Old 10-17-2010, 05:44 AM   #1861
k_bojar's Avatar
Trader Rating: 30 (100%+)
Send a message via ICQ to k_bojar Send a message via AIM to k_bojar
Originally Posted by eR1c View Post
ARGGGHHHH,
started building my CR'er this evening ...w/ 2 small kids and wife I don't get much time to myself ...tonight was my night. I am totally missing 2 plastic parts from the plastics bag. One part is the entire battery tree the other is the shock parts set. ...totally missing. Tonight was the first time I opened the box. I was very methodical in looking over every page of the directions and noticed that two part trees/bags are totally missing. Also my red liquid locking solution containter cap was not tighten and the liquid is all over the inside of that bag. The outer box of my CR'er is in perfect condition, so this must have happened before it was all packaged. -totally frustrating as now I have to call HPI for replacement parts. Funny, thing is that I had to send my original receipt in for the current $25 discount they are offering. So I have no proof I bought this kit!
The two parts trees are cheap, about $10 total, so I may just see if I can get them from some 3rd party and will probably get here quicker.
okay, little frustrated!
(I did make it out to a race today w/ my 4year old boy ...we raced my 1/18th scale street car). -so was still a good day!
shoot me a pm on the parts you are misssing, i might be able to help you out
Bodies By Bean | Team Belly
k_bojar is offline   Reply With Quote
Old 10-17-2010, 10:43 AM   #1862
eR1c's Avatar
Thanks for the offer to help me out w/ the missing parts.
I actually already ordered them through another co' (w/ some upgrade parts).
-they were about $10 for the two missing plastic parts trees.
eR1c is offline   Reply With Quote
Old 10-18-2010, 06:49 PM   #1863
eR1c's Avatar
Okay, got another question ...
...as I am looking to get a Lipo battery and brushless setup, i am noticing that none of the recievers out there seem to accept lipo's as a battery source. Can I get a voltage regulator for the reciever (to connect to the lipo battery) ..and then use lipo w/ any reciever? I think the voltage regulators are called BEC's or something? ..thanks
Old 10-18-2010, 06:54 PM   #1864
eR1c's Avatar
please delete this post (somehow my post was submitted 2x)
Old 10-18-2010, 07:14 PM   #1865
k_bojar's Avatar
99% of all esc have a built in BEC that will 'down-grade' the voltage from the 7.4 lipo to a usable voltage (don't know the exact figure off the top of my head)...
the only time you run into issues with lipo, receivers and voltage is when you are running a 1s pack with a 2s receiver pack - this is when you need a regulator or something along those lines...this would be for 12th scale, WGT or oval...
but if you are using 2s or 3s pack, you'll be fine with the voltage that the esc is sending to the receiver
Old 10-18-2010, 09:48 PM   #1866
eR1c's Avatar
Thankyou for your help w/ this! -that's what I needed to know.
Old 10-19-2010, 06:25 AM   #1867
I RAN THIS PAST WEEKEND WITH MIXED RESULTS...
We run a TCS class, and we wanted to see how the CR holds up with them.
Jack the Gripper traction compound all around. This is what my setup is:
Front:
* Pink springs, 50wt oil, option shocks laydown
* Kickup (track bumpy)
* 0 Toe
* 1 degree negative camber
* Gold swaybar
* 1 clip in front of upper arm 1 behind to set caster
* Stock rollcenter
* 5mm ride height
* Tamiya A Slicks w hard inserts
* had the stock gear diff without any springs
* Stock Droop
Rear:
* Blue springs, 40wt oil, option shock set on inner most hole on option tower
* No antisquat
* 3 degree toe-in
* 1.5 degree negative camber
* No swaybar
* Low roll center
* 5mm ride height
* Tamiya A slicks W hard inserts
* Ball diff adjusted to no slip
* Stock droop
It was VERY hard to drive, off the throttle in the corners was great as soon as I gas'd it it would pull hard into the boards.
Still working on setup for the next race, I am going to install a ball diff up front to see if it helps.
Bodywerx_rc is offline   Reply With Quote
Old 10-19-2010, 07:47 AM   #1868
Are there any alternatives to the Hot Racing axle cups yet? The Hot Racing ones are not threaded, so I'd rather not buy those.
Fabiz
Fabiz is offline   Reply With Quote
Old 10-19-2010, 07:52 AM   #1869
Fabiz
Mine are threaded....
Old 10-19-2010, 10:00 AM   #1870
k_bojar's Avatar
Fabiz
like bodywerz said, the Hot Racing ones are threaded...and i definitely know mine are - that's the biggest reason i went with them, so i could get rid of that damn locknut on the back of the stock pieces
Old 10-25-2010, 06:15 PM   #1871
Mine were not threaded, but I easily solved that with an M3x0.5 tap. There must be some issue with their manufacturing quality control. I recieved two complete pairs without threaded holes. Odd....
simple is offline   Reply With Quote
Old 10-25-2010, 06:30 PM   #1872
Default How to make adjustments
These might be some super noob questions.
How do you adjust rear toe in/out ? I know the camber in the rear is fairly easy by twisting the uper links in to close the gap.
How do you adjust the front toe/in out? Is it done via the akerman plates?
Right now I have some good camber on the rear, but I found adjusting camber on the front is fairly hard as its physically hard to twist the upper portion on the arms to make the shorter therfore giving it camber.
Thanks for any help, in advance.
ro.sniper is offline   Reply With Quote
Old 10-26-2010, 05:10 PM   #1873
eR1c's Avatar
I think I am running into a similar problem w/ the threaded or lack of threading on the tiny locknut. ..I barely tighted the differential gear w/ one of the tiny nuts and it stripped as I was tightening it. ...I looked at it under a magnifying glass. Looks like it only has about 2 or 3 threads of metal then plastic ..it's very fragile. I ordered a bag of them for about $2 off another site, ..yet thinking I am either going to have to put some locktite on it? or find a longer lock nut w/ more threads? -I don't trust that that tiny locknut is going to do the job. -especially w/ tension from the spring that is loaded in the diff housing.
Old 10-26-2010, 05:17 PM   #1874
Raman's Avatar
Trader Rating: 56 (100%+)
Drop a little ca glue in each hole and put screw back in.. works for me all the time..
Ps the spring in the diff pushes out against the side walls of diff case, not against the ring gear
TRF419X / Pulse 17.5, T.O.P Racing Sabre Mini AWD / Impact 21.5, M06 Pro / Impact 21.5, XV-01 Pro Rallye / Kinetic 17.5
Raman is offline   Reply With Quote
Old 10-29-2010, 05:58 AM   #1875
Do you guys increase ride height by lengthening the shocks?
Tamiya TRF415 JDM_DOHC_SiR Electric On-Road 21094 03-10-2016 11:02 AM
The Future of RC Racing (Your Opinions) rccarracer15 Nitro Off-Road 103 06-10-2011 09:25 PM
Bodies for sale, new, used & painted coastaltony R/C Items: For Sale/Trade 68 01-02-2007 03:45 PM
Belt Driven vs. Shaft Driven Allen Sondej Electric On-Road 69 11-05-2004 07:51 PM
