Old 07-06-2009, 03:39 PM   #781
k_bojar's Avatar
Trader Rating: 30 (100%+)
Send a message via ICQ to k_bojar Send a message via AIM to k_bojar
Originally Posted by BIG DADDY8 View Post
How does the Tamiya RS540 Sport Tuned Motor 49/62 (black can) work in it?
It seems to have 4500+ RPMs than the silver can. Is it too much for it?
i don't think its a case of 'too much for the car' - its just that for some reason, M-Chassis racing uses the Tamiya Silver can motors
If you read in the ABC MSeries thread, that's what those guys are running...I guess the silver can makes everything 'about even' - even though there are some people that know how to 'work' a silver can motor unfortunately, I'm not one of them
If the HPI Challenges are saying 17.5/27t - then someone thinks they'll be able to handle the power, because I know a decent tuned 27t has WAY more RPMs then any tweaked silver can
Bodies By Bean | Team Belly
k_bojar is offline   Reply With Quote
Old 07-07-2009, 03:44 PM   #782
Hi, I got my Cup Racer kit on July 2nd. I took some pictures I thought other people might be interested in.
This is my first post on this board so I wasn't able to embed images, so I had to attach them:
cup-racer-kit.jpg - what is included in the kit
finished-levin-cup-racer.jpg - my finished Toyota Levin Cup Racer
My setup:
Airtronics MX-3FG FHSS-2 Transmitter w/ Receiver (new!)
Airtronics 94102 Servo (had laying around)
Futaba MC330CR ESC (had laying around)
Trinity P2PK Pro Motor (had laying around)
DuraTrax Piranha 2000mAh NiMH Batteries (new!)
I got this kit for parking lot drifting. I was looking at the HPI E10 Drift, but also really wanted to build another kit. When I found the Cup Racer, there wasn't any other option.
I still have yet to run it (besides tormenting my animals in the house), but from what I've read on this thread, I'm guessing my P2PK Pro motor is going to be too much for the car. I have the HPI X-30 motor on order.
I'm also super interested in getting some non-drift tires just to see how the car performs. Haven't been able to find those anywhere yet either.
I'm not too sure about my servo choice. At first I was thinking I wanted one of the low profile ones to do the vertical mounting position, but then I saw Hara's setup and if he does side mount, that's more than enough for me. :P
Any advice? I'd gladly take it.
Anyway, I really enjoyed building the kit and wanted to share with the others on this board...and also say "Hi."
Hi!
Donovan
HPI Cup Racer 1M-cup-racer-kit.jpg   HPI Cup Racer 1M-finished-levin-cup-racer.jpg
ms3boy is offline   Reply With Quote
Old 07-07-2009, 04:02 PM   #783
ive heard a few people talk pretty bad about this kit well i just got mine yesterday and i think its great. a few problems ive heard is with the small selection of gear ratios, i solved this by removing the gear cover and replacing the black plastic spacer under the diff ith 2mm aluminum spacers and now i can get good ratios even for some crazy brushless motors (ive got a 10.5 in it now) i also heard about problems with certain batteries i solved this by placing the small body mount(p/n 85277-17 over the battery cover mount and use an exsisting hole in the upper chassis for my one plu and did a little dremal work on the battery cover dosnt keep the battery super close to the shaft but it works good hope this helps some one.
jjhanson is offline   Reply With Quote
Old 07-07-2009, 06:26 PM   #784
speedracer1129's Avatar
Trader Rating: 19 (100%+)
Hey guys,
I need some advice.....
I have had my kit sitting for 3 days and I haven't even opened the shipping box!! Here is my situation. I really like the car and I have always wanted a "mini" to have as a play car. However, I do plan to run brushless and lipos as that is all I have.I would like to make this car a 50mph or so play car that can give me 20 minutes or so on a pack. For you guys that have ventured alittle with the brushless already......WILL IT HOLD UP???
I have read some mixed opinions and I do not see the light at the end of the tunnel..........
Your input is greatly appreciated and please hurry as the desperation to tear the box open is killing me!!!!!!!!!!!
