HPI Cup Racer 1M >
HPI Cup Racer 1M
Like Tree2Likes
HPI Cup Racer 1M
Old 04-17-2009, 09:05 AM
  #226
fordmike65's Avatar
Trader Rating: 28 (97%+)
Originally Posted by Bodywerx_rc
I got my body all cut out last night and I will be painting soon.
I have bought ABC bodies in the past. I would pay the price for them over Tamiya now. You get the headlight buckets as a bonus.
I use the alcad chrome, and I love it. I have heard the Spaz-stix really stinks.(but good product)
X2 on the detail & LED buckets!! I have used the Spaz-stix with a brush as well for small detail work. It takes a few applications though 'cuz it doesn't stick too well.In the end it is awesome.
fordmike65 is offline
Old 04-17-2009, 09:22 AM
  #227
freeway's Avatar
Originally Posted by Jdm510
the only thing i dont like about the ABC bodys is for the price you would think they would have detail chrome bumpers like the Hpi kit... and not the lexan ones you have to paint (btw anyone know whats best to use to try and make the lexan look chrome???)
And some one answer me this how dose that grille go together on the 510??? i still not have even touched my ABC (bre 510) body cuz its pretty much got me freaked out any one know where to get some instructions in USDM writing not JDM
the grill would use double sided tape imo, been looking at it yesterday trying to cipher the instructions vs the 3 pieces included in the pack. i think you set it up either circuit style or street, ill see how it goes together and post it up, need to do the electronics.
freeway is offline
Old 04-17-2009, 09:28 AM
  #228
MikeR's Avatar
Trader Rating: 15 (100%+)
Originally Posted by JS
Has anyone figured out how to (easily) adjust the front camber settings?
I contacted HPI and they said that you have to take out the ball end from the upper arm and insert washers to adjust the camber.
It will be difficult to make adjustments while you are on the track with this setup....
Obviously it's was designed to be more durable and easier to keep aligned which is way more important any way.
Soooo glad there are no purple anodized parts.
MikeR is offline
Old 04-17-2009, 09:56 AM
  #229
JS
JS's Avatar
Trader Rating: 70 (100%+)
That's true, MikeR.
Come to think of it, after dialing in the suspension you will rarely make any more adjustments.
I still have to install the ESC and Radio. Can't wait to get it out on the track...
JS is offline
Old 04-17-2009, 12:07 PM
  #230
besure to take pics of the process...
yeah the light buckets are cool.... but dose that make up for the FAT mold lines that run threw the (510) body???????
idk when i opend my ABC kit i was pretty disopointed....
i hope i dont feel the same when my HPI kit gets here
Jdm510 is offline
Old 04-17-2009, 12:50 PM
  #231
rai913's Avatar
What size is the battery compartments? Are we limited to 3200 lipos? Will a 5000 hardcase lipo fit? Dimensions 24.5mm x 47mm x 136mm
thanks in advance
Ryan
rai913 is offline
Old 04-17-2009, 04:00 PM
  #232
Default Abc bodys on cup racer
if you got it post it
Jdm510 is offline
Old 04-17-2009, 07:37 PM
  #233
Chiefy 707's Avatar
thanks in advance
Ryan
I replied on the RC tech forums but your larger lipo battery should fit. You just dont use the cage or the cradle for mounting larger lipos.
Chiefy 707 is offline
Old 04-17-2009, 08:28 PM
  #234
freeway's Avatar
heres the ABC TE27 levin got bored waiting so i just painted it up, fits perfect need to do the stickerupper to make it look fast/LOL
freeway is offline
Old 04-18-2009, 01:06 AM
  #235
cannon's Avatar
Trader Rating: 35 (100%+)
Was building a Cup Racer and am very disappointed ... large binding poiint in the front gearbox
And the rear crown gear sitting on a single bearing wobbles causing more binding.
This kit looks about as bad as the Switch. The Switch has serious binding issues as well
cannon is offline
Old 04-18-2009, 01:25 AM
  #236
Trader Rating: 76 (100%+)
This want be a prob once the motor plate is installed? shouldnt have any issues
addicted is offline
Old 04-18-2009, 08:43 AM
  #237
Big Daddy Cool's Avatar
That's right! For larger lipos, see attached pic for mounting. Make sure to file and CA the fiberglass parts where the tapes rub through. There is still a lot of space for larger capacity packs. I installed an Orion 3600 lipo and the battery slot can still accommodate much thicker (higher capacity) lipos as long as the overall length pf the pack is nearly the same.
Attached Thumbnails HPI Cup Racer 1M-cupracer02.jpg   HPI Cup Racer 1M-cupracer01.jpg
Big Daddy Cool is offline
Old 04-18-2009, 05:08 PM
  #238
freeway's Avatar
a orion 5000mah hardcase lipo fit , i like how HPI included the different battery holder options and this particular one is attached by screws and locknuts. dont mind the wiring and masking tape since its just a rush install so i could run it today, will be going back to clean up the wiring and cut the body post. so far i like how its behaving with the 4600kv motor on stock gearing.
freeway is offline
Old 04-18-2009, 09:54 PM
  #239
rai913's Avatar
Thanks for all the pics with batteries. I'll be picking mine up tomorrow (hope they still have it in stock). I just wanted to be sure i could fit all my batts. Any build recommendations or tips?
Ryan
rai913 is offline
Old 04-18-2009, 09:58 PM
  #240
freeway's Avatar
^^^ had a tough time doing the shocks due to the tiny e clips for the shafts, aside from that its good.
freeway is offline
