Old 04-27-2011, 11:40 AM   #2326
Originally Posted by giantzack View Post
took the cr out for a rip today and it was the first nice day since i bought it. although im having problems in the corners under deceleration it likes to come out backwarrds im thinking it has something to do with the brushless system in it. to much motor breaking?
any other suggestions?
Try:
Standing the front shocks more upright if you are using the optional front shock tower (outer holes in the tower).
Reduce rear droop.
Run a stiffer spring in the front.
Use thicker shock oil in the front shocks.
The drag brake in the motor can make a setup issue more apparent but should not be considered the cause of you handling issue. I'm using 40% drag brake in my CR.
Sydewynder is offline   Reply With Quote
Old 04-27-2011, 11:58 AM   #2327
KING_PALM's Avatar
Send a message via AIM to KING_PALM
Originally Posted by Fractured View Post
Thanks I appreciate it.
Novak havok w/ 13.5 censored brushless
duratrax 4000 2s 25c
Hitec cheapo servo.
everything else is pretty much setup to the instructions..
G-TROOP | OC/RC | CALRACEWAY | WC/RC
FUTABA | NOVAK NATION
22 | B44.1
KING_PALM is offline   Reply With Quote
Old 04-28-2011, 10:45 AM   #2328
KING_PALM's Avatar
I am having issues with my Spur gear coming loose. the hun nut keeps backing out. any suggestions on what i can do to stop this?
22 | B44.1
Old 04-28-2011, 11:48 AM   #2329
Use a little blue thread lock on the threads and use the plastic tool to tighten the metal collar/nut onto the metal drive cup.
Old 04-28-2011, 01:36 PM   #2330
KING_PALM's Avatar
trying it now...
edit: i didnt build my car so i had no idea that the gear hub was metal.. that what happens when you buy a display from the LHS
22 | B44.1
Old 04-28-2011, 07:02 PM   #2331
love my cup racer but I am having a hard time keeping it simply as a basher/drifter when i have a cyclone tc for drifting as well....
more rim options for my 1/10.
shinjari is offline   Reply With Quote
Old 04-29-2011, 05:07 AM   #2332
I've just picked up the Porsche kit and am trying to work out a motor / ESC combo and was thinking of one of the XERUN set-ups.
Reading through here there are lots of different motor / ESC combos but the general view seems to be 17.5T is about right.
Would something like this be OK?
XERUN 17.5T Combo-XS5A Xtreme 60A ESC for Stock Racing
http://cgi.ebay.com.au/XERUN-17-5T-C...item41591429ed
Or do you reckon the ESC is a bit under-done?
fritzzz is offline   Reply With Quote
Old 04-29-2011, 05:51 PM   #2333
Suspended
Hey guys, I was wondering who else makes spur gears for the cup racer? I already have the 65-67 spur gears from HPI And would like something smaller to gear higher on the pinion.
s.l.c. is offline   Reply With Quote
Old 04-30-2011, 02:38 PM   #2334
Does anybody have any links for a good wheel and tire combo for some parking lot bashing? I want something that has good grip. The drift tires at the parking lot by my house make the car almost un-driveable. Its fun to drift it around for a while, but its very difficult to keep the car straight.
I saw some tamiya super grip "60d" tires on ebay. Will those work?
I would prefer to purchase the wheels and tires form an online store instead of ebay.
I also want to go with the tamiya "m" chassis wheels.
Thanks.
Fractured is offline   Reply With Quote
Old 05-01-2011, 03:15 PM   #2335
Trader Rating: 32 (97%+)
Any aluminum options for the front diff input where the center drive shaft attaches to the front diff pinion gear. The 3 pin thing sheered off. Any other options aside from the stock HPI one?
Hotshot Rc Raceway
kikcaffine is offline   Reply With Quote
Old 05-01-2011, 03:28 PM   #2336
team green's Avatar
Go to exotekracing.com they make one....
I will never go back to brushed motors or NIMH's!!!!
Awesomatix EVO2
Tamiya TA07 Pro
Associated B6
TLR 22-4 2.0
team green is offline   Reply With Quote
Old 05-02-2011, 10:42 AM   #2337
MikeR's Avatar
Trader Rating: 15 (100%+)
Originally Posted by littlealex View Post
miker, is it possible to post setup? its short wheel base right?
also what motor and esc, tires are you using?
i m trying to get my cr ready for outdoor season
Hi Guys,
Our instruction sheet now has our base race set up. It is attached below;
www.exotekracing.com ☆ASSOCIATED☆DURANGO☆HPI☆HB RACING☆KYOSHO☆LOSI/TLR☆SERPENT☆TAMIYA☆XRAY☆
A picture with your post, when trouble shooting, will probably get more rctech help than without...
Last edited by MikeR; 05-02-2011 at 03:02 PM. Reason: Thanks sydewynder for catching that! ;)
MikeR is offline   Reply With Quote
Old 05-02-2011, 10:49 AM   #2338
superspeed's Avatar
Default budget
It seems the cup racer chassis is a hard-sell at LHS. Once a while, there would be someone buying a Tamiya m chassis kit but cup racer w/ 240Z body has been sitting on the shelf for 2 years.
superspeed is offline   Reply With Quote
Old 05-02-2011, 10:50 AM   #2339
superspeed's Avatar
Originally Posted by MikeR View Post
Hi Guys,
price on this exotech chassis ?
Old 05-02-2011, 10:53 AM   #2340
Hi Guys,
MikeR
Are the springs correct in the instruction flyer? Isn't pinks harder than the blues? Shouldn't their positions be swapped?
Thanks for including the base setup.
Tamiya TRF415 JDM_DOHC_SiR Electric On-Road 21094 03-10-2016 11:02 AM
The Future of RC Racing (Your Opinions) rccarracer15 Nitro Off-Road 103 06-10-2011 09:25 PM
Bodies for sale, new, used & painted coastaltony R/C Items: For Sale/Trade 68 01-02-2007 03:45 PM
Belt Driven vs. Shaft Driven Allen Sondej Electric On-Road 69 11-05-2004 07:51 PM
