HPI Cup Racer 1M
#2521
Which rounded LiPo packs fit?
Hi,
Just about completed my build and I've gone to put my SuSuMu LiPo pack in there and with the lead configuration on there it doesn't fit.
The LiPo is curved and is shaped like a NiMH stick pack.
The power and balance leads both come out of the end of the pack and there is not enough room in the part at the rear of the car for both leads to fit and then head upwards, plus the balance lead on the pack is only about 1" long so it's stuck down near the drive shaft.
I'd like to stick with the curved pack style but would prefer one where the leads come out of the top of the pack on the corners.
Can anyone tell me what LiPo packs they have in their cars now that fit?
#2522
Hi,
#2523
This is the battery that I have.
Both sets of leads come out of the centre at the end which is the problem.
I did look at the strap / tray arrangment and thought I could zip tie them in that way but the short balance plug lead is a bit of an issue.
Can you post a link to a battery with the ones out the side?
#2524
I have these installed right now with the red lead going through the round 6 mm hole in the top deck. With this set up, I'm not able to swap batteries between heats. Instead I just recharge the pack between heats.
http://www.hobbyking.com/hobbyking/s...dproduct=14988
I recently picked these up, They should work.. although I have not tried them our of laziness and lack of need..
http://www.hobbypartz.com/77p-sl4000...-hardcase.html
#2525
Thanks for the links.
As both are square packs, have you got the curved battery mounting arrangement or the one that is geared up for the open cell style with taping?
Any chance of a photo?
#2526
just got a new nickel metal battery pack hoping this thing will be faster and last alot longer as soon as i figure out the best way to care for the battery
#2528
Hi,
Fits great. I am using velcro straps to secure it. It works great. I can probably use a battery with less capacity. So far, with that pack, I have run it almost 2 hours and I still didnt hit the lipo cutoff.
#2529
Sold my CupRacer-CRX and this is the new owners first new body for it!
Absolutly love it one of the best 510 i have seen!
And i love that he still rides with my old famous "Callahan camber" setup!
#2530
#2531
ive just bought a second had cup racer in very good condtion, my first question... i have a hpi plazma stick lipo but the wires seem to get in the way when fitting? am i missing a trick or have i got the wrong type of battery? cheers guys...
#2532
also whats the best way to fix the rx and esc to the chassie, never run run on raod b4...
#2533
Hopefully a few people can post pictures of their set-up.
#2534
any pictures of the chassie with everything fitted anywhere..
