Old 08-12-2011, 09:28 PM   #2566
Make sure the bearings are seated in the Hot Racing axles and the bearings/axle cups are seated in the HPI alloy knuckles.
How are you judging the offset? Is it with the tire to the wheel well? Sometimes the body is not quite symmetrical and the offset looks off. Use a ruler to measure from the center of the chassis to one tire/wheel. Do the same for the opposite side and compare the two measurements.
Sydewynder is offline   Reply With Quote
Old 08-13-2011, 09:36 AM   #2567
The bearings are seated all the way into the hub carriers and the axle cups aswell. I can see that the offset is off because the the front right wheel with a 0mm offset hub covers the two allen screws that hold the carrier hub to the a-arms where as the opposite side is not covering the screws. I also noticed that the dog done side of the axle sits further outside of the out drive cup, close to the edge.
AndrewSi is offline   Reply With Quote
Old 08-13-2011, 11:05 AM   #2568
aSab's Avatar
Default My CR
after lots of offroading with my SC10 and B44, I did sell the B44 when I got fed up with it and so I decided to try out the Cup Racer. Ever since I was a kid I loved the looks of the Porsche Carrera...
hope I'll have lots o' fun with it though - the paint job was done by me, using Pactra cans.
I know the body is sitting too high up, but until I get used to the car, I'd like to leave it that way...
aSab is offline   Reply With Quote
Old 08-13-2011, 02:00 PM   #2569
Are you using different offset wheels for the front and rear? Maybe the wider offset rears were put on the right side of the car.
Old 08-15-2011, 06:26 PM   #2570
Saint Bastia's Avatar
Hi All,
Just a heads up that i'm selling my spare CR kit.
Here's the link for those interested NEW HPI CUP RACER KIT FOR SALE
Cheers.
"All that is necessary for the triumph of evil is that good men do nothing"
Saint Bastia is offline   Reply With Quote
Old 08-16-2011, 08:47 AM   #2571
All of the rims have a 0mm offset. This is really weird becuase it does not look like anything is wrong or off. Maybe it's the hot racing axle cups, not all the same lenght? Either that or I am thinking it might be the plastic hubs that connect the wheels to the axle cups because it seems that they do not sit flush, they kind of stick out alittle.
Old 08-16-2011, 09:34 AM   #2572
gashuffer's Avatar
Trader Rating: 48 (100%+)
I have a cup racer with the hpi aluminum front and rear hub carriers with hot racing axle cups and when I put the 0mm offset plastic hubs on all four wheels the two wheels(front/rear) on the right side of the car sit further in than those on the opposite side. I have to put a 2mm spacer on the front right wheel to match the front left wheel with a 0mm offset spacer. And a 1mm spacer on the rear right wheel to match the rear left wheel with a 0mm offset spacer. The rims all have a 0mm offset.
Anyone know the reason/cause of this?
Post up some pics..
T-Sal
gashuffer is offline   Reply With Quote
Old 08-16-2011, 03:56 PM   #2573
I would, if I could! lol
How many posts do you have to have to post links/pics?
Old 08-17-2011, 09:45 PM   #2574
aSab's Avatar
doesn't depend
you simply upload your photo to a storage space like photobucket or picasa, and the you use the button to link to it when you do the post
Old 08-19-2011, 12:19 PM   #2575
kmas's Avatar
Trader Rating: 59 (100%+)
anyone run 26mm wheels/tires on these?
kmas is offline   Reply With Quote
Old 08-19-2011, 02:34 PM   #2576
Callahan_88's Avatar
All with 26mm rims!
Go big or go home! :)
Callahan_88 is offline   Reply With Quote
Old 08-19-2011, 03:35 PM   #2577
I've run 28mm foams.
Old 08-19-2011, 09:23 PM   #2578
Originally Posted by aSab View Post
doesn't depend
It's telling me that I can't post any links or URL's because I don't have a high enough post count.
Ohh also Is anyone running an exotek alloy front input shaft? I bought one a couple weeks ago and just got around to installing it today but that sucker will not fit inside the bearings. It seems the diameter is a tad to big. Is this how it is or did I get a dud?
Old 08-20-2011, 01:21 PM   #2579
kmas's Avatar
what are good upgrades for stock car, where items would break or wear under a brushless mod motor? Im starting to build one, was thinking about getting the exotek chassis..........what else? thx
Old 08-20-2011, 02:03 PM   #2580
Raman's Avatar
Trader Rating: 51 (100%+)
Car is fairly durable. Only week point is the front joint cup for centre drive shaft. Exotek has a replacement. if you plan on racing the carbon shock towers and upgraded threaded shocks.
TRF419X / Pulse 17.5, T.O.P Racing Sabre Mini AWD / Impact 21.5, M06 Pro / Impact 21.5, XV-01 Pro Rallye / Kinetic 17.5
Raman is offline   Reply With Quote
Tamiya TRF415 JDM_DOHC_SiR Electric On-Road 21094 03-10-2016 11:02 AM
The Future of RC Racing (Your Opinions) rccarracer15 Nitro Off-Road 103 06-10-2011 09:25 PM
Bodies for sale, new, used & painted coastaltony R/C Items: For Sale/Trade 68 01-02-2007 03:45 PM
Belt Driven vs. Shaft Driven Allen Sondej Electric On-Road 69 11-05-2004 07:51 PM
