Old 05-06-2009, 02:15 PM   #421
Yeah, if you built a TB evo or TB03, shimming helps with some of the noise from the bevel gears.
redbones is offline   Reply With Quote
Old 05-06-2009, 05:57 PM   #422
well I overtightened the bolt in the center of the rear diff and snapped it be careful cause it's easy to do)
kingcobra69 is offline   Reply With Quote
Old 05-06-2009, 07:15 PM   #423
Originally Posted by DarthRacer View Post
Thanks for the tips.
I received a bad part in my kit, PN 86194. There were no notches in it to match up with the bevel gear on the opposite side, and if I tightened it down the assembly was hard to rotate. HPI is sending a replacement but I have to wait 5 business days. . Anyone else get bad or defective parts?
Defective parts? Yes. Bent ball diff screw. Front diff ring gear had chunks of metal missing in the teeth. Flashing in the metal gears.
Per HPI the diff screw isn't available til the end of the month. Guess I won't be running this car anytime soon.
Sydewynder is offline   Reply With Quote
Old 05-06-2009, 11:31 PM   #424
rai913's Avatar
Just finished my cup racer and the body is really detailed. Still waiting for the 510. I did encounter a motor plate screw hole that was too big, I just put a bigger screw in. Hope to run it soon waiting for esc and 17.5.
rai913 is offline   Reply With Quote
Old 05-07-2009, 12:52 AM   #425
i change the diff front and locker put at back because i want do it for drifting will it work? i havent test witing for motor
LoongJess is offline   Reply With Quote
Old 05-07-2009, 01:54 AM   #426
Trader Rating: 65 (100%+)
You should be able to use the diff screw from a Pro 4.
tadashi is offline   Reply With Quote
Old 05-07-2009, 03:47 AM   #427
Unfortunately the Pro 4 is 25mm long and the cup racer is 32mm long. Oh well thanks anyway.
Old 05-07-2009, 04:58 AM   #428
What color is that? Copper?
Looks great. My paint sould arrive next week and then I can get mine finished up.
Bodywerx_rc is offline   Reply With Quote
Old 05-07-2009, 05:30 AM   #429
k_bojar's Avatar
Trader Rating: 30 (100%+)
Send a message via ICQ to k_bojar Send a message via AIM to k_bojar
Originally Posted by MikeR View Post
Yes, complete PRO4 front spool and bevel gear for the front. It is a few mm narrower than the Cup Racer diff so the dog bones aren't as deep into it but because the spool is metal it seems to have plenty to hold the dog bones in. For the rear I'm using the stock diff outdrive but am using the PRO4 bevel gear. The PRO4 bevel gears are very close tolerance against the pinion gear and diff cases but I've put 3 packs through my car and it all is running very smooth, if not better each run.
Hey Mike - how's the mods holding up??
I got the parts I need to do this to mine on the way
Bodies By Bean | Team Belly
k_bojar is offline   Reply With Quote
Old 05-07-2009, 05:34 AM   #430
k_bojar's Avatar
not to take away from HPI, but has anyone seen what Hot Racing has released for the Cup Racer??
http://www.hot-racing.com/?c=467
Old 05-07-2009, 05:47 AM   #431
GREAT ! I will be getting some of those parts.
Old 05-07-2009, 08:26 AM   #432
freeway's Avatar
good find, any info on hotracing quality ?
freeway is offline   Reply With Quote
Old 05-07-2009, 08:26 AM   #433
Kevin K's Avatar
Trader Rating: 32 (100%+)
Send a message via AIM to Kevin K Send a message via Yahoo to Kevin K
Anyone looking for one of these cars PM me I have one that I have no need for make me an offer....
2013 USVTA World Champion of the World
MOTIV RC presents the Midwest All-Star Carpet Series....14th year running 2016/17!!!
USVTA National Championship....check it out!!!
Im only responsible for what I say NOT what you understand.
Kevin K is offline   Reply With Quote
Old 05-07-2009, 09:44 AM   #434
tsais's Avatar
Default hopups for the CR from TSAIS
new hopups for the HPI cup racer at tsais.com
tsais is offline   Reply With Quote
Old 05-07-2009, 10:19 AM   #435
k_bojar's Avatar
so no discount if you purchase the entire motor mount kit, huh
cam + motor mount a + motor mount b = $44.98 (if purchased separately)
or $44.98 in the "kit"
nice looking stuff
Tamiya TRF415 JDM_DOHC_SiR Electric On-Road 21094 03-10-2016 12:02 PM
The Future of RC Racing (Your Opinions) rccarracer15 Nitro Off-Road 103 06-10-2011 10:25 PM
Bodies for sale, new, used & painted coastaltony R/C Items: For Sale/Trade 68 01-02-2007 04:45 PM
Belt Driven vs. Shaft Driven Allen Sondej Electric On-Road 69 11-05-2004 08:51 PM
SEO by vBSEO 3.5.0
