Old 07-10-2011, 12:57 PM   #2536
Raman's Avatar
Trader Rating: 49 (100%+)
This is my set up.. not sure if it will help you
As you can see my battery is wired in there. The GensAce battery that Skadoosh posted will definitely work..
With regards to the HPI battery, in the manual.. page 37, it shows you how the wire for a stick pack is supposed to be routed.
TRF419X / Pulse 17.5, T.O.P Racing Sabre Mini AWD / Impact 21.5, M06 Pro / Impact 21.5, XV-01 Pro Rallye / Kinetic 17.5
Raman is offline   Reply With Quote
Old 07-11-2011, 11:12 AM   #2537
cheers raman... thats great gives me an idea of where to go, i need to get a few velcro straps of ebay i guess or my local hobby shop... how have you fixed the rx/ and esc? any pics of your shell mounted up?
postie90 is offline   Reply With Quote
Old 07-11-2011, 11:34 AM   #2538
Raman's Avatar
Double stick tape for the RX and ESC. Velcro straps.. any hardware store should have it, along with Hobby stores etc.
Old 07-13-2011, 07:52 AM   #2539
Is there anywhere that races these in the New Jersey area on a semi-regular basis at least?
slubben is offline   Reply With Quote
Old 07-13-2011, 12:41 PM   #2540
where can i find the carbon fibre front and rear shock towers that are in stock? rc-mart say the front is now discontinued? any ideas please, thanks...
Old 07-13-2011, 12:49 PM   #2541
Trader Rating: 69 (100%+)
you can find the towers on ebay.
Markus is offline   Reply With Quote
Old 07-13-2011, 12:51 PM   #2542
is it worth buying them.....
Old 07-13-2011, 10:10 PM   #2543
Is there a Pre-Setup sheet for the Cup Racer, like a starting point for the droop, camber, toe, height?
CEASER is offline   Reply With Quote
Old 07-14-2011, 11:13 AM   #2544
found them on tower hobbies so i ordered them, want the crx carbon chassie now....
Old 07-15-2011, 10:23 AM   #2545
Suspended
Trader Rating: 86 (100%+)
i got a cup racer exotek chassis with aluminum drive cups, x11 17.5t motor, new sweep 28r tires and temp gun selling
cup racer exotek chassis, x11 17.5, sweep 28r, temp gun
littlealex is offline   Reply With Quote
Old 07-17-2011, 03:53 AM   #2546
My motor heat sink has snapped so need a new one, carnt seem to find one any where, any help would be great
Old 07-17-2011, 08:38 AM   #2547
can someone link what lipo`s fit crx exotech chassis without rubing on the steering coloum?
Old 07-17-2011, 02:14 PM   #2548
knowbody link any lipo`s that fit with the crx carbon chassie? also what pinion size is best to run it this kit? cheers in advance.
Old 07-21-2011, 11:18 AM   #2549
Guys please any advice as to what lipo`s to run in this model? i`ve sorted the pinion... out.. but as yet found a battery to run with CRX carbon chassie.. thanks.
Old 07-21-2011, 11:59 AM   #2550
k_bojar's Avatar
Trader Rating: 30 (100%+)
Send a message via ICQ to k_bojar Send a message via AIM to k_bojar
you're talking about the exotek chassis?? If so, the last time i've run my cup racers, I was using a 3800mah lipo pack (square shaped, not rounded stick pack styled) - it fit without issue
I believe the exotek one is make to fit up to 5000mah without much issues
as far as what pinion, that's going to depend on what kind of track you're racing on, assuming you are racing it...if not, it'll still depend on what you're planning to do with the CR
Bodies By Bean | Team Belly
k_bojar is offline   Reply With Quote
Tamiya TRF415 JDM_DOHC_SiR Electric On-Road 21094 03-10-2016 11:02 AM
The Future of RC Racing (Your Opinions) rccarracer15 Nitro Off-Road 103 06-10-2011 09:25 PM
Bodies for sale, new, used & painted coastaltony R/C Items: For Sale/Trade 68 01-02-2007 03:45 PM
Belt Driven vs. Shaft Driven Allen Sondej Electric On-Road 69 11-05-2004 07:51 PM
