Old 06-08-2011, 01:21 PM   #2461
yeah ive seen the abc hobby bodies but i like the detail of the hpi bodies and would love a mini version of my car
current line up
traxxas tmaxx pro .15
traxxas tmaxx pro .15 converted to 2,5
traxxas jato
hpi cup racer 13.5 turn brushless
bonvo is offline   Reply With Quote
Old 06-08-2011, 01:25 PM   #2462
eR1c's Avatar
..i hear ya.
by the way, i've started racing my CR'r competively. Having a lot of fun, ..when you race you really notice what your car needs and what needs to be adjusted. I've totally gone through my suspension set up to get it just right. -also experimenting w/ new tires for better grip.
eR1c is offline   Reply With Quote
Old 06-08-2011, 02:40 PM   #2463
how do you get your gear mesh right and keep it that way or is it somthing that has to be constantly rechecked?
current line up
traxxas jato
Old 06-08-2011, 05:16 PM   #2464
eR1c's Avatar
I check it after every race day, ...as racing seems to be pretty hard on cars. I can't really describe how to do it, it's a feel ....you just kind of set it tight then loosen slightly ...i spin the wheels w/ my fingers to make sure there isn't too much resistance on the gears ...i am going for something that turns freely, yet not too loose not too tight. hard to describe, not sure there is a way to measure it. More of a feel.
Old 06-08-2011, 05:19 PM   #2465
Suspended
Trader Rating: 86 (100%+)
i think cup racer manual have a good way to set gear mesh by a piece of paper. check it out
littlealex is offline   Reply With Quote
Old 06-08-2011, 06:12 PM   #2466
eR1c's Avatar
..i don't care for the paper method (personally).
a lot of manuals recommend that method ...its never worked well for me, usually the mesh is too tight when i do it w/ the paper
Old 06-08-2011, 06:17 PM   #2467
Trader Rating: 20 (100%+)
Me too. The paper mesh method never works. My rule of thumb is get the mesh tight then back it off untill the spur can roack back n forth on the pinion.
goots is offline   Reply With Quote
Old 06-09-2011, 01:02 AM   #2468
alrighty its pic time heres my cup racer with no body
the z body my gf did all the masking and paint work she chose the colors as well this will be the indoor body
some good pics of my 510 body repaint these pics show the color a little better
current line up
traxxas jato
Old 06-09-2011, 01:29 AM   #2469
Suspended
THIS:
Forget the paper and do it by feel, mesh them together, tighten off one screw, turn the spur checking for any tight spots, if you find a tight spot, unscrew and remesh with a little more gap, rinse and repeat until you get a mesh that moves freely without any obvious tight or loose spots, its a feel thing.
RogerDaShrubber is offline   Reply With Quote
Old 06-09-2011, 05:44 AM   #2470
Originally Posted by daign View Post
It works fantastic. Body posts suck. Thanks!
Thanks!. I've done it on nearly every car/crawler I've built. The unimog even holds up in bind situations where the tires are stretching the body.
You can use tin snips to cut hobby metal, then sand down the body posts, then apply the velcro, or use balsa. I couldn't find any more metal so I used balsa.
I stock up on body posts and prefer all my cars look scale.
Edit: White gorilla glue and black gorilla glue (for black backing paint) work great for sealing the velcro or metal to the post for extra srength, but I only found it necessary with my crawler. I can pick it up and swing it around.
Would you mind posting a photo of the underside of your unique body mounts?
I have the same body and really don't want to drill holes in it so I'm intrigued by how you've done it!
fritzzz is offline   Reply With Quote
Old 06-11-2011, 02:25 AM   #2471
i think i have my gear mesh handled
any one know of a trueno body that fits the cup racer? i know theres the levin but i want to make an initial D duplicate ad that requires a trueno body
current line up
traxxas jato
Old 06-11-2011, 04:35 AM   #2472
Suspended
Originally Posted by bonvo View Post
anyone know how i would get a body request to hpi? i would offer up my first born for a datsun 610 body
http://rchobbies3-px.rtrk.com.au/sto...ducts_id=53986
I think that is close to what you are looking for, unfortunately its in 162mm, not 190-200.
Old 06-11-2011, 05:12 AM   #2473
Trader Rating: 16 (100%+)
All the ABC bodies for the M series cars are 210mm wheel base. so that Datsun should fit. I belieze the 162 is the track width.
brettweir78 is offline   Reply With Quote
Old 06-11-2011, 08:12 AM   #2474
eR1c's Avatar
so I totally ruined my last body at the last race, ..during the practice session some stadium trucks ran over my car. Lesson learned, -never practice while stadium trucks on on the track. My body literally got destroyed, paint chipped off and somehow the front had a huge crack/tear in the plastic. So i re-painted a new body the same as the last one. This color scheme is my trademark, ...people recognize my car by it when I race.
Also experimenting w/ some Team Associated treaded tires as opposed to the slicks that HPI makes for our cars ...i'll see how these perform at next weeks race.
Old 06-11-2011, 08:13 AM   #2475
eR1c's Avatar
...the class I run in requires a stock silver can motor (during the off season I put my 17 turn back in).
Tamiya TRF415 JDM_DOHC_SiR Electric On-Road 21094 03-10-2016 11:02 AM
The Future of RC Racing (Your Opinions) rccarracer15 Nitro Off-Road 103 06-10-2011 09:25 PM
Bodies for sale, new, used & painted coastaltony R/C Items: For Sale/Trade 68 01-02-2007 03:45 PM
Belt Driven vs. Shaft Driven Allen Sondej Electric On-Road 69 11-05-2004 07:51 PM
