Old 09-21-2010, 06:44 PM   #1831
Originally Posted by Bodywerx_rc View Post
Morning guys,
I am looking to start racing my CR with our local minis. Any ideas for setups?
I am running on Carpet (ozite)
I have the basic kit with a few options
optional spur and pinion to match the M05
gear diffs without the springs F & R (much smoother)
HR Alum outdrives
R CF shock tower
Disc break set, but they are coming off to race.
I am running the laydown shocks, but I am going to switch them to the tower as I am running the CIVIC body.
Should I get the optional springs, and sway-bars?
I run on Ozite with foam tires and Jack the Gripper traction compound and this is what my setup is:
Front:
  • Pink springs, 55wt oil, option shocks laydown*
  • Kickup (track bumpy)
  • 0 Toe
  • 1 degree negative camber
  • Gold swaybar
  • 1 clip in front of upper arm 1 behind to set caster
  • Stock rollcenter
  • 5mm ride height
  • Orange/Double Pink foam tires
  • Ball diff adjusted to have no slip
  • Stock Droop
Rear:
  • Gold springs, 45wt oil, option shock set on inner most hole on option tower
  • No antisquat
  • 3 degree toe-in
  • 1.5 degree negative camber
  • No swaybar
  • Low roll center
  • 5mm ride height
  • Double Pink foams tires
  • Ball diff adjusted to no slip
  • Stock droop
*a little loose off power. Will try standup front shock tower.
Sydewynder is offline   Reply With Quote
Old 09-21-2010, 07:30 PM   #1832
tha Beast's Avatar
Trader Rating: 100 (99%+)
were did you get foam tires for the cup racer
REFLEXRACING
MIKES HOBBY SHOP PORTER TX
tha Beast is offline   Reply With Quote
Old 09-21-2010, 08:56 PM   #1833
I'm using cut down touring foams.
Old 09-22-2010, 06:19 AM   #1834
Front:
  • 0 Toe
  • Gold swaybar
  • Stock rollcenter
  • 5mm ride height
  • Stock Droop
Rear:
  • No antisquat
  • 3 degree toe-in
  • No swaybar
  • Low roll center
  • 5mm ride height
  • Stock droop
Thanks, I will try that.
Bodywerx_rc is offline   Reply With Quote
Old 09-22-2010, 03:37 PM   #1835
tha Beast's Avatar
oooooohh ok
REFLEXRACING
Old 09-24-2010, 10:02 AM   #1836
[QUOTE=Sydewynder;7961760]Look in the manual at page 20 at the pics in the middle of the page. See if part 85281 is installed and that the spur gear is installed properly on it (two of the holes in the gear needs to fit onto the two nibs on part 85281). Make sure part 86219 is tight on the spur gear.
THANKS FOR THE HELP GUYS, IT WAS THE COLLAR THAT THREADS ONTO THE DRIVE SHAFT CUP THAT HOLDS THE SPUR GEAR ON....ONCE THAT WAS TIGHTEND IT WORKED GREAT.
NEXT QUESTION....ANY RECOMMENDATIONS FOR FOAM TIRES AND WHEELS THAT WILL WORK. LOOKING TO RACE ON CARPET.
JGRANT is offline   Reply With Quote
Old 09-25-2010, 03:33 AM   #1837
[quote=JGRANT;7981316]
I'm using Jaco Orange/Double Pink front and Double Pink rear.
Old 09-27-2010, 02:49 AM   #1838
Miller_Time's Avatar
Trader Rating: 11 (92%+)
I haven't seen setup sheets anywhere for this car. Anyone know where I can find some, or have a good base setup for concrete?
www.HobbyStop.com
Miller_Time is offline   Reply With Quote
Old 09-28-2010, 06:19 AM   #1839
Hello guys. This is my first post, im new to the CR and im having trouble on deciding wich combo to use on it. The thing is that ive got a novavk havok 8.5, a velineon, and a CC sidewinder 5700. My idea was to use the sidewinder, but when i removed it from my sc truck I realized it says it is a 3.5T motor. Is it too much engine for the CR? Im quite experienced on rc, but i wouldnt like to wreck the differentials. Thank you very much
goyoloco is offline   Reply With Quote
Old 09-28-2010, 06:53 AM   #1840
All of those are going to be more than the CR was intended to use to be honest. You could use one of those speed controllers with a different motor - I'd say at most a 17.5 brushless.
I've read about people using more in this car, so it can be done, but I don't know how well the internals will stand up to that power over long term.
www.HobbyStop.com
Old 09-28-2010, 08:19 AM   #1841
Default what hop ups are available for my cr
hi,
i just ordered a porsche cup racer and hope to get in in the next days.
now i want to build kind of a show cup racer with tuning parts etc.
for this is my first cup racer i want to ask you who is offering parts for this kit besides hpi? i know of gpm and exotek so far.
Thank you very much for your help, i will post the result...
Tom
tommog is offline   Reply With Quote
Old 09-30-2010, 06:57 AM   #1842
1555Racing's Avatar
Thumbs up hop ups
Exotech, Hot Racing and Tsais make/made very nice hop-up for the Cup Racer
1555Racing is offline   Reply With Quote
Old 10-01-2010, 01:52 AM   #1843
Default where to buy hpi tuning parts?
Hi,
thank you. i will have a look for these parts.
For i am not from america it would be nice, if you guys could give me some advice where to order hpi etc. parts. the prices in us are much better than here in europe! i know tower (quite expensive), rc-planet (better) and go hobbies (i think good prices, but no paypal)
so thank you very much for you help!!!
tom
Old 10-01-2010, 02:35 AM   #1844
MikeR has a good setup for asphalt here. I think he used this setup in his youtube video of a race:
HPI Cup Racer 1M
Old 10-01-2010, 02:38 AM   #1845
Originally Posted by tommog View Post
Hi,
tom
Stormer Hobbies sells Exotek but I don't know if they send to Europe.
Tamiya TRF415 JDM_DOHC_SiR Electric On-Road 21094 03-10-2016 11:02 AM
The Future of RC Racing (Your Opinions) rccarracer15 Nitro Off-Road 103 06-10-2011 09:25 PM
Bodies for sale, new, used & painted coastaltony R/C Items: For Sale/Trade 68 01-02-2007 03:45 PM
Belt Driven vs. Shaft Driven Allen Sondej Electric On-Road 69 11-05-2004 07:51 PM