Want to know how to have better health tailored just for you?? Visit www.mygenewize.com/lchirino
speedracer1129 is offline   Reply With Quote
Old 07-07-2009, 06:57 PM   #785
i have a 10.5 in my car right now with a lipo pack ran car for about 45min so far i started the car with a pretty low gear ratio and slow been raising it im running foams on the car right now. i have the 510 and the rear rims are 3mm offset and the tires rub the body so im going to get the 0 offset. with the foams its a little twichy hopfully the rubber will calm it down. when you build the kit beware of the smallest e clips you ever seen i lost a few to the crpet but it came with extras
Old 07-07-2009, 07:05 PM   #786
Are you running 1/10 foams or M0-3 foams?? Also, how many milliamps are you running??
Old 07-07-2009, 07:27 PM   #787
johnvigg's Avatar
Send a message via AIM to johnvigg Send a message via Yahoo to johnvigg
i built mine saturday night, ran it a bit sunday and a little more monday night. I havent gone through one 2s lipo battery and already need new tires and to replace the 85281 drive shaft piece. I built it using a Castle creations momba max 5700. I expected to upgrade what was going to break before i got it 100%
this is a replacement for my nitro rs4 mini, and love it.
it can handle this power with just a few upgrades i think.
I Bought the 510 kit and the 3mm rear wheels do seem to rub, they also rub on my civic hatch body.
the stock tires got very grippy when warm and covered the chassis in rubber dust on just this little use.
johnvigg is offline   Reply With Quote
Old 07-07-2009, 07:55 PM   #788
im running parma 1/10 foams trued down to the same size as the factory cup tires, as for the battery its a 3700 25c 3 racing pack. im running a 102/22 64 pitch gears right now motor still fairly cool after 10min of running so add some more gear to it to see what it will do.
Old 07-07-2009, 11:07 PM   #789
johnvigg's Avatar
Originally Posted by five&dime View Post
I am having trouble with my rear diff. It is binding for some reason. I followed the instructions precisely. When I turn it it spins free until about 3/4 of the way through the revolution. Then it binds. There doesn't seem to be any problems with the gears. As I start to tighten the screws that connect each half of the diff case, it gets worse.
i have the same issue, what did you do. I just ran mine to free it up. Hopefully that fixed it for me
Old 07-08-2009, 06:24 PM   #790
BIG DADDY8's Avatar
Trader Rating: 62 (100%+)
Send a message via AIM to BIG DADDY8
Questions??
I see all these hop-up parts from HR. Is any body making a hop up for the drive line piece (85281) SOON? Anybody know????????
BIG DADDY8 is offline   Reply With Quote
Old 07-09-2009, 06:48 AM   #791
1555Racing's Avatar
Default check entry 728 in this thread by tsais
www.tsais.com, may have more transmission parts available in a month or two.
1555Racing is offline   Reply With Quote
Old 07-09-2009, 10:50 AM   #792
tsais's Avatar
Hey 1555Racing, have you installed the motor mount yet?
tsais is offline   Reply With Quote
Old 07-09-2009, 11:27 AM   #793
tsais's Avatar
Default For RCTECH.net Cup Racer Owners Only!
The TSAIS Team wants to offer something to cheer you guys up during this slow economic situation, so we put aside 10 motor mount sets for RCTech.net Cup Racer owners at a discounted rate from 07/09 to 07/12 midnight CST.
Old 07-09-2009, 11:48 AM   #794
The kit looks great and all, but the car will oversteer on corner entry and exit. You have to drive it like a M04. This is with any motor faster than the silver can. Somehow, this car does not run like any of the 4wd chassis I've run before. Still waiting on the spring and sway bar sets, and hope they will fix this issue.
redbones is offline   Reply With Quote
Old 07-09-2009, 01:40 PM   #795
1555Racing's Avatar
Default this weekend
tsais, I'll work on it this weekend......... I'll post pics afterwards. Thx, again....
Tamiya TRF415 JDM_DOHC_SiR Electric On-Road 21094 03-10-2016 12:02 PM
The Future of RC Racing (Your Opinions) rccarracer15 Nitro Off-Road 103 06-10-2011 10:25 PM
Bodies for sale, new, used & painted coastaltony R/C Items: For Sale/Trade 68 01-02-2007 04:45 PM
Belt Driven vs. Shaft Driven Allen Sondej Electric On-Road 69 11-05-2004 08:51 PM
SEO by vBSEO 3.5.0
