Old 08-03-2010, 07:27 AM   #1756
Just a quick question for people using the Hot Racing aluminum axle cups... were yours threaded? I got a set recently with no threads at all in them. I figure I'll just run a tap through them, but it seemed odd so I wanted to check.
AMorgan is offline   Reply With Quote
Old 08-03-2010, 08:26 AM   #1757
k_bojar's Avatar
Trader Rating: 30 (100%+)
Send a message via ICQ to k_bojar Send a message via AIM to k_bojar
mine were all threaded and perfect alternative to the stock plastic one - a well worth the money investment
Bodies By Bean | Team Belly
k_bojar is offline   Reply With Quote
Old 08-03-2010, 09:14 AM   #1758
Ok, sounds like mine were screwed up then (both packages were missing the threads). I'll just run a tap through them. Thanks.
Old 08-03-2010, 01:48 PM   #1759
Raman's Avatar
Trader Rating: 50 (100%+)
Originally Posted by thefnshow View Post
i just bought a used cup racer and when i turn the wheels one way it goes full lock but if i turn it the other way steering severely limited...any ideas what could be wrong...thanks
When steering is straight, Check to see that your servo arm is centred and adjust the steering turn buckle accordingly. Also make sure the turn buckles that go to the steering knuckles are evenly adjusted.
Last, make sure your servo is centred when you are checking this.
If all these factors are set up, you should have equal steering on both sides. If you still down, then you may have an issue with your servo.
Raman is online now   Reply With Quote
Old 08-03-2010, 01:50 PM   #1760
Raman's Avatar
Mike,
Any idea what price those aluminum cups will go for? Planning to order all your accessories at once. Just got my HR cups so I should be good to go to run this car hard. Looking forward. Thanks for finally making them.
+1 Thanks Mike... and thank you HPI umm NOT
Old 08-03-2010, 02:38 PM   #1761
Trader Rating: 21 (100%+)
servo is not even hooked up and i have this problem
thefnshow is offline   Reply With Quote
Old 08-03-2010, 02:48 PM   #1762
Raman's Avatar
Post some pictures so we can see what's up
Old 08-03-2010, 10:35 PM   #1763
i got it to go full lock left and right...it was missing that little plastic plate that goes inder the plate that the upper arms attach to...but those two vertical screws that connect the upper and lower arms start to cause it to bind so i took them off for now..maybe i had them too tight ?
Old 08-03-2010, 11:09 PM   #1764
MikeR's Avatar
Trader Rating: 14 (100%+)
Mike,
I Haven't figured the final cost but it should be apprx $12usd. Due date is late Aug. early Sept.
www.exotekracing.com ☆ASSOCIATED☆DURANGO☆HPI☆HB RACING☆KYOSHO☆LOSI/TLR☆SERPENT☆TAMIYA☆XRAY☆
A picture with your post, when trouble shooting, will probably get more rctech help than without...
MikeR is offline   Reply With Quote
Old 08-04-2010, 07:32 AM   #1765
That seems quite fair. I look forward to it.
Old 08-04-2010, 09:50 AM   #1766
jgGonzo's Avatar
Trader Rating: 24 (100%+)
Thanks for all your hard work Mike, I'm sure this product will be as great as the rest of the Exotek products.
I was running the Exotek chassis and your set up last season and did real well..........Our track here has decided to go all off road so I'll be turning my CR into a drift machine...............oh well, they still are allot of fun.................
RS4 MT/RS4/Pro2/Pro4/Pro5/D413/RS4 Nitro MT/RS4 Micro/RS4 3 18ss/RS4 Rally/Blitz/Blitz ESE/E.Firestorm/Super E.RS4/MT2 Slash Killer/Mini Recon/HB Cyclone/Tamiya Midnight Pumpkin/Revo3.3(x2)/Slash(x2)/Slash 4x4 Platinum/Mini E.Revo/EXO Terra/SCX10/Twin Hammers/Pro2SC/DEX210/DEST210R/DESC210R/Associated Rally/Yetti XL
jgGonzo is offline   Reply With Quote
Old 08-04-2010, 11:31 AM   #1767
3-Dee's Avatar
Default mini brawl
Here's a link to the mini brawl for it all (2wd & 4wd), set to take place on Sept 11, 2010. Check it out and post your comments (positive ones please).
MINI BRAWL FOR IT ALL (Sept 11, 2010)
Denmark
3-Dee (BROKE _ SS RACING)
CASTLE CREATIONS
HRT Racing (thanks Doug)
Team Shut Up And Drive!
3-Dee is offline   Reply With Quote
Old 08-08-2010, 11:56 AM   #1768
Billh's Avatar
Default spare parts
Ok guys I just got my cup racer "used" and need to order a steering part from hpi, what other parts should I stock up on. They are hosing me 10.00 shipping so I dont want to order 2 $8.00 parts if you know what I mean. Thanks
Billh is offline   Reply With Quote
Old 08-08-2010, 12:04 PM   #1769
Raman's Avatar
You don't need to order from HPI and pay full retail plus high shipping. Try one of these sites
http://www3.towerhobbies.com/cgi-bin...I=HPIC0594&P=Z
https://www.myatomic.com/catalog/sea...%3A3026&rpp=60
http://www.amainhobbies.com/index.ph...cing-Cup-Racer
Old 08-08-2010, 02:34 PM   #1770
MikeR's Avatar
Any time and thanks for your support!
Drift actually looks like fun and the body and rim choices for mini are perfect looking for drift
Tamiya TRF415 JDM_DOHC_SiR Electric On-Road 21094 03-10-2016 11:02 AM
The Future of RC Racing (Your Opinions) rccarracer15 Nitro Off-Road 103 06-10-2011 09:25 PM
Bodies for sale, new, used & painted coastaltony R/C Items: For Sale/Trade 68 01-02-2007 03:45 PM
Belt Driven vs. Shaft Driven Allen Sondej Electric On-Road 69 11-05-2004 07:51 PM
