Old 07-25-2010, 04:02 AM   #1741
k_bojar's Avatar
Trader Rating: 30 (100%+)
Send a message via ICQ to k_bojar Send a message via AIM to k_bojar
Originally Posted by BangkokBulldog View Post
Ok, the CR has been available for a while now..Does anybody here actually race their CR on an asphalt track???
I only ask as Ive had mine for around 4 months and I am still disappointed with it. I have rebuilt it 4 times, changed front/rear diff settings, motors and springs etc and it still behaves on the track poorly.
Its noisy, glitchy and has no chance against similar models on a high bite track.
Any other racers care to comment?
what is it doing on the track?? that might help
mine works pretty good the last time I ran it - the noisey-ness is because of the meta gears, shaft drive and the 48P gears...
and I know a group that pretty much ONLY runs the CR and they all handle like they are on rails...
Bodies By Bean | Team Belly
k_bojar is offline   Reply With Quote
Old 07-25-2010, 04:41 AM   #1742
Billh's Avatar
What is a good motor choice for these?
Billh is offline   Reply With Quote
Old 07-25-2010, 10:27 AM   #1743
BangkokBulldog's Avatar
Hi K,
Maybe I'm too used to my HB Cyclone and its smoothness. I just feel that the CR is twitchy even with a Sport Tuned motor and was hoping I built it wrong. Ive rebuilt it and its still not much better.
Im using the rear metal shaft cup holder on the front and the stiffest gear diff spring in the front too.
I will have another rebuild this week and take it to the track on Saturday, if its still the same, I will sell it and buy a F104
BangkokBulldog is offline   Reply With Quote
Old 07-25-2010, 12:04 PM   #1744
k_bojar's Avatar
Hi K,
well the car will actually be a little more twitchy then a cyclone - smaller wheel base and narrower chassis...i had a hi-speed digital servo in mine, and it was very twitchy - needed to dial a lot of steering expo out of mine...
i can't remember what kind of oil i got in mine, but I got the hardest springs in the front and the 2nd hardest (medium, i guess) in the rear - these are from the optional kits...I'll have to pull mine out and see what I got in it...
Old 07-25-2010, 12:54 PM   #1745
MikeR's Avatar
Trader Rating: 14 (100%+)
It's mostly all about tires tires tires with this car
You haven't listed your set up. Spell it all out and I think someone can get you going. I ran my car last weekend and it is seriously fast and nimble and I'm really looking forward to the ABC mini series that will soon kick off next month
Here is a race with my cup racer from last year if you haven't already seen;
[YOUTUBE]<object width="480" height="385"><param name="movie" value="http://www.youtube.com/v/Ze3eFieJD_Q&amp;hl=en_US&amp;fs=1"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/Ze3eFieJD_Q&amp;hl=en_US&amp;fs=1" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="480" height="385"></embed></object>[/YOUTUBE]
Also some good news regarding the plastic front input cup. We've developed an alloy hard anodized cup that will be here late August!
www.exotekracing.com ☆ASSOCIATED☆DURANGO☆HPI☆HB RACING☆KYOSHO☆LOSI/TLR☆SERPENT☆TAMIYA☆XRAY☆
A picture with your post, when trouble shooting, will probably get more rctech help than without...
MikeR is offline   Reply With Quote
Old 07-25-2010, 10:26 PM   #1746
Great news about the input cup Mike, everyone has waited soooo long for somebody to make one.
My basic set up is:
Pink springs on front
Blue springs on rear
Hard spring in front diff
23t Tamiya Super Stock
Tyres: HPI standard CR on Porsche rims or Sweep 33/40
30w shock oil
Short wheelbase option as using Porsche body
I will keep trying different set ups and see whats best.
Thanks for the help guys.
Old 07-26-2010, 03:28 AM   #1747
Hi guys!
I have a problem with my CR. When I am going to tighten the wheels, the plastic cups is being twisted by the pin that is going through the shaft and cup. What do I do wrong?
Fabiz
Fabiz is offline   Reply With Quote
Old 07-26-2010, 09:01 AM   #1748
MikeR's Avatar
My basic set up is:
30w shock oil
Shocks looks good- same as mine except I run 40wt with 3 hole piston.
My droop is set with arms at level (make sure it is equal left to right).
Rear toe should be at 3* with the motor you are running.
Front caster all the way back.
I use 36 degree Atomic tires with medium insert. These tires are awesome and handle like if they were Sorex
You may need to find a bigger wing also.
Old 07-26-2010, 09:02 AM   #1749
MikeR's Avatar
Originally Posted by Fabiz View Post
Hi guys!
Fabiz
Wheel screw you are using is too long maybe... may be hitting the drive shaft.
Old 07-26-2010, 09:29 AM   #1750
And you are running the exotek chassis correct?
Bodywerx_rc is offline   Reply With Quote
Old 07-26-2010, 10:08 AM   #1751
MikeR's Avatar
Oh but of course!
Old 07-26-2010, 10:19 AM   #1752
k_bojar's Avatar
Oh but of course!
he's running the original chassis or one of the original
Old 07-30-2010, 08:18 AM   #1753
Mike,
Any idea what price those aluminum cups will go for? Planning to order all your accessories at once. Just got my HR cups so I should be good to go to run this car hard. Looking forward. Thanks for finally making them.
AMorgan is offline   Reply With Quote
Old 07-31-2010, 07:46 AM   #1754
Well,
I just got back from the track and am pleased with the CR finally.
I changed the front gear diff spring back to the softest, changed the wheelbase back to 225mm and used my Sweep 33/40 tyres.
It seems much quieter after the rebuild and smoother.
Only raced against my friends M chassis, both with 23t brushed, and the CR was much quicker through the corners.
Old 08-03-2010, 12:14 AM   #1755
Trader Rating: 21 (100%+)
i just bought a used cup racer and when i turn the wheels one way it goes full lock but if i turn it the other way steering severely limited...any ideas what could be wrong...thanks
thefnshow is offline   Reply With Quote
Tamiya TRF415 JDM_DOHC_SiR Electric On-Road 21094 03-10-2016 11:02 AM
The Future of RC Racing (Your Opinions) rccarracer15 Nitro Off-Road 103 06-10-2011 09:25 PM
Bodies for sale, new, used & painted coastaltony R/C Items: For Sale/Trade 68 01-02-2007 03:45 PM
Belt Driven vs. Shaft Driven Allen Sondej Electric On-Road 69 11-05-2004 07:51 PM
