Old 06-14-2011, 08:45 AM   #2491
eR1c's Avatar
..sorry, wasn't trying to offend you or talk down (w/ the FPS lesson).
it is just difficult to get a sense of how fast something is travelling on a YouTube video ..looking at it visually.
You mentioned that you have a 13.5 turn motor w/ a 1500mah nicad pack, and Novak GTB ESC.
do you mean "NiMH", or are you using a nicad? If a nicad, then that battery isn't listed to work w/ that ESC and may be your issue:
here is what the Novak GTB ESC says about input voltage:
2S (Li-Po) / 4-6 cells NiMH (1.2V/cell)
you need to get a li-po or a nimh battery. nimh are less expensive if $$ is an issue. I'd recommend a 4800 or 5000 mah one.
eR1c is offline   Reply With Quote
Old 06-14-2011, 11:00 AM   #2492
lol don't worry man no offense taken just saying i know where your coming from i actually like that you explained it most people dont know anything about fps or how it works
i have a new nimh pack on the way thats rated at 6800 mah not sure if thats accurate or not but its on its way i thought the battery pack might be holding me back but its the only pack i have to work with at the moment
current line up
traxxas tmaxx pro .15
traxxas tmaxx pro .15 converted to 2,5
traxxas jato
hpi cup racer 13.5 turn brushless
bonvo is offline   Reply With Quote
Old 06-14-2011, 02:04 PM   #2493
revoracer10's Avatar
Send a message via Yahoo to revoracer10
doesnt look to bad but somethings can be changed
-HPI e-firestorm 10t HT
-SCHUMACHER MI3 (coming)
revoracer10 is offline   Reply With Quote
Old 06-14-2011, 02:47 PM   #2494
Suspended
To get the best out of that 13 turn brushless, you really need to give it a 40C or better LIPO pack, because it can dish up the current much more efficiently and dish up more current than the NIMH can.
The car i currently drive came with a NIMH battery, changing to a 3200 50C Lipo gave me a 3 second per lap speed increase, using the same rtr motor it came with.
The 6800 NIMH will give you much longer run times, but if you are after better lap times, hi rated C lipos are the way to go IMO.
RogerDaShrubber is offline   Reply With Quote
Old 06-14-2011, 02:57 PM   #2495
k_bojar's Avatar
Trader Rating: 30 (100%+)
Send a message via ICQ to k_bojar Send a message via AIM to k_bojar
Originally Posted by bonvo View Post
i understand how fps works (took film classes in high school made a few shoryt films etc) but that video is a good representation of how fast it goes
the main reason i ask is my friend has a brushless 2wd slash on 2 s lipos that is 3 times as fast and that just seems backwards to me
the one thing you need to take into consideration is tire diameter, which factors into roll-out..internal gear ratio plays alot into it as well...not as much as roll-out, but a lot
a slash has significantly larger tires - thereby giving it a higher rollout (ie, the amount of ground it covers in 1 revolution of a wheel)
your cup racer has smaller tires - if you put on standard TC wheels, it will go faster assuming you didn't mess with gearing.
that's why when you are running foam tires, you need to constantly be aware of what you're rolling out at - because as the tires get smaller, the car goes slower (assuming no changing of gear ratios)...
plus, what kind of motor does your friend have in his slash? is it the same as what you're running in your CR?
Bodies By Bean | Team Belly
k_bojar is offline   Reply With Quote
Old 06-14-2011, 02:59 PM   #2496
k_bojar's Avatar
another thing to consider - lipo's hold their voltage much longer the nimh cells...so over the course of 1 min (for example) a lipo pack may still be sitting at 8.41v whereas your nimh may be down to 8.00v...the longer a pack holds its voltage, the stronger (and faster) it'll run
Old 06-14-2011, 04:46 PM   #2497
eR1c's Avatar
..Lipo is definitely the way to go,
yet if you already have a 6800MAH NIMH battery on the way try that out. I'd bet that you'll get much better performance than your 1500 NICD, -which isn't even rated for use w/ that ESC you have. I think what you're doing w/ the new battery is a good thing to try.
If that doesn't give you faster performance, you should also check your ESC programming. That ESC has several programmable forward scenarios, ...you may have it programmed to something that isn't allowing full power? -probably not, but worth checking (and it doesn't cost $$).
