Old 08-01-2009, 07:00 PM   #931
snoopyrc's Avatar
Originally Posted by kriscros View Post
would a Ezrun 9T Brushless motor 35A ESC For 1:10 from ebay work? or a castle creation mamba max 5700 brushless combo system work?
im looking for something thats affordable but quick
also need to know what teeth i should use on the motor
Well it would be fast!!! If you can keep from hitting anything. It will be a joy if you can keep from splattering it.
www.battlefieldraceway.com Racing videos at http://www.youtube.com/snoopyrc
snoopyrc is offline   Reply With Quote
Old 08-01-2009, 07:15 PM   #932
so what do you recommend?
kriscros is offline   Reply With Quote
Old 08-01-2009, 07:37 PM   #933
snoopyrc's Avatar
If you can handle it go ahead. I have no idea what your experience level is. What I do know is that I can take the slowest powertrain that is legal in VTA (in my opinion thats 4cells and 27t brushed). I can run that car at a car show or in a Walmart parking lot and people will say,"Wow thats fast." and I will respond,"No it isnt. Not really!" You are talking about way more power than that. The other thing is you might rip the drivetrain out of that little car putting that much power behind it, but I would wait for someone like andyh to comment on wether or not the car can handle it. But Im telling you its like trying to steer a bullet.
If you want it blisterfast I would go Lipo and maybe 10.5 or 13.5 brushless. Trust me it will rip across the parking lot. I wouldnt do anymore than that unless you dont want it to last very long. If you go lipo and 17.5 it will still be fast and it will seem more reasonable when you run it. Better battery life too.
Old 08-01-2009, 07:51 PM   #934
alright, so im thinking 17.5 sounds good. what companies do u recommend? i also need a esc w/ the motor i get. im looking to spend $100 on both
Old 08-01-2009, 07:54 PM   #935
Trader Rating: 30 (94%+)
Seriously good luck on finding a sensored ESC/ motor for under $100.
I'd reccomend Novak for a cheaper option, I run Tekin, but that is a bit more spendy .
Rocky8333 is offline   Reply With Quote
Old 08-01-2009, 08:06 PM   #936
snoopyrc's Avatar
Assuming this is what you are talking about.
http://www.hobbypartz.com/ezseselebrel.html
You know what? I have gone and looked at the combo you are talking about and it doesnt look half bad for a hundred bucks. But it wont be any good for racing if you ever decide to go that way. I do still think it will be crazy fast if it performs anything like it sounds, but you can get around that by gearing it slower. If the drive train holds up, and you dont plan on racing, I say go for it, because it does sound like a good deal.
Old 08-01-2009, 08:26 PM   #937
ty guys, im ganna go w/ the 10t and hopefully wont break stuff. mabey i should go w/ the 13t? idk, its not for racing so.....idk, just ganna basically ganna go in a straight line
what gear size should i use?
Old 08-01-2009, 08:56 PM   #938
BIG DADDY8's Avatar
Trader Rating: 62 (100%+)
Send a message via AIM to BIG DADDY8
Questions??
Were just ran are first cup class tonight and it was a blast. Run the silver can motor with orion 3200 20c lipos. The car ran and handled very well. Had to dial a lot of steering out. Have a couple questions:
1st..... What compound are the tires that come with the 510 kit, S or M? We run in an asphalt parking lot track (with a preped track) and the tires had alot of wear. Really would like to get a harder compound.
2nd.... What handling differance is it from laydown and using the stand up for the shocks? Were running the laydown set up now, the front is agressive. Moved the clips to the front to give it less caster and use 40w front and 35rear.
Some help would greatly appreciated.
BIG DADDY8 is offline   Reply With Quote
Old 08-01-2009, 09:00 PM   #939
k_bojar's Avatar
Trader Rating: 30 (100%+)
Send a message via ICQ to k_bojar Send a message via AIM to k_bojar
very cool about getting a class together - I'm hoping we can get something like that at my place
as far as the tires...the are the 'M' compound tires in the all the kits, except for the drift kit obiviously
from what i've found, currently HPI only has the M-compound and the S-compound for the cup racerrs only thing harder would be the drift tires
Bodies By Bean | Team Belly
k_bojar is offline   Reply With Quote
Old 08-01-2009, 09:48 PM   #940
1555Racing's Avatar
...and they're in limited supply. I am going to stock up on both when they become available.
1555Racing is offline   Reply With Quote
Old 08-01-2009, 10:05 PM   #941
what size lipos do u guys recommend w/ a brushless 10t motor?
w/ the cup racer
also where do u get the rc falken tires? has the logo on them(pictured on the drift cup car)
Old 08-02-2009, 05:25 AM   #942
k_bojar's Avatar
w/ the cup racer
I would say try whatever you can get within your price range...HOnestly, there isn't MUCH of a difference in lipo packs...The higher the mAh the longer (essentially) you'll be able to run between charges Just make sure you have an esc that has a lipo cut-off or else you'll damage the pack - and that would suck..
the 'falken' tires in the pics are nothing more then decals on the tires that came in the kit - worse case, they are HPI's Cup Racer drift tires with decals...
what are you planning on doing with your Cup Racer? Race it, drift it, or just bash around with it?
Old 08-02-2009, 06:44 AM   #943
cyclone x's Avatar
this car is awsome and handles real well and is actually really fast
Chase Chandler
Sponsors:HOTBODIES Express .The Track. Stevo Racing
Cars: VE8, F104 PRO, B4.1, HPI BLITZ, Losi SCTE
cyclone x is offline   Reply With Quote
Old 08-02-2009, 07:44 AM   #944
k_bojar's Avatar
what motor are you running in it?
Old 08-02-2009, 09:41 AM   #945
BIG DADDY8's Avatar
I noticed this form is linked to the HPI site. Does anyone from HPI know if they will be comming out with a harder compound tire for this car? It looks like a must on the asphalt. other than that this is a great car. That was a question by the drivers here in TX.
Tamiya TRF415 JDM_DOHC_SiR Electric On-Road 21094 03-10-2016 11:02 AM
The Future of RC Racing (Your Opinions) rccarracer15 Nitro Off-Road 103 06-10-2011 09:25 PM
Bodies for sale, new, used & painted coastaltony R/C Items: For Sale/Trade 68 01-02-2007 03:45 PM
Belt Driven vs. Shaft Driven Allen Sondej Electric On-Road 69 11-05-2004 07:51 PM
