Old 01-14-2011, 01:37 AM   #2116
ericbeenorcal's Avatar
Default carpet track
Originally Posted by JDM CR View Post
Thank! eRc1, I'm trying to find a track around salinas, cal, Theres on in gilroy but they have wierd hours, the next closest one is 1 hr away, so for know I'll drift it around the parking lot.
if ur down for some indoor carpet drifting theres one in san jose @sheldons hobbies(sheldonshobbies.com) its free theres also an indoor rock crawler course and the hours are 10-7pm
BocaBearingdePeppo
ericbeenorcal is offline   Reply With Quote
Old 01-14-2011, 04:42 AM   #2117
shanty140's Avatar
Originally Posted by littlealex View Post
please help, my cup racer spins out in corners easily, not sure whats wrong of it
i m using sweep 40 tires on mid high traction carpet, 40 weight shock oil, pink front/black rear spring. diff is adjusted right.
any help would be appreciated
If you post your setup it would make it a lot more easier to help you out.
Race Vehicles:
Mugen MBX6T - Ninja JX.21 with EB Mods Headbutton, O.S. 2060 Pipe, DX3R, Hitec 7955TG Servos on LiPo
HPI Cup Racer - Murfdogg Synergy 17.5, Tekin RS Pro, 2S 40C 4200mah, DX3R, Savx SC-1251MG Servo
shanty140 is offline   Reply With Quote
Old 01-14-2011, 08:48 AM   #2118
egaus's Avatar
I was pleasantly surprised how easy it was to install the front Exotek alloy shaft-drive cup. The Cup Racer is not really that difficult to work on, contrary to some reports I've read.
For anyone who is hesitating to install one, it's a matter of removing about seven screws, popping the front diff assembly out and screwing it on. Hopefully you did not use red loctite on the screw holding in the stock plastic part. (I did not -- use blue). Took me all of a half-hour. Well worth it I think. Now I won't worry when I swap out my 17.5t for a 13.5t on 32t pinion.
e
egaus is offline   Reply With Quote
Old 01-14-2011, 06:33 PM   #2119
Suspended
Trader Rating: 86 (100%+)
i follow the instruction manual to build the car.
its using exotek chassis, exotek front cup, exotek turn buckle
hot racing alu cups.
i m assuming either something wrong with droop or shock.
how much droop and what shock oil do you guys use?
littlealex is offline   Reply With Quote
Old 01-15-2011, 12:38 AM   #2120
MikeR's Avatar
Trader Rating: 15 (100%+)
What tire sauce are you using? What's the room temperature? Is it spinning going into the corner or coming out while getting on the gas or both?
www.exotekracing.com ☆ASSOCIATED☆DURANGO☆HPI☆HB RACING☆KYOSHO☆LOSI/TLR☆SERPENT☆TAMIYA☆XRAY☆
A picture with your post, when trouble shooting, will probably get more rctech help than without...
MikeR is offline   Reply With Quote
Old 01-15-2011, 03:09 AM   #2121
shanty140's Avatar
I was wondering what wheels are on the Cup Racer in the link below? It's from Exotek's website on there CRX chassis page. Does anyone have a link to where I can purchase them from. They look sweet.
http://exotekracing.com/EXOTEK_NEWS/.../7/21_CRX.html
Race Vehicles:
Old 01-15-2011, 03:17 AM   #2122
[[john]]'s Avatar
Trader Rating: 24 (100%+)
On the bottom of the page is says:
SHOWN WITH ABC HOBBY WHEELS AND TIRES
[[john]] is offline   Reply With Quote
Old 01-15-2011, 05:45 AM   #2123
shanty140's Avatar
Oh didn't see that. Thanks!
Race Vehicles:
Old 01-15-2011, 08:30 AM   #2124
Suspended
i m using jack the gripper, temp is about 25c, its spinning out in middle of corner.
Old 01-15-2011, 10:12 AM   #2125
MikeR's Avatar
Jack the gripper is really good. I want to say that your 40 tires are the culprit. You know that 40 means they are rated for 40c temperatures? If the track is 25c then the tires can not generate enough traction due to lack of heat build up. You want to find some cool weather tires for sure, something rated at 20-28. The 40's are more suited for outdoor hot asphalt use.
Assuming you have ride height that is not rubbing the carpet and front traction that is not too aggressive (try not saucing the front tires) that just might get you going.
Old 01-15-2011, 10:38 AM   #2126
Suspended
thanks mike, i will try softer tires
i have enough traction in front, just rear spin out very easily.
funny thing is it wasnt like this b4. it just happen last practice day
Old 01-15-2011, 12:26 PM   #2127
For something really easy try a softer spring in the back helped me out huge. Also make sure you have the correct toe blocks in the rear lower arms.
HPI Cup Racer
HPI Firestorm x 2
Associated SC10
Axial AX10 x 2
All Controlled By Futaba 3PM-X. All Powered By Castle Creations.
rbjeepthing is offline   Reply With Quote
Old 01-15-2011, 10:33 PM   #2128
san.'s Avatar
Trader Rating: 59 (100%+)
Originally Posted by YmeBP View Post
Hello everyone we are having a Cup racer event at our track and would like to welcome anyone who can make it!
This class has been growing like wild fire at our track!! Details are on the race thread.
[old link here]
I'm also taking suggestion as to rules and such as it's our first cup event.
Exotek, Skyrocket racing and HPI are sponsors so far.
Any support you can give (setup information, track suggestions, tips etc) would be welcome, thanks!!
-Tory
http://www.mushroombowl.com/
Originally Posted by san. View Post
The first one was a great success. So Da' Bowl is doing it again!!
That's right, the 2nd Annual Cups @ Da' Bowl is happening on January 22nd, 2011.
Mushroom Bowl R/C Speedway
960 West Cypress Street
Kennett Square, PA 19348
(610) 444-4221
Here's the Event Thread for further detail:
2nd Ann. Cups at Da' Bowl - Kennett Sq, PA Jan 22nd, 2011
7 more days!
Awesomatix USA||Roche RC USA||Sanwa
san. is offline   Reply With Quote
Old 01-16-2011, 07:02 PM   #2129
Sorry for the crappy cell phone pics but here is my new body for the Cup Racer!
HPI Cup Racer 1M-163801_493334002357_506397357_6260191_3819867_n.jpg   HPI Cup Racer 1M-164850_493334682357_506397357_6260196_3102534_n.jpg   HPI Cup Racer 1M-167248_493334422357_506397357_6260195_337048_n.jpg
HPI Cup Racer
HPI Firestorm x 2
Associated SC10
Axial AX10 x 2
Old 01-16-2011, 08:29 PM   #2130
shanty140's Avatar
Looks good, I am going to be trying a Datsun 510 body next. Depending on how that goes the Civic body will be my next option.
Race Vehicles:
Tamiya TRF415 JDM_DOHC_SiR Electric On-Road 21094 03-10-2016 11:02 AM
The Future of RC Racing (Your Opinions) rccarracer15 Nitro Off-Road 103 06-10-2011 09:25 PM
Bodies for sale, new, used & painted coastaltony R/C Items: For Sale/Trade 68 01-02-2007 03:45 PM
Belt Driven vs. Shaft Driven Allen Sondej Electric On-Road 69 11-05-2004 07:51 PM