If your using the standard CR'r tires, i wouldn't worry 'bout that too much. I have a 17turn and my CR'r flies ...whether i use the 60mm CR'r tires or a little larger 64mm sized tires ...doesn't seem to make a noticeable difference for parking lot driving.
i'd go through and recheck your gear mesh, the ESC programming, make sure your motor is in good shape. From the video you shared it looks like your tires are pretty standard size, ..you don't have Clod Buster tires on it or anything! ....the battery seems like a logical place to start (especially since you were using a Nicd when it should be a Nimh or Lipo for that ESC).
Let us know what happens w/ the new battery. I am curious.
Old 06-14-2011, 04:56 PM   #2498
my friend just has the stock traxxas brushless system in his slash
i do plan to go lipo later but right now it was easier to get a nimh pack that i already have a charger for then a new lipo pack and $50+ for a charger ive messed with the programming a little so i now have reverse and turned the drag brake off but other then that i havent done much we shall see what a new pack does cause im curious as well
current line up
traxxas jato
Old 06-20-2011, 09:39 AM   #2499
eR1c's Avatar
..I installed these aluminum axle cups in my CR'r.
http://cgi.ebay.com/HPI-Cup-Racer-al...item3a671837ec
In my last competition one of the rear tires came off in both of the events I competed in. I am wondering if I need to put a little blue loctite on them to keep them snug? ...yet is that the best way to go considering I change tires after each race ...and will be changing tires often ..not sure I want to junk up the threads w/ loctite each time? Anyone else experience this? ...or maybe I just didn't tighten my wheels enough?
Old 06-23-2011, 12:09 AM   #2500
Think you don't need loctite, but check the wheels after each race. it is good moment to check the axle, bearings etc. too. Have a good day!
Zavo66 is offline   Reply With Quote
Old 06-23-2011, 07:29 PM   #2501
eR1c's Avatar
..yeah i usually do check everything, i think i must have forgot to check the wheels after the 1st race.
Old 06-23-2011, 09:59 PM   #2502
Raman's Avatar
Trader Rating: 54 (100%+)
You should not need loctite. The washers are serrated and bite down on the wheels to keep them tight. Just make sure you are tightening them down.
I still have the original hubs. I glued the nut inside the hub so that it wont move in and out on wheel changes. So far so good.
TRF419X / Pulse 17.5, T.O.P Racing Sabre Mini AWD / Impact 21.5, M06 Pro / Impact 21.5, XV-01 Pro Rallye / Kinetic 17.5
Raman is offline   Reply With Quote
Old 06-24-2011, 07:35 AM   #2503
Send a message via Yahoo to KrackerG
welp, i guess i know what my next r/c car will be....
a question, anyone know for sure if the older HPI mini wheels/tires will fit the new cup racer? offset is the same? I have a few sets and am not too crazy about the 4 spoke wheels...but i love the new hpi cup racer!
HPI CHALLENGE East Coast: '01 E-town, NJ, '02 spring Valley, NY, '03 Home Depot, NJ, '05 Delaware, '08 Cherry Hill, NJ and 301 Raceway in MD. - RTR Box Stock Nitro - Nitro Vintage TA - 1/10 Nitro Truck - Super Nitro
KrackerG is offline   Reply With Quote
Old 06-24-2011, 07:47 AM   #2504
i also have this old skool HPI Mini Pajero suv body, it was made for the RS4 mini or nitro mini, anyone know if it will fit the cup racer correctly?
link-->> http://www.hpiracing.com/graphics/bodies/7025paj.jpg
Old 06-24-2011, 08:49 AM   #2505
k_bojar's Avatar
it should, the cup racer has adjustable wheel bases that accomendate all the normal mini wheelbases...the tamiya old skool mini cooper will fit up to the longer wheelbase cars..
best thing - if you can find the wheel base for that body download a copy of the Cup Racer's manual from HPI's site its free and will give you everything you need to know about the chassis
Tamiya TRF415 JDM_DOHC_SiR Electric On-Road 21094 03-10-2016 11:02 AM
The Future of RC Racing (Your Opinions) rccarracer15 Nitro Off-Road 103 06-10-2011 09:25 PM
Bodies for sale, new, used & painted coastaltony R/C Items: For Sale/Trade 68 01-02-2007 03:45 PM
Belt Driven vs. Shaft Driven Allen Sondej Electric On-Road 69 11-05-2004 07:51 PM
