Old 01-28-2012, 07:31 PM   #2806
EM1-TC3's Avatar
Originally Posted by Raman View Post
FYI guys, regardless of what car you own, stay away from GPM parts. They are beyond poor quality and very cheaply made to poor tolerances. So you're not really upgrading your car. Save your money.
Another thing, the less aluminum on your suspension the better. You hit a piece of plastic it flexes or breaks. Aluminum bends, straightening the bend is not easy. Also these cars do need a weak point to absorb the shock of the hit. By replacing those weak parts with harder parts only means you are going to damage something else.
Yeah my hind site is 20/20 and they're really not all that. The hubs imho are one thing but the arms was just overkill and to make the car faster
But seriously I have been fortunate enough when I have hit something it just pulls the hinge pin out and it's a matter of bending that orange suspension arm holder back or replacing it. Fingers crossed!
+1 on the GPM being soft, I had some rear knuckles on my TC3 and one wreck was all it took to twist one.....lesson learned
EM1-TC3 is offline   Reply With Quote
Old 01-28-2012, 07:43 PM   #2807
EM1-TC3's Avatar
Default Slipper Spool
Also... has anyone found an easy way to make a slipper spool for the front diff? I've swapped diffs at one point and tightened the ball diff as best I could but it still had plenty of give. I wasn't sure if anyone has tried a certain set of slipper pads to install in place of the ball bearings etc.
Thanks,
Old 01-28-2012, 08:15 PM   #2808
Trader Rating: 17 (100%+)
Originally Posted by Saint Bastia View Post
Hi CR owners,
Has anyone else noticed that in step 25 (page 33) of the build process, parts 75115 (ball stud) is attached directly to the plastic part 85279 #5, yet in the exploded view section (page 44) part 85279 #4 (plastic washer) fits in between parts 75115 (ball stud) and the plastic part 85279 #5.
Cheers.
Indeed, the extra washer is a tuning option that gives the rocker a slightly different ratio.
This is Hell, Dante. Not your personal fantasy.
burnineyes is offline   Reply With Quote
Old 01-29-2012, 02:40 AM   #2809
Originally Posted by aSab View Post
a further must have item is the spring kit. don't ever think you can have enough fun (I mean speed) with the stock springs installed
Which spring kit?
Or do you mean the sway bar kit?
fritzzz is offline   Reply With Quote
Old 01-29-2012, 08:07 AM   #2810
EM1-TC3's Avatar
Originally Posted by fritzzz View Post
Which spring kit?
the part number is HPI87320
they can be found on eBay for $13.32 w/ free shipping from EverthingRC.
They are the hard set, I personaly run the pinks up front and the blue in the rear and the car is much better. Had a lot of body roll before. I believe the second are the "Soft" and they should only be used on the front shocks if you are using the laydown style of dampening......I think
On the sway bars I only run the stiffer bar up front and to be honest I haven't had a lot of quality track time with the car to really notice any difference, I will say definetly do the springs first because that will make the most drastic change in the handling. And if you're running front stand up shocks the HPI carbon shock tower is good
Old 01-30-2012, 12:09 PM   #2811
jgGonzo's Avatar
Trader Rating: 27 (100%+)
Thanks,
This should fit:
http://www.ebay.com/itm/HPI-Pro-4-Fr...item519cccc10e
I run the pro4 one way in mine and it works/fits fine..........so this should.
RS4 MT/RS4/Pro2/Pro4/Pro5/D413/RS4 Nitro MT/RS4 Micro/RS4 3 18ss/RS4 Rally/Blitz
Blitz ESE/E.Firestorm/Super E.RS4/MT2 Slash Killer/Mini Recon/HB Cyclone/Midnight Pumpkin
Blitzer Beetle/Revo3.3/Slash/Slash 4x4 Platinum/Mini E.Revo/EXO Terra/SCX10/Twin Hammers
Pro2SC/DEX210/DEST210R/DESC210R/Tekno 410.3/Yeti XL/Kyosho Beetle/Team C TS4
Scorpion XXL
jgGonzo is offline   Reply With Quote
Old 01-30-2012, 07:31 PM   #2812
EM1-TC3's Avatar
Originally Posted by jkgonzo View Post
This should fit:
Cool I will look into that, thanks!
Have you had any issues snapping an axle with that spool installed?
Old 01-31-2012, 05:58 AM   #2813
jgGonzo's Avatar
I run the one-way, not the spool. Still never had any issues with it.......I did run the spool in my pro4 for asphalt racing. Didn't like it, real choppy around tight corners and wore the one-way cups pretty bad.
Scorpion XXL
Old 02-02-2012, 03:55 PM   #2814
Saint Bastia's Avatar
If the washers are used is the shock dampening effect harder or softer ?
Thks,
Bas
"All that is necessary for the triumph of evil is that good men do nothing"
Saint Bastia is offline   Reply With Quote
Old 02-02-2012, 03:56 PM   #2815
error
Old 02-02-2012, 04:20 PM   #2816
With the exra spacer the effect is a firmer shock.
Old 02-02-2012, 05:39 PM   #2817
Smile Upgrading the standard shocks.
Hi,
Well I got my CRer a week or so ago and have just about finished the build. I was wondering if anyone knows if you can upgrade the standard shocks with the Aluminum shock bodies. HPI 87070. The bottom of the standard body looks different. Or do I have to buy a full kit of aluminum shocks?
Thanks for your help,
Stu.
stu_bry is offline   Reply With Quote
Old 02-02-2012, 06:48 PM   #2818
A few minutes ago i just installed them in the front shock setup and they do feel firmer
Cheers,
Bas
Old 02-03-2012, 05:36 PM   #2819
Originally Posted by stu_bry View Post
Hi,
Stu.
Does anyone have some advice????
Old 02-03-2012, 06:41 PM   #2820
You need:
  • 2 sets #87070 Al shock bodies
  • 1 set #87071 adjuster nuts
Transfer everything else from stock plastic shocks except body and bottom plastic snap cap. If o-rings are old I'd just get a new pack #87069
Important: You need part #13, plastic washer (4 of them) from both parts trees 85282 (there are 2 on each tree). These hold the clear o-ring in place before you clip in the C clip supplied with the new shock bodies.
Sydewynder is offline   Reply With Quote
Tamiya TRF415 JDM_DOHC_SiR Electric On-Road 21094 03-10-2016 11:02 AM
The Future of RC Racing (Your Opinions) rccarracer15 Nitro Off-Road 103 06-10-2011 09:25 PM
Bodies for sale, new, used & painted coastaltony R/C Items: For Sale/Trade 68 01-02-2007 03:45 PM
Belt Driven vs. Shaft Driven Allen Sondej Electric On-Road 69 11-05-2004 07:51 PM
