Old 05-19-2009, 07:24 AM   #511
milenko_76's Avatar
Trader Rating: 32 (100%+)
Has anyone had problems with the laydown shocks? Im having big spin out problems. I have checked all the suspension to make sure it is free and not binding in any way. Im running the light spring in the front diff. The rear diff is slightly loose but not too loose. Running gold springs all around. 3° in the rear of the car. 1mm shim under the shock tower. Stock tires 13.5 novak using the stock gearing and a futaba 9452 servo. I have tried taking out the steering limiter screws. Im at a loss. Its set up the same as a friend of mines. the only differance is he is using upright shocks in the front of his car. This happens when the car is turning at more than 1/3 throttle.
milenko_76 is offline   Reply With Quote
Old 05-19-2009, 07:28 AM   #512
Super Moderator
charlie_b's Avatar
Send a message via AIM to charlie_b Send a message via MSN to charlie_b Send a message via Yahoo to charlie_b
It sounds like there isn't enough weight transfer to the rear wheels. Try adding 1-2mm droop in front and limiting the rear droop.
''Many of life's failures are people who did not realize how close they were to success when they gave up.''-- Thomas Alva Edison
CAL RACEWAY:CAL RACEWAY
GT10 SERIES:GT10 SERIES
CFX Paintworks:="https://www.facebook.com/CFXPaintworks?fref=ts
|HITEC|PARMA|PROTEKRC|SWEEP|IWATA|RPM|AMAIN|CREATE X/WICKED/AUTOAIR PAINTS|TEAMASSOCIATED|REEDY
charlie_b is offline   Reply With Quote
Old 05-19-2009, 10:45 AM   #513
DarthRacer's Avatar
I'm running that setup with completely stock setup settings and I'm not having any turning issues at all running on asphalt. It has not shown any tendency to want to spin out. The rear diff feels pretty loose, definitely more loose then I have ever set a 1/10 ST diff at.
On the suspension note, I have done as others have said and reamed out the suspension arm holes and checked other areas for binding during assembly and I have to say the suspension feel on this car is far better than any kit I have owned so far. It's super smooth.
DarthRacer is offline   Reply With Quote
Old 05-19-2009, 10:57 AM   #514
honestly, I don't know why hpi just didn't make the bevel gear assembly like the pro4. Seems like no one has spares or aftermarket for this yet. And I'm not paying $25 for a small plastic piece. This part is probably designed to be the breaking point instead of chewing through the gears like my TB03(even less likely that the gears are metal). Tamiya releases all the spare parts on the same day a kit is released. So why no LHS carries them??
I really like the car in all, but I guess I'll have to race my indestructible M03 for the championships.
redbones is offline   Reply With Quote
Old 05-19-2009, 02:07 PM   #515
fordmike65's Avatar
Trader Rating: 28 (97%+)
Originally Posted by andyh View Post
And yes we will be bringing back the Mini X-Patterns and "Mini" wheels!
SWEET!!!! I've been saving the X-patterns on my M01 for a rainy day! How soon will they be out??
fordmike65 is offline   Reply With Quote
Old 05-19-2009, 05:54 PM   #516
cyclone x's Avatar
does anybody know if there are going to race theese at any of the HPI Challange races
Chase Chandler
Sponsors:HOTBODIES Express .The Track. Stevo Racing
Cars: VE8, F104 PRO, B4.1, HPI BLITZ, Losi SCTE
cyclone x is offline   Reply With Quote
Old 05-19-2009, 06:13 PM   #517
ScionBox's Avatar
Thanks for convincing me to buy the new Tamiya M05 chassis when it comes out.
Judging by the numerous posts in this thread of people having to...
shim this, cut that, droop this, change that screw out, smooth out that bearing seat, use F201 springs, degrease the kit's bearings, swap out the thrust assembly with a spare Tamiya one and shaving off suspension arms, among other fixes too numerous to mention...
...the Cup Racer sounds like too much trouble.
