Old 08-04-2009, 07:53 PM   #961
k_bojar's Avatar
Trader Rating: 30 (100%+)
Send a message via ICQ to k_bojar Send a message via AIM to k_bojar
Originally Posted by speedracer1129 View Post
Funny you mention that. I have heard people complain about the same thing. I love the 510 body, but don't want to run it as I do not like the 2 piece body!! I went ahead and purchased a Tamiya Mini Cooper to run in the meantime and I went ahead and bought a set of Tamiya M chassis rims and tires just in case..... I found the overall diameter to be the same between the Tamiya and HPI tires so I think the problem with the stock 510 setup is the fact that the rear rims are 3mm offset. Grab yourself a pair of 0 offset for the rears and it should be fine!!
hpi probably should have packed in the 0mm offset rims instead of the +3 rims
Bodies By Bean | Team Belly
k_bojar is offline   Reply With Quote
Old 08-05-2009, 08:18 AM   #962
andyh's Avatar
andy,
I assume you are bring out the belted ones as well???
Also, will these fit the current Cup Racer rim selection or do we have to go to Tamiya wheels??
#4565 X-Pattern Radial Belted Mini Tire (B15-40)
#4560 X-Pattern Radial Mini Tire (B15-40)
Currently we have the #3630 Mini Star Wheels and we are in the process of trying to get some more of the OZ ish spoke/center dish mini wheels.
The Cup Racer wheels/tires are not compatible with the "standard" Mini tires/wheels
andyh is offline   Reply With Quote
Old 08-05-2009, 08:21 AM   #963
andyh's Avatar
...the +3 offset looks way better and you can run the car with them, just not recommended for "spirited" runs or competition. If we had included 0 offset wheels then we'd have 510 guys telling us the rear end looks weird ..
Old 08-05-2009, 11:35 AM   #964
I'm ganna go w/ the:
Novak EX Extreme Sport Brushless Motor (10.5T) $50.99
Castle Creations Sidewinder 1/10th Scale Sport Brushless ESC $76.99
I'll see how that works out
kriscros is offline   Reply With Quote
Old 08-05-2009, 06:38 PM   #965
k_bojar's Avatar
you won't the absolute performance outta that novak motor with the castle esc - unless I'm mistaken, that's a sensorless esc and the novak motor is a sensored motor (the 2 can be used together)...
why not look into a castle sensorless motor in a package combo? any reason why the novak over the castle? not that there is anything wrong with the novak motor - just asking because you might get a better deal getting a package from either company
Old 08-05-2009, 08:25 PM   #966
snoopyrc's Avatar
Yeah you would. The drifters are even less forgiving about the fender wheel gap than the bashers and racers.
www.battlefieldraceway.com Racing videos at http://www.youtube.com/snoopyrc
snoopyrc is offline   Reply With Quote
Old 08-05-2009, 11:52 PM   #967
CSF0623's Avatar
Thumbs up
HPI Honda Civic EK9 225mm body w/ ABC mesh wheels and tires.
I have to admit the car was a pain to put together but with patience the car will go together well. The CR is very competitive against the ABC Genetics mini here where I race in Socal. I almost gave up on the car to buy an ABC but gave it time and I am very happy with the results of the car. I have only broken one front hub carrier by brushing up against the wall and have been racing with it for almost 3 months. Hope my set-up will help others....Good luck fellow CR owners and have fun...I know I am!
Here is my set-up for WCRC high bite asphalt track.
Front
Gear diff w/ black spring installed
Gold springs w/ 40wt oil
Gold sway bar
Top upper position on shock tower (stock)
No Spacer under front gear case (using 54mm tires)
4.5mm of droop under front arm
4mm ride height
-2 degrees of front camber
-1 degrees of front toe
Rear
Black springs w/ 40 wt oil
Black sway bar
Middle hole on rear shock tower (Carbon fiber)
No spacer under gear case (using 54mm tires)
4mm droop under rear arm
4mm ride height
3 degrees of rear toe (stock)
-2 degrees of camber
225mm wheel base
Mabuchi silver can 540 motor
FDR 4.0
Novak GTX esc
Novak 2 cell lipo cutoff module
Airtronics 737 servo
Airtronics 2.4 receiver
Carl F.
