Needing to find some info on tires. Looking for a harder compound tire for the cup car. We run them on asphalt preped track. Like to find a rim and tire thats the same diameter(if there is one) as the one's that come on the car or close to it. The "m" compound is too soft and wearing out fast.
BIG DADDY8 is offline   Reply With Quote
Old 08-09-2009, 09:54 PM   #984
k_bojar's Avatar
unfortunately, the cup racer tire is an unique size...
Tamiya, HPI original Mini and ABC tires/rims are all 54mm - HPI made the cup racer 60mm why, I dunno probably more 'scale' then either a full-sized TC tire or the existing mini-tires...
is your place running strictly Cup Racers? if not, you probably have an advantage running your Cup Racer because of its bigger tires (you're roll out is higher with the CR tires then a standard mini tire - given the same gearing)
You might wanna check out 3Racing or Square - they might have someting...Did you try a drift tire for the hell of it?
Old 08-09-2009, 10:00 PM   #985
k_bojar's Avatar
MikeR - the CRX chassis is awesome !!!!!!!
Got it all together just need to re-attached the steering plates (changed to the "B" plates)
I'll try and grab a few pics of it tomorrow and post it
it will be getting an 'east coast' workout starting Friday
Old 08-09-2009, 10:06 PM   #986
BIG DADDY8's Avatar
the drift is too hard. The tires lasted 6 heats and there pretty much gonna now.
Old 08-10-2009, 05:45 AM   #987
Tamiya makes a 60D tire that is the same diameter as the cup tires. They fit on the standard mini rims, not the cup wheels.
Bodywerx_rc is offline   Reply With Quote
Old 08-10-2009, 06:39 AM   #988
[QUOTE=k_bojar;6183229]unfortunately, the cup racer tire is an unique size...
Tamiya, HPI original Mini and ABC tires/rims are all 54mm - HPI made the cup racer 60mm why, I dunno probably more 'scale' then either a full-sized TC tire or the existing mini-tires...QUOTE]
I just measured a brand new pair of Tamiya 60D radials PN# 50683 and they measure 58mm in dia. which should be perfect.
Old 08-10-2009, 09:04 AM   #989
andyh's Avatar
Default ...
Cup Racer tires/wheels are a different spec than the "regular" mini size to add to the scale realism of the car (ie. RC car tires/wheels for Mini and 1/10th scale sedans tends to make the cars looks like they have 18/19/20 rims with lo profile tires...)
You can use the "regular" mini wheels/tires with the Cup Racer (...just need to adjust the gearing accordingly)
andyh is offline   Reply With Quote
Old 08-10-2009, 02:26 PM   #990
BIG DADDY8's Avatar
does anyone have a good setup for asphalt yet?
Tamiya TRF415 JDM_DOHC_SiR Electric On-Road 21094 03-10-2016 12:02 PM
The Future of RC Racing (Your Opinions) rccarracer15 Nitro Off-Road 103 06-10-2011 10:25 PM
Bodies for sale, new, used & painted coastaltony R/C Items: For Sale/Trade 68 01-02-2007 04:45 PM
Belt Driven vs. Shaft Driven Allen Sondej Electric On-Road 69 11-05-2004 08:51 PM
