Old 05-12-2009, 04:53 AM   #481
k_bojar's Avatar
Trader Rating: 30 (100%+)
Send a message via ICQ to k_bojar Send a message via AIM to k_bojar
Originally Posted by IndyRC_Racer View Post
If the F201 springs work, then springs for Associated micro shocks should work as well. Since those type of shocks are used as side shocks in 1/10 pan cars or center shocks on 1/12 cars, you can find quite a few different selections of springs.
didn't even think of them
time to dig out the pan car - now I just have to hope I have 2 of each spring
Bodies By Bean | Team Belly
k_bojar is offline   Reply With Quote
Old 05-12-2009, 05:11 AM   #482
k_bojar's Avatar
Originally Posted by MikeR View Post
Rear diff- I'm using the plastic diff gear and bearing spacer only with the stock Racer outdrives.
doh! I need to actually read directions - now I see what THAT little spacer is for I feel MUCH better now
Front- My spool fit a little loose into the dog bones being used and all. On a side note the pro4 spool is a bit narrow as well so the dog bones don't sit into the spool that well. Something I'll accept for now until someone comes out with a true lightweight Racer spool.
My spool is brand new, so it doesn't have any of the 'wear' yet I was thinking about getting out the dremel and making the openings a little bigger
Have you driven the bad boy yet?? I bet the binding goes away in half a battery pack. I'm hoping by my 6th pack my Racer becomes as free as my Pro4
Haven't got that far yet...Keep getting sidetracked Maybe either Wednesday or Friday I'll get power to it
Thanks Mike - so any ExoTek parts in the works for this??
Old 05-12-2009, 05:59 PM   #483
MikeR's Avatar
Trader Rating: 14 (100%+)
Originally Posted by freeway View Post
anybody know what brushless motor is under there ?
Judging by the huge pinion probably a 10.5
Yes
www.exotekracing.com ☆ASSOCIATED☆DURANGO☆HPI☆HB RACING☆KYOSHO☆LOSI/TLR☆SERPENT☆TAMIYA☆XRAY☆
A picture with your post, when trouble shooting, will probably get more rctech help than without...
MikeR is offline   Reply With Quote
Old 05-13-2009, 09:48 AM   #484
rai913's Avatar
Hey guys, I'm looking for some help. I've got a 10.5 on my cup racer and it keeps spinning out coming out of a turn. I've tried more droop in the front, raising the inner rear camber link, more rear camber, less caster and even layed the rear shock down a hole. It pushes a bit coming in a turn but still washes out going out. I'm guessing it's binding somewhere. Any ideas where?
Or what to look for?
rai913 is offline   Reply With Quote
Old 05-13-2009, 09:55 AM   #485
Trader Rating: 28 (100%+)
Ryan,more droop in the front will not only transfer more weight to the rear which in theory should help,but it also increases on power steering which can cancel out the the effect you were try to achieve.This sounds like something else.One other thing to check.Tires.Make sure you have no beads that are coming undone or even slightly broken.Bring that thing to Norcal.I will figure it out.
Team I'm Over It
racenut123 is offline   Reply With Quote
Old 05-13-2009, 10:58 AM   #486
If you are using the kit springs, they won't work with anything faster than a silver can. My car with a 27T stock motor did the same thing as above with the kit springs. Much better once I used the F201 harder springs.
Other tid bits are to make sure the suspension can fall freely with no shocks, and make sure there are no binding from over-tightening the wheel screw.
redbones is offline   Reply With Quote
Old 05-13-2009, 11:25 AM   #487
MikeR's Avatar
More rear toe in- 3 deg total. 1 deg front toe. Make sure the rear ride height isn't so low that the chassis is scraping on power. Maybe you are getting a little torque steer on throttle w/ the 10.5? Might have to try a smoother profile on the esc and turn the throttle curve down on the radio.
Maybe different tires- push on entry and loose on power means not enough grip.
Old 05-14-2009, 04:39 AM   #488
k_bojar's Avatar
ok, i'm going to try something 'simple' because I've had a similar problem in the past and went thru everything to get the car to stop looping
did you try adjusting your rear diff - I mean make it looser?? I know that was what solved my problem - had the diff too damn tight and kept spinning out in turns, not both ways, just one way
hope that helps
Old 05-14-2009, 11:26 AM   #489
tsais's Avatar
Is there any HPI hopups available for purchase anywhere? I am interested in getting the brake disk kit.
tsais is offline   Reply With Quote
Old 05-14-2009, 11:42 AM   #490
academygaz's Avatar
New bodies:
Quote, Leodis, 2007: ''I've been shopping online for 9 years and the only charge I've ever had to dispute with my credit card company was from TiR. Congratulations TiR. Even porn sites are more ethical than your company!''
RC cars - I haz sum.
academygaz is offline   Reply With Quote
Old 05-14-2009, 11:47 AM   #491
DarthRacer's Avatar
Originally Posted by academygaz View Post
New bodies:
Those are beautiful!
DarthRacer is offline   Reply With Quote
Old 05-14-2009, 12:18 PM   #492
snoopyrc's Avatar
Actually its just one new shell, and the set of wheels but I like it. Im all for it.
www.battlefieldraceway.com Racing videos at http://www.youtube.com/snoopyrc
snoopyrc is offline   Reply With Quote
Old 05-14-2009, 01:05 PM   #493
Official's Avatar
Just finished building up my Cup racer. Looks Awsome. But now looking for some slicks and pinion gears for it. Anyone know where in singapore i can get it? Looking for 39t pinion or 36.
Chassis :4WD = CEFX Photon,TA-05|2WD = Xevo, M05PRO, FF-03Pro, Kysho Evola M3, Kyosho V-One RRR Shimo, Team C TC02
ESC :Brushless - Tekin RS-Pro, Keyence Tachyon|Brushed - Tekin FX-Pro
www.hiro-seiko.com ; www.cefx.net
e-mail: officialracing@gmail.com
Official is offline   Reply With Quote
Old 05-14-2009, 11:34 PM   #494
For you experts....
If getting spare ABC Genetic parts is not an issue, would it be a better car than the cup racer? Or these two are about equal in design and performance?
Thanks.
cvccsi is offline   Reply With Quote
Old 05-15-2009, 01:14 AM   #495
MikeR's Avatar
Originally Posted by cvccsi View Post
For you experts....
Thanks.
Out of the box I would lean towards the Genetic IMHO. Better tires, race inspired and a little cheaper. Once the hop ups come out for the Racer it will balance out but that means more $$. The aftermarket and factory support for the Racer and overall appeal is what makes the Racer a winner tho for most people.
Tamiya TRF415 JDM_DOHC_SiR Electric On-Road 21094 03-10-2016 12:02 PM
The Future of RC Racing (Your Opinions) rccarracer15 Nitro Off-Road 103 06-10-2011 10:25 PM
Bodies for sale, new, used & painted coastaltony R/C Items: For Sale/Trade 68 01-02-2007 04:45 PM
Belt Driven vs. Shaft Driven Allen Sondej Electric On-Road 69 11-05-2004 08:51 PM
