Old 04-10-2009, 12:50 PM   #181
freeway's Avatar
picked-up a kit and some ABC bodies, the LHS only got the drift version, didnt want it since i already got a 10th scale for drift but its really hard to refuse this thing.
the ABC body could be used with the short wheelbase so ill see how it goes since one of them (corolla levin) is new and gotta have the 510.
and im not allowed to post pics yet
freeway is offline   Reply With Quote
Old 04-11-2009, 04:25 PM   #182
Big Daddy Cool's Avatar
Trader Rating: 15 (100%+)
Send a message via ICQ to Big Daddy Cool
Originally Posted by bigb11 View Post
Big Daddy Cool, which way did you put your front shocks?
Inboard, Laydown. Seems to offer pretty good damping. Different spring rate from rear.
Big Daddy Cool is offline   Reply With Quote
Old 04-11-2009, 04:35 PM   #183
bigb11's Avatar
Trader Rating: 59 (100%+)
Send a message via AIM to bigb11
I have the 240Z body and want to put shocks up/down.
PHAT QUAD RACING, HPI/HOTBODIES, RATZAS, DARKSIDE MOTOR SPORTS, PARMA, Brown Engineering, ROBITRONICS, RC AMERICA, PANTHER, TEKIN, TEAM HOLY ROLLER, Rev Tech/Epic, RC AFRICA, HITEC www.browneng.org, DE wheels
bigb11 is offline   Reply With Quote
Old 04-11-2009, 06:20 PM   #184
Default Hpi Cup racer motor/esc, which is best for brushless/
I have about finished my Cup racer build.
Before I purchased the kit I called HPI and asked what brushless setup would be best.
I was told a Castle mamba Max with a 5700 motor. When I tried to install the motor I noticed I couldn't get the gears to mesh with an 18 tooth pinion gear.
I called castle and asked about the gearing for the cup racer, and they said they would contact HPI.
I called HPI myself and was told the Mamba system will not work in the cup racer!
Now I was quite mad after blowing $215 on the mamba system as you can imagine.
It turns out after many phone calls to HPI, the cup racer can only handle a 19 turn brushed or equivalent brushless motor.
I have researched this issue and it seems LRP and Novak make such a setup.
I am really thinking of going with the Novak Havoc 17.5 esc/ motor combo.
Is this a good choice?
tc5basher is offline   Reply With Quote
Old 04-12-2009, 12:53 AM   #185
Xtant3150c's Avatar
I would be pissed at the shop that sold you the MM5700 without telling you anything.
But anyways. The Novak Havoc 17.5 should work fine in the Cup Racer. If you want more speed you could go with the 13.5 it will put you on the edge as far as the supposed 19t motor limit.
space for rent
Xtant3150c is offline   Reply With Quote
Old 04-12-2009, 01:10 AM   #186
Dan
Dan's Avatar
Trader Rating: 45 (100%+)
What is the stock gearing on the Cup Racer?
I'm pretty sure the Cup Racer can handle more than a 19T durability wise, but would make it tough to drive I bet.
Dan is offline   Reply With Quote
Old 04-12-2009, 06:01 AM   #187
k_bojar's Avatar
Trader Rating: 30 (100%+)
Send a message via ICQ to k_bojar Send a message via AIM to k_bojar
unless I'm mistaken, 99% of all BL motors have multiple mounting positions - so it just a matter of trying to find the correct set of holes
You can throw a 2.5 motor in there and it will fit - gearing aside - so I'm a little confused at what the problem you had with HPI and Castle...
Bodies By Bean | Team Belly
k_bojar is offline   Reply With Quote
Old 04-12-2009, 06:21 AM   #188
I am confused too. A good 19T is more like a 10.5BL and WAY faster than a 17.5 unless you have an HPI 19T .
In 1/12 4 cell a 19T is noticably faster than a 13.5 and would dust a 17.5 hands down, only a 10.5 can keep up.
