Old 12-24-2010, 10:01 AM   #2056
egaus's Avatar
I have some of those, I was going to install them but ran into the same problem you have. The kit screws don't even fit. Good job, Not-Racing.
e
egaus is offline   Reply With Quote
Old 12-24-2010, 11:16 AM   #2057
if anyone can help us out..much appreciated!
rsx2crazy is offline   Reply With Quote
Old 12-24-2010, 12:54 PM   #2058
Manny's Avatar
Default 3mm tap
You can either return them and get new ones or pick up a tap and wrench from the local hardware store and tap them yourself. A 3mm tap is a useful tool to have anyway. I was lucky and all of mine were tapped correctly.
I really like the HR metal axle cups. Coupled with the metal drive hexes they are really smooth and don't bind when you tighten the wheel screw.
Manny is offline   Reply With Quote
Old 12-26-2010, 10:31 AM   #2059
Default Got to have upgrades
My son just got a Cup Racer drift model for Christmas. What are the must have upgrades for this model? thanx in advance.
jmaverick is offline   Reply With Quote
Old 12-26-2010, 08:31 PM   #2060
eR1c's Avatar
The rims are TopCad that locally sell in Hong Kong.
-WOW, went to the site, ...those are nice rims. I ..am going to see if I can hunt them down somewhere (flying to Hong Kong for some rims isn't in the budget )
Congrats! Personally I think the car is pretty solid. I upgraded my shocks, turnbuckle, and got the disc brake kit (purely bling). If you plan on running the car non competively and with a brushed 19 turn or higher (slower) motor I think you'll be okay as it is stock out of the box. I've been running a 17 turned brushed, ...the pinion gear kept slipping but a little loctite solved that. I am now thinking of racing this car competively (not totally sure which class ...if I go for an open class i'll get the exotec Carbon Fiber body, -for better handling and will swith to brushless, etc..). ...yet not sure that's the route I want to go w/ this one.
eR1c is offline   Reply With Quote
Old 12-26-2010, 08:34 PM   #2061
eR1c's Avatar
..and here are two updated photos of my Porsche CR. -w/ lights!
...now just need to paint the driver and install w/ the dash kit I am creating. ..I may also include a roll cage for the back seat area (my buddy has a mini tube bender he's been using for crawlers).
Old 12-27-2010, 12:08 AM   #2062
First one should be:
Exotek front alloy cup for the center shaft.
http://www.exotekracing.com/EXOTEK_N...DRIVE_CUP.html
Sydewynder is offline   Reply With Quote
Old 12-27-2010, 10:47 AM   #2063
eR1c's Avatar
..mine haven't snapped yet, but I do hear this is the weak link on our CR'ers. I'll replace mine if/once they break, until then I haven't had an issue. The exotek does seem like a much better design, ..I don't like how the nut has to seat in the cup w/ the stock design. Exotek does make GREAT products, can't go wrong w/ anything they sell.
Old 12-27-2010, 02:22 PM   #2064
egaus's Avatar
I'm looking to wring out a little more speed from my CR running a Novak SS Pro 17.5t brushless. I currently run the stock gearing and was looking online for a pinion with higher tooth count than 30.
I found:
ssl-stormerhobbies.com/cgi-bin/seekpart.pl?src=ns&pn=HPI6931 (31T 48P)
HPI has:
hpiracing.com/products/en/6932
Are there any other options for pinions that fit the CR and 540 size motors?
The HPI link above does not list the 6932 pinion as being a part for the CR.
e
Old 12-27-2010, 08:16 PM   #2065
san.'s Avatar
Trader Rating: 59 (100%+)
Originally Posted by YmeBP View Post
Hello everyone we are having a Cup racer event at our track and would like to welcome anyone who can make it!
This class has been growing like wild fire at our track!! Details are on the race thread.
[old link here]
I'm also taking suggestion as to rules and such as it's our first cup event.
Exotek, Skyrocket racing and HPI are sponsors so far.
Any support you can give (setup information, track suggestions, tips etc) would be welcome, thanks!!
-Tory
http://www.mushroombowl.com/
The first one was a great success. So Da' Bowl is doing it again!!
That's right, the 2nd Annual Cups @ Da' Bowl is happening on January 22nd, 2011.
Mushroom Bowl R/C Speedway
960 West Cypress Street
Kennett Square, PA 19348
(610) 444-4221
Here's the Event Thread for further detail:
2nd Ann. Cups at Da' Bowl - Kennett Sq, PA Jan 22nd, 2011
Awesomatix USA||Roche RC USA||Sanwa
san. is offline   Reply With Quote
Old 12-28-2010, 12:46 PM   #2066
Suspended
Originally Posted by RockDragon View Post
Hi guys...
during I'm waiting for the new BMW 2002 body arrives soon. I just tried some thing different with the body for mu CR.
It's a classic Mini Cooper body but dresses as a member of the Team orange's drift car.
Well! it doesn't look so bad, does it?
liking the flares on the mini :thumbsup:
s.l.c. is offline   Reply With Quote
Old 12-28-2010, 10:37 PM   #2067
egaus's Avatar
That mini is awesome looking. What kind of wheels/tires are those?
e
Old 12-29-2010, 12:43 PM   #2068
eR1c's Avatar
..look in the previous posts at the top of page and end of previous page, -there is a link to them.
apparently you can adjust the offset on each rim.
Old 12-29-2010, 05:42 PM   #2069
I wouldn't wait until the 3 fingers on the plastic cup snaps.
These fingers lock into the three in the metal bevel gear holding the gear still while you grab the 2 flat spots on the cup and tighten the screw. If the fingers break the gear will spin when you turn the screw. Adding to the problem is HPI said to use RED threadlock (permanent) on the screw.
You can use something to jam the gear but its gonna be a PITA.
Old 12-29-2010, 05:51 PM   #2070
I found:
HPI has:
e
Per the manual HPI lists part nos. for up a 35t pinion but the chart gives ratios up to a 39t pinion.
Just don't overheat your motor.
Tamiya TRF415 JDM_DOHC_SiR Electric On-Road 21094 03-10-2016 11:02 AM
The Future of RC Racing (Your Opinions) rccarracer15 Nitro Off-Road 103 06-10-2011 09:25 PM
Bodies for sale, new, used & painted coastaltony R/C Items: For Sale/Trade 68 01-02-2007 03:45 PM
Belt Driven vs. Shaft Driven Allen Sondej Electric On-Road 69 11-05-2004 07:51 PM
