Old 01-27-2015, 10:47 AM   #3316
firefoxussr's Avatar
Originally Posted by firefoxussr View Post
I have my 21 turn Speed Passion setup from my F103 installed, it's clearly under-geared.
I used the biggest pinion on my 48p collection, which is 24 teeth. Anyone run higher tooth count or smaller spur?
It was a 26 tooth, kicked it up to 32 after reading standard is 30. Thinking lower turn motor. The 21.5 can go to the M05.
firefoxussr is offline   Reply With Quote
Old 02-13-2015, 06:11 PM   #3317
Rob34's Avatar
Default Cup Racer Fan
Hi all try this for you lipo to fit. Remove both battery cups you can do a little filling on the front stop some and the motor mount for a good fit but not necessary. One in pic's is no filled just tape it in.
HPI Cup Racer 1M-dsc04782.jpg   HPI Cup Racer 1M-dsc04780.jpg   HPI Cup Racer 1M-dsc04781.jpg   HPI Cup Racer 1M-dsc04784.jpg   HPI Cup Racer 1M-dsc04785.jpg
Rob34 is offline   Reply With Quote
Old 03-23-2015, 11:42 AM   #3318
Wink
Originally Posted by Anorak View Post
Hello!
Im a Cup Racer enthusiast from Norway. I'v found that also the 3racing 48 pitch spur gear fits the cup racer. They have the range from below 60t to way over 70t. The spur gears is a little bit slimmer than the original but they fit on the hub nicely. How durable they are i do not know, have had three packs through a 68t and it holds up fine. Just a heads up.
Hi, I am Greek enthusiast and bought a brand new cup racer last Christmas. I had a problem when I was fitted the genuine spur gear so it broke. And tried to find a similar one. I bought a 3racing 48pitch 65t and 2 kimbrough one 48p 66t and one 48p 69t . Kimbrough are exactly the same with the genuine better than 3racing. Now I'm running with the 69t kimbrough that fits perfect and with a brushless yuki sl3560 motor without any problem for a month .very durables! You can provide them from hobbyking.com for 5$ Each
Riskymiata is offline   Reply With Quote
Old 03-23-2015, 11:57 AM   #3319
As a new member here are two photos of my chassis and my favorite 1973 Porsche rsr.HPI Cup Racer 1M-image.jpg
Old 03-23-2015, 12:00 PM   #3320
Old 03-23-2015, 01:15 PM   #3321
eR1c's Avatar
Nice CR!
I sold one of mine that was NIB, still have another that is in 100% perfect ...it's a shelf queen for the most part. ...yet I have been thinking of selling it to fund a new project?
eR1c is offline   Reply With Quote
Old 05-27-2015, 01:37 PM   #3322
eR1c's Avatar
...and I sold it.
I have sold all my Cup Racers ...they are good cars, but decided to only keep what I race.
Old 08-11-2015, 04:09 PM   #3323
MOmo's Avatar
anyone know if an ESC designed for a 1/16 or "smaller size" RCs would work at powering a Cup Racer?
I have one that is a 1-off CS Drifter and I need a cheap ESC. Id rather not sacrifice a 1/10th scale ESC if I can help it, though I will if I need to.
Just curious. I have a sensorless Reedy 3500KV in it now, just need an ESC to pair with it.
MOmo
RACE CARS: B44.1, RC8.2E FT, SC10.2 4X4, B5M, YZ-2
RADIO: Futaba 4PKS/3PKS. BATTERY: Venom
ESC: SpeedPassion. MOTORS: SpeedPassion / Venom
"Im not a racer, but I play one on the Internet"
MOmo is offline   Reply With Quote
Old 08-12-2015, 01:15 PM   #3324
eR1c's Avatar
it's not so much about the car, as it is about the ESC and motor your using and if they are compatible.
Will the 1/16th scale ESC power your 550sized motor, -is that the question?
I believe that that 3500KV Assosciated is a 550 sized motor, yes?
Ideally you'd want a 540sized motor in that CR'r. And ideally you'd want an ESC that is made to power that 540sized motor ...I have not tried using an ESC for 1/16th scale purposes to power a 1/10th or larger scale motor. My hunch is that it will not work. For one, I think most 1/16th ESC's use smaller batteries, not the larger batteries used for 1/10th scale ESC's ...i think that will be an issue.
I'd personally try to get a 1/10th scale ESC for that motor ...otheriwse you may be out more money if you end up frying what you currently have.
Old 09-07-2015, 08:03 AM   #3325
sakadachi's Avatar
Got a HobbyWing XeRun Juststock the other day, wired up to my torquey 21.5T ReedySonic which I had no luck getting smooth performance out of my Novak GTB3 nor TBLE02-S.
But with the HobbyWing ESC on this chassis with 35 degree timing, runs very smooth and quick with the 30 teeth pinion.
4PKS-R, DX4S, EX-5UR: Sabre4WD Mini, SabreFD Mini, M01, M02, M03, M04, M05 (2), M05ProV2, TA05 M-Four, CupRacer, BSR M-Rage, WR02, GF01 (2), CC01 (2), CW01, CR01, DF02, TT02B, TA02, RS4, MicroRS4, MR01, MR03-S (2), MR03VE, DigiQ (7), & more.. Updates of projects I am working on in my profile page.
sakadachi is offline   Reply With Quote
Old 09-19-2015, 02:54 AM   #3326
After a cup racer for my son. If anyone has a NIB or one in very good condition can you please message me.
Cheers.
GasNutt is offline   Reply With Quote
Old 09-19-2015, 05:17 AM   #3327
SagadSetup's Avatar
Trader Rating: 38 (100%+)
I'm sort of regretting that I gave my cup racer away.
That's a nice CR Sak.
Are you right where you're supposed to be?
Think. Learn. Play. Plan. For soon you'll become.
SagadSetup is offline   Reply With Quote
Old 12-03-2015, 07:29 AM   #3328
My Cup Racer ate a spur, finally replaced it then found the hub cup wobbles a lot...enough to cause the spur to rub on the top plate, gear guard scews, etc. (I have a suspicion the wobbling is what caused the spur to get jammed & damaged.)
Is it unusual that the rear gearbox input shaft bearing can move in the housing?
The replacement is an Associated spur. It seems to be 2mm or so too thick. What's everyone using these days?
I haven't found a vendor with the stock spur available... I'd like to buy one.
Old 12-03-2015, 09:26 AM   #3329
eR1c's Avatar
it shouldn't move, the bearing should sit snug.
...is it possible that the plastic around the bearing (on the gearbox) has warped-been destroyed since you mentioned you had issue w/ a spur being eaten. Maybe this is causing the bearing to not be seated correctly?
Old 12-03-2015, 04:42 PM   #3330
The thought had crossed my mind (though I wouldn't know any better as I bought the car secondhand... i.e. didn't assemble it).
Thank you, helpful response always eR1c
Parking lot heroes: M06, TA05sw, XV01, XRay T1, SC10B
Partially disassembled: HPI Cup Racer, FGX, M04, TA02, TA05 IFS
Newest acquisitions: A210SS Exige, HPI MX-5, Tamiya F40
Tamiya TRF415 JDM_DOHC_SiR Electric On-Road 21094 03-10-2016 11:02 AM
The Future of RC Racing (Your Opinions) rccarracer15 Nitro Off-Road 103 06-10-2011 09:25 PM
Bodies for sale, new, used & painted coastaltony R/C Items: For Sale/Trade 68 01-02-2007 03:45 PM
Belt Driven vs. Shaft Driven Allen Sondej Electric On-Road 69 11-05-2004 07:51 PM