AreCee is offline   Reply With Quote
Old 04-12-2009, 06:45 AM   #189
Trader Rating: 52 (100%+)
Hey marvet, when and where is this Ray's challenge ?....i have my mini on order thru rich @ rampage already
rcracer1958 is offline   Reply With Quote
Old 04-12-2009, 06:51 AM   #190
k_bojar's Avatar
Ray Murray's Challenge is Aug 15th and 16 in Tunersville, NJ - at the local Nifty Fifty's
Old 04-12-2009, 08:21 AM   #191
Trader Rating: 76 (100%+)
Lay down Bigb11.
Ran mine today but used the same springs as rear. had more front hop than Easter Bunny Changed the front springs to the other pair provided and eliminate 95% of the problem. Think by changing the front shock oil to the next weight up will completely solve the issue.
The drive train after a few laps bedded in and was quieter than i expected.
Car suffered from quiet severe front push . but after some tire changes it was suffering from too much grip Grrr More track time and testing.
I was running an equivalent to a TZ21t Car was well undered gear
Over all car is quiet impressive with stock set-up . Obviously this does need to be taylored to suit individuals. The only let down was build time, I found the parts seemed to be just placed in any bag/ order they felt to put them in.
addicted is offline   Reply With Quote
Old 04-12-2009, 08:34 AM   #192
freeway's Avatar
^^^ +1 on parts being all over the place/LOL, only managed to do the front and rear diffs into the chassis. i will try to put a MM4600kv in there and see if it fits and let you guys know. and i set it up for laydown in front.
Old 04-12-2009, 11:15 AM   #193
Chiefy 707's Avatar
Just wondering what motor/esc combos are you guys using? As well as battery packs too.
Late last year I got back into the hobby but focused on nitro on-road. I couldn't help but notice how much the electric scene has changed with the whole brushless lipo thing, yikes!
I'll be getting my Cup Racer tuesday but I still haven't decided on esc/motor/battery. My car will probably be doing double duty as 'once a month racecar' and 'while I'm at work bashing drifter'.
Right now I'm leaning more toward some sort of BL 17.5 setup. But crap man, I noticed the prices of ESC's have basically doubled from the last time I bought one. Being the relative noob, I have a couple of questions: is it true the Tekin RS requires a PC for setup? What ESC's work with both brushless and brushed as well as stock and mod?
Anyways thanks for any help!
"It looks like a [insert car here]. It's just another [insert car here] clone!"
"Why did [insert manufacturer here] go with such a radical design? [insert manufacturer here] needs to stick with what works!" Shhhh, please.
HB/LRP/KO Propo/Protek/Associated/Tekno
Chiefy 707 is offline   Reply With Quote
Old 04-12-2009, 01:01 PM   #194
Here's the issue: The cup racer uses a "ring" which you bolt to the motor.
According to HPI the smallest pinion you can use is a 25 tooth. The available spur gears are 65 and 67 only! Castle reccomends a 18 tooth pinion for my set up, but it won't mesh with such a small spur. You need more like a 87 tooth spur gear. So in order to go brushless i am stuck with a Noval or LRP setup, which is ok, but I need to figure out which motor will work best using a65 tooth spur and any pinion form 25 tooth to 39 tooth.
I really am leanig toward the Novak Havoc system becuase of price (its $80 cheaper). So the real question is which motor to get 21.5,17.5,15,13.5 or?
Old 04-12-2009, 01:06 PM   #195
I too am trying to figure out which type of motor.
Just for your info a Mamba max will not work.
The Novak Havoc 17.5 motor/esc combo is where I think I am going. Price is great, only $149. I would go with SPc lipos for batteries.
HPI says a 5000 Mah 7.4 will fit. I just tried my maxamps 6000Mah 7.4 and it too fit, but I think I need to get hard case batteries for the Cup Racer.
Tamiya TRF415 JDM_DOHC_SiR Electric On-Road 21094 03-10-2016 11:02 AM
The Future of RC Racing (Your Opinions) rccarracer15 Nitro Off-Road 103 06-10-2011 09:25 PM
Bodies for sale, new, used & painted coastaltony R/C Items: For Sale/Trade 68 01-02-2007 03:45 PM
Belt Driven vs. Shaft Driven Allen Sondej Electric On-Road 69 11-05-2004 07:51 PM