ACTIVRC.COM P1BRAND
CSF0623 is offline   Reply With Quote
Old 08-06-2009, 09:22 PM   #968
live2crawl's Avatar
Send a message via MSN to live2crawl
civics looking good. i just dropped on my new 510 body.
www.rccontario.ca
www.rc4wd.com
live2crawl is offline   Reply With Quote
Old 08-07-2009, 04:16 AM   #969
So that is 2 CP's here in Ontario that I know of now. Any others down there in T.O. with them?
Bodywerx_rc is offline   Reply With Quote
Old 08-07-2009, 09:00 AM   #970
hey guys where do u all buy your spare parts from? ive broken a fair few things on my cup racer and cant get my hands on any spares in australia... My LHS have had my "parts on order" since i bought my cup racer 3 months ago...
Any help or links would be great guys thanks heaps..
kypreo is offline   Reply With Quote
Old 08-07-2009, 09:04 AM   #971
k_bojar's Avatar
i've got most of my parts from Stormer Hobbies...but not sure if they ship overseas
you could try ebay?
Old 08-07-2009, 11:47 AM   #972
pauld's Avatar
Thanks for the set-up Carl. I will try that on my 'spinning out' Civic.
pauld is offline   Reply With Quote
Old 08-07-2009, 12:39 PM   #973
MikeR's Avatar
Trader Rating: 15 (100%+)
Yes, Carl's car is sick! The old school RS4 Civic looks great
And I agree with you also. Really have to pay attention to all the little details in the CR but once finally finished the work will pay off.
www.exotekracing.com ☆ASSOCIATED☆DURANGO☆HPI☆HB RACING☆KYOSHO☆LOSI/TLR☆SERPENT☆TAMIYA☆XRAY☆
A picture with your post, when trouble shooting, will probably get more rctech help than without...
MikeR is offline   Reply With Quote
Old 08-07-2009, 02:40 PM   #974
CSF0623's Avatar
Thanks Paul and Mike! Hey Mike how bout you post up that bad@$$ Exotek CR with your current set-up!
Carl F.
ACTIVRC.COM P1BRAND
Old 08-07-2009, 06:13 PM   #975
MikeR's Avatar
Oh boy, ok, here we go. I'll try my best,
Front
HPI SHOCKS w/ 40wt oil HPI blue spring.
STOCK SHOCK MOUNT (stock)
No Spacer under front gear case (using 55mm tires)
ABC HOBBY TIRES
5mm ride height
0 degrees of front toe
Caster all the way back
2mm spacer under upper hinge block
Arms drooped
Rear
Ball diff w/ pro4 gear, tight.
HPI SHOCKS w/ 40wt oil TAMIYA RED spring.
Inner hole on rear shock tower (Carbon fiber)
No spacer under gear case (using 55mm tires)
ABC HOBBY TIRES
Rear arms level
5mm ride height
2.5 degrees of rear toe
CRX carbon chassis set
210mm wheel base
FDR 3.9
Orion 2400 pack
Tekin esc
Hitec mini servo
Spektrum 2.4 receiver
40mm fan
all weight moved forward
My Cup racer option spring set came in so I want to go back to the HPI Cup arcer shocks again soon. 1/10 springs on the car a little too firm- a little too much tire hop right now.
Here it is in action;
http://www.youtube.com/watch?v=Ze3eFieJD_Q
Tamiya TRF415 JDM_DOHC_SiR Electric On-Road 21094 03-10-2016 11:02 AM
The Future of RC Racing (Your Opinions) rccarracer15 Nitro Off-Road 103 06-10-2011 09:25 PM
Bodies for sale, new, used & painted coastaltony R/C Items: For Sale/Trade 68 01-02-2007 03:45 PM
Belt Driven vs. Shaft Driven Allen Sondej Electric On-Road 69 11-05-2004 07:51 PM
