Old 02-03-2013, 12:04 AM   #3001
Originally Posted by DarthRacer View Post
I'm looking for an aluminum front diff input cup to replace the plastic one on parts tree 85281. I guess Exotek doesn't make them anymore. Are there any others out there?
Look at the 5th post down on the previous page. Someone is setting up a buy to have an Al cup made.
Sydewynder is offline   Reply With Quote
Old 02-03-2013, 07:29 AM   #3002
DarthRacer's Avatar
Thanks. I guess that is the only option?
DarthRacer is offline   Reply With Quote
Old 02-03-2013, 07:13 PM   #3003
I am trying to amass an order for a machinist to custom mill this input fitting for us. So far I believe there are four of us. We would need a total of 10. Please send me a PM if you are interested. This fitting was made by Exotek and now long discontinued.
CarerraRSeattle is offline   Reply With Quote
Old 02-04-2013, 01:05 AM   #3004
seek on ebay, too! Good luck!
Zavo66 is offline   Reply With Quote
Old 02-04-2013, 04:08 AM   #3005
Have you seen them on there recently because I haven't been able to find any in quite a while....
fritzzz is offline   Reply With Quote
Old 02-04-2013, 07:58 AM   #3006
Default Alloy shock bodies.
You could have just linked my post Stu. Ha.
1000 apologies. Wasn't taking credit on purpose, just cut and paste to help out a fellow CR man. Thanks for your help, again.
stu_bry is offline   Reply With Quote
Old 02-04-2013, 03:33 PM   #3007
Ha no worries. I just thought you typed out everything. Feel free to use my posts. They are public afterall.
Old 02-04-2013, 03:34 PM   #3008
I think this is the only option right now.
Old 02-04-2013, 03:54 PM   #3009
DarthRacer's Avatar
Ah well will probably get a stock one for now.
Does anyone have a good base drift setup?
Old 02-05-2013, 09:48 AM   #3010
really sorry, a few days ago I was able to find that, but today nothing...
Old 02-08-2013, 08:43 PM   #3011
Rob34's Avatar
Hi I have 2 cup racers I race in a t.c. class And i play with a brushless 9.0
turn as for the front drive cup i have 2 ways two help i drilled holes .045 i.d.
and used piano wire to pin a new one or just pin the old one its not real easy
good luck
Rob34 is offline   Reply With Quote
Old 02-08-2013, 08:49 PM   #3012
DarthRacer's Avatar
good luck
I had a similar idea and was wondering if it would work. Thanks for the tip!
Old 02-09-2013, 08:08 AM   #3013
Rob34's Avatar
Hi its works fine. Pic's are after I ran a hole season with the new one. The one
thats just pined in my brushless on the brushless the pins moved a little as you can see in the pic's.
Old 02-09-2013, 08:20 AM   #3014
DarthRacer's Avatar
Since you have two cars each with the different front shock setup, how is the handling different? I've had my CR built with the front laydown shocks and I have been thinking of going to the stand up position. I think it might be better for drifting. I've read the laydown position can make the handling a little lazy.
Old 02-09-2013, 06:05 PM   #3015
Rob34's Avatar
Hi ok I just put the upright shocks on to try it. Took it out today it's more stable at high speed. I will be taking it out on Sunday to the track let you know how it goes. But as for drifting I am not sure I do not drift. For the lay down
shocks I race with. I went with 30wt shock oil with gold sprigs it help alot.
I hope it helps you.
Tamiya TRF415 JDM_DOHC_SiR Electric On-Road 21094 03-10-2016 11:02 AM
The Future of RC Racing (Your Opinions) rccarracer15 Nitro Off-Road 103 06-10-2011 09:25 PM
Bodies for sale, new, used & painted coastaltony R/C Items: For Sale/Trade 68 01-02-2007 03:45 PM
Belt Driven vs. Shaft Driven Allen Sondej Electric On-Road 69 11-05-2004 07:51 PM
