Old 05-11-2009, 05:21 AM   #466
Send a message via ICQ to blue 3:16 Send a message via AIM to blue 3:16
hahaha dami dito nyan kabayan
blue 3:16 is offline   Reply With Quote
Old 05-11-2009, 07:39 AM   #467
freeway's Avatar
i had loads of fun inside those places chong, great to see you here. ingat
freeway is offline   Reply With Quote
Old 05-11-2009, 10:32 AM   #468
Originally Posted by sim600 View Post
You're right. Atsushi Hara's car taken during qualifying day at the KLGP race over the weekend...
What springs are those on the rear? The kit springs are too soft when you use aftermarket slicks. Anyone know alternative springs that can be used?
redbones is offline   Reply With Quote
Old 05-11-2009, 11:59 AM   #469
Core Creations's Avatar
Trader Rating: 94 (100%+)
Send a message via AIM to Core Creations
Maybe F201 springs???
Core Creations paint thread
Mini Mafia Kansas Chapter - where the monster minis grow!
Core Creations is offline   Reply With Quote
Old 05-11-2009, 12:54 PM   #470
My friend still has his F201. I'll try and see if they are the same diameter unless someone beats me to that.
Old 05-11-2009, 04:05 PM   #471
Has anyone done the standup steering servo mounting? What servo are you using?
AZRacer18 is offline   Reply With Quote
Old 05-11-2009, 04:45 PM   #472
freeway's Avatar
mine is lay down
Old 05-11-2009, 05:59 PM   #473
k_bojar's Avatar
Trader Rating: 30 (100%+)
Send a message via ICQ to k_bojar Send a message via AIM to k_bojar
I still got my sets from my F201 - I didn't even think to try them
MikeR - when you used the Pro4 gear/stuff, did you use the entire Pro4 diff w/halves and internals?? I tried swapping the metal gear for the Pro4 gear and the stock bearings are too small. So I swapped that out and them lost ALL diff action - so I'm baffled
Another one - on the spool in the front, did you have to 'machine' anything on the outdrive sides to get the CVD end to fit?? My brand new spool was super tight and caused a TON of binding...
So for I'm 0 for 2 with the Pro4 mods
Bodies By Bean | Team Belly
k_bojar is offline   Reply With Quote
Old 05-11-2009, 07:06 PM   #474
F201 springs or the springs that come with the 3Racing shocks for the F201 will work just fine. Same diameter and length as the kit springs.
Shoot for the best, expect the worst and be willing to accept anything in between.
MADHAT is offline   Reply With Quote
Old 05-11-2009, 07:23 PM   #475
freeway's Avatar
sounds good, was there a big difference in handling ?
Old 05-11-2009, 07:40 PM   #476
Tried the F201 springs on, and they fit. They are about 1mm smaller in diameter so you can't use the top spring retainer and the bottom one will be a little squished. But they will work. I have yet to try them out at the track but I have a feeling it will handle much better now.
Old 05-11-2009, 08:16 PM   #477
IndyRC_Racer's Avatar
If the F201 springs work, then springs for Associated micro shocks should work as well. Since those type of shocks are used as side shocks in 1/10 pan cars or center shocks on 1/12 cars, you can find quite a few different selections of springs.
I'm currently racing VTA. Check here for rules/info: http://www.usvintagetransam.com/
IndyRC_Racer is offline   Reply With Quote
Old 05-11-2009, 09:20 PM   #478
You know, now that I look at it, Hara might be using the F201 soft black springs... which are still harder than the stock ones.
Old 05-11-2009, 09:30 PM   #479
freeway's Avatar
anybody know what brushless motor is under there ?
Old 05-11-2009, 11:11 PM   #480
MikeR's Avatar
Trader Rating: 15 (100%+)
Rear diff- I'm using the plastic diff gear and bearing spacer only with the stock Racer outdrives.
Front- My spool fit a little loose into the dog bones being used and all. On a side note the pro4 spool is a bit narrow as well so the dog bones don't sit into the spool that well. Something I'll accept for now until someone comes out with a true lightweight Racer spool.
Have you driven the bad boy yet?? I bet the binding goes away in half a battery pack. I'm hoping by my 6th pack my Racer becomes as free as my Pro4
www.exotekracing.com ☆ASSOCIATED☆DURANGO☆HPI☆HB RACING☆KYOSHO☆LOSI/TLR☆SERPENT☆TAMIYA☆XRAY☆
A picture with your post, when trouble shooting, will probably get more rctech help than without...
MikeR is offline   Reply With Quote
Tamiya TRF415 JDM_DOHC_SiR Electric On-Road 21094 03-10-2016 11:02 AM
The Future of RC Racing (Your Opinions) rccarracer15 Nitro Off-Road 103 06-10-2011 09:25 PM
Bodies for sale, new, used & painted coastaltony R/C Items: For Sale/Trade 68 01-02-2007 03:45 PM
Belt Driven vs. Shaft Driven Allen Sondej Electric On-Road 69 11-05-2004 07:51 PM
