Old 07-10-2010, 05:34 PM   #1726
Raman's Avatar
Trader Rating: 48 (100%+)
Its one of two things.. either ESC or motor. Check the lead wires from ESC to motor. See if they work.
If you have another motor, connect it to ESC to test. If you don't have another motor, you can attach a volt meter to the leads that go to motor. When you pull trigger, see if any voltage registers.
Raman is online now   Reply With Quote
Old 07-10-2010, 10:12 PM   #1727
nogoodname's Avatar
If it's the ESC, which one should I buy to replace it and would work with the other parts I have installed?
Also, the X30re motor is a 30 turn motor, is this a good motor to be using?
HPI Cup Racer | Datsun 240Z | Gun-Metallic | 540 | TE37 | BBK | Bunch of stickers for added torque!!!
nogoodname is offline   Reply With Quote
Old 07-11-2010, 09:05 AM   #1728
nogoodname's Avatar
Hey, The motor is working fine. I connected a 9v battery to it and it works.
I lost my volt meter so I couldnt check the esc.
Old 07-11-2010, 09:30 PM   #1729
Raman's Avatar
You have a lot of choices as far as ESCs. You can spend anywhere from 40 to 200. Its up to your budge. Most ESC's over 100 are able to run both brushed and brushless motors.
Check the for sale section of this forum.. lots of ESC's are being sold dialy.
Old 07-11-2010, 09:41 PM   #1730
nogoodname's Avatar
I'm not sure if the x30re is brushed or brushless
Also, does it matter whether it's a 30 turn or not? Also, I like to have reverse too. I would like to spend around 50 dollars for one. Any ideas?
Old 07-11-2010, 09:49 PM   #1731
Raman's Avatar
Its brushed. Brushless have 3 wires.. yours have 2.
Here are a list of ESCs
http://www3.towerhobbies.com/cgi-bin/wti0093p?&C=MJG
Old 07-11-2010, 09:54 PM   #1732
nogoodname's Avatar
Thanks for the tip!!! I'm such a newbie with this. I want to get my 240z to work so that I can show it off when I organize car meets for my club I started.
Which is a good brand? I dont want another dead ESC...lol
Old 07-13-2010, 10:58 PM   #1733
just got the HPI Cup Racer build and brand new. Can this car handle brushless? For speed run, what is the best setup?
rcracingzone is offline   Reply With Quote
Old 07-16-2010, 06:30 PM   #1734
Billh's Avatar
Default Motor
What would be a good motor to drift with?
Billh is offline   Reply With Quote
Old 07-22-2010, 03:28 PM   #1735
Chimer's Avatar
Trader Rating: 26 (100%+)
Default ?
I finally got all of my electronics in my Porsche and it makes a very loud grinding type noise when I give it some throttle. The rear wheels spin a little and the front ones don't spin at all but the driveshaft is spinning. The gear mesh between the pinion and spur is good. Does anyone have any idea what I should look for as far as broken parts when I disassemble it?
AE:B5r,B5m,TC6.1,Team Losi:JRX-2,Tamiya Mercedes-Benz 1838LS,Traxxas Slash
Chimer is offline   Reply With Quote
Old 07-23-2010, 06:23 AM   #1736
Take a look at the diffs, they might be too tight.
I ended up taking apart my gear diff, and removed the spring entirely, and it is VERY SMOOTH now.
Bodywerx_rc is offline   Reply With Quote
Old 07-23-2010, 01:43 PM   #1737
Chimer's Avatar
Thanks for the tip. Turns out I just had two wires soldered in the wrong places on the motor, I switched 'em and now it runs awesome. I just assumed it was a drivetrain problem because of the horrible noise. Ready to race on Sunday!
Old 07-24-2010, 09:26 AM   #1738
BangkokBulldog's Avatar
Ok, the CR has been available for a while now..Does anybody here actually race their CR on an asphalt track???
I only ask as Ive had mine for around 4 months and I am still disappointed with it. I have rebuilt it 4 times, changed front/rear diff settings, motors and springs etc and it still behaves on the track poorly.
Its noisy, glitchy and has no chance against similar models on a high bite track.
Any other racers care to comment?
BangkokBulldog is offline   Reply With Quote
Old 07-25-2010, 01:34 AM   #1739
tha Beast's Avatar
Trader Rating: 100 (99%+)
i do its actually pretty good i was VERY pleased a friend and I are working on getting the front thing that keeps breaking the pins in aluminum(i cant remember the name right now) anyway we are getting some prototypes in pretty soon so if there are any other guys out there that may need this peace please post up cause we want to see how much interest there is before we order
tha Beast is offline   Reply With Quote
Old 07-25-2010, 01:37 AM   #1740
tha Beast's Avatar
dude mine is awesome runs very well.... it is a little louder but it has metal gears and is shaft driven
Tamiya TRF415 JDM_DOHC_SiR Electric On-Road 21094 03-10-2016 12:02 PM
The Future of RC Racing (Your Opinions) rccarracer15 Nitro Off-Road 103 06-10-2011 10:25 PM
Bodies for sale, new, used & painted coastaltony R/C Items: For Sale/Trade 68 01-02-2007 04:45 PM
Belt Driven vs. Shaft Driven Allen Sondej Electric On-Road 69 11-05-2004 08:51 PM