ScionBox is offline   Reply With Quote
Old 05-19-2009, 06:57 PM   #518
don't get me wrong. The cup racer will give you better lap times. Perhaps I'm too anal with building having experienced xrays, TRF, etc. And I do almost as much work in my M03 as well. You can't compare the build quality between the two, but each has their advantage. Trying to see if I can make my TB03 stuff to fit... Oh, and degreasing the bearings, Tamiya is no exception.
Old 05-19-2009, 10:09 PM   #519
Chiefy 707's Avatar
I don't blame you. Reading this forum and hearing the complaints. You have to remember the Cup Racer is an all new car that's not based on anything so right now alot of us are trying to figure out what works and what doesn't.
I'm not going to lie, I really like the M05 too but I don't think it can fit the ABC Celica 1600GT body.
"It looks like a [insert car here]. It's just another [insert car here] clone!"
"Why did [insert manufacturer here] go with such a radical design? [insert manufacturer here] needs to stick with what works!" Shhhh, please.
HB/LRP/KO Propo/Protek/Associated/Tekno
Chiefy 707 is offline   Reply With Quote
Old 05-19-2009, 11:10 PM   #520
MikeR's Avatar
Trader Rating: 15 (100%+)
Yeah umm good luck with the MO5 as well
www.exotekracing.com ☆ASSOCIATED☆DURANGO☆HPI☆HB RACING☆KYOSHO☆LOSI/TLR☆SERPENT☆TAMIYA☆XRAY☆
A picture with your post, when trouble shooting, will probably get more rctech help than without...
MikeR is offline   Reply With Quote
Old 05-20-2009, 02:30 AM   #521
Frank McKinney's Avatar
Originally Posted by k_bojar View Post
do you think HPI will bring back said 'ye olde molded foams'??
I'd guess yes (but I don't know) after Andrew said the X-patterns and wheels will be re-released
<snip>
What, you haven't heard what TCS racers do to their cars? Like someone said above, this is an entirely new car so all the racers are experimenting with it and finding out all the little tips and tricks...and yes weak points. I'm sure I'll be going through the whole learning process when I start running mine!
Minimal signature to save screen space! Big sigs suX0r
Frank McKinney is offline   Reply With Quote
Old 05-20-2009, 03:55 AM   #522
k_bojar's Avatar
Trader Rating: 30 (100%+)
Send a message via ICQ to k_bojar Send a message via AIM to k_bojar
yes, they cup racers are listed on the 'official' classes for the Challenges...I know there will be about 1/2 dozen at Ray Murray's challenge in August - so if you got one, bring it out
Just don't know if its gonna be 27t/17.5 motors or 30t spec motors - personally, I'd rather see the 30t motor class and not 'open' motors, but that's not my call
Bodies By Bean | Team Belly
k_bojar is offline   Reply With Quote
Old 05-20-2009, 05:42 AM   #523
DarthRacer's Avatar
Perhaps people are being very anal about building their kits, or possibly just assuming what may be needed even before running it?
The only 'tweaking' I had to do to my kit was to ream out the suspension arm holes like most do on any kit. Everything went together well with no extra fitting required.
Old 05-20-2009, 10:04 AM   #524
So after looking and calling around, it seems no one has spare parts for this car except HPI. It's not like the kit came out yesterday, little over a month now?
Even found a comment on twitter: "re:HPI Cup Racer HPI needs to flood the resellers with spare parts. I had to buy parts direct from HPI at MSRP and full shipping. NOT HAPPY"
Any HPI reps reading this, please get your act together and distribute the parts. In these tough economic times, this is no way to be treating your customers. I'm still waiting to get a reply back in regards to shipping from you guys.
/end rant
Old 05-20-2009, 11:03 AM   #525
I know the guys at HPI USA are working as hard as possible to make the spares available...but I still feel your pain.
But in better news, YESSSS!!!!
I found it:
Tamiya TRF415 JDM_DOHC_SiR Electric On-Road 21094 03-10-2016 11:02 AM
The Future of RC Racing (Your Opinions) rccarracer15 Nitro Off-Road 103 06-10-2011 09:25 PM
Bodies for sale, new, used & painted coastaltony R/C Items: For Sale/Trade 68 01-02-2007 03:45 PM
Belt Driven vs. Shaft Driven Allen Sondej Electric On-Road 69 11-05-2004 07:51 PM
