Old 04-15-2010, 09:02 AM   #1591
Chimer's Avatar
Trader Rating: 26 (100%+)
The HPI website in England says they have the Fuchs Wheels, maybe I can order them from there.
AE:B5r,B5m,TC6.1,Team Losi:JRX-2,Tamiya Mercedes-Benz 1838LS,Traxxas Slash
Chimer is offline   Reply With Quote
Old 04-15-2010, 02:19 PM   #1592
Can I get some help over here?
DuffmanIVXX is offline   Reply With Quote
Old 04-15-2010, 02:23 PM   #1593
k_bojar's Avatar
Trader Rating: 30 (100%+)
Send a message via ICQ to k_bojar Send a message via AIM to k_bojar
i believe this is what you are referring to:
http://www3.towerhobbies.com/cgi-bin...&I=LXMVE1&P=ML
not an esc, but something that aids in drifting
Bodies By Bean | Team Belly
k_bojar is offline   Reply With Quote
Old 04-15-2010, 02:39 PM   #1594
1555Racing's Avatar
Originally Posted by David-M View Post
It is always the same piece and nobody does it aluminum (almost incredible), and as Mike said, take a back one and mount in the front...
However, a 8.5t is ok but the setup has to be perfect ...otherwise you can use its power only on the straight...
http://www.hobbyetc.com/cgi-bin/item.cgi?part_id=60177
1555Racing is offline   Reply With Quote
Old 04-15-2010, 03:59 PM   #1595
Yeah, thats what i heard about, sounds kinda like a bitch aid to me. Should be able to drift without it right? What about the rest of the electronics? I'm kinda new to r/c racing and I dont want to buy the wrong stuff. What electronics would you put in a cup racer set up for drifting? I would prefer brushless if its worth it. What radio? Motor/ESC? Batteries? Etc... thanks
Old 04-16-2010, 06:36 AM   #1596
Chimer's Avatar
I'm planning on getting a cup racer. What electronics should I put in it? Radio? Servo? Li-Po? Motor? Im just getting it for fun, no racing, all I know is I want it brushless. I have a near by carpet track I have access to as well as smooth parking lots. I want the car set up for drifting but i also want it quick in the straight aways. I heard of a speed control that aids with drifting, i think it was programmable?? Im looking for as much info as you guys can throw at me, wanna do it right the first time. Thanks
I think the speed control you are referring to is the Novak Slyder, go to www.teamnovak.com and see if they have any refurbished ones for sale. The refurbished esc's come with the same warranty as a new one but is cheaper. I think a 13.5 or 17.5 brushless motor would be good enough for drifting, but I am not into drifting. Any 2-cell LiPo would be good, I have had good luck with Reedy, Venom, and True Rc(www.truerc.com) batteries. Any servo would work but a faster servo makes the car easier to drive, I would go with a Hitec HS-625MG, it's $35 and Hitec has awesome customer service.
Find the best Cup Racer driver at your local track and ask him what he has, he will be your competition so it only makes sense to get a step up on him.
Old 04-16-2010, 10:30 AM   #1597
speedemall's Avatar
Trader Rating: 57 (100%+)
I am in the market for a CR and I want a speed demon as I will not be racing it. Of course I plan to go brushless but I wanted to know how far I could go KV wise on the motor setup and not end up grenading the diffs on it. Also with the power of the BL setup what upgrades should I look into for protection against the power of the BL setup? Are there any upgrades that I absolutely must have for the car to run efficiently.Does anyone make wider wheels for the CR? I want the stretched tire JDM look on my 510 just like in the pics below, I will also be doing the camber stance like the 510 to the left of the photo.
HPI Cup Racer 1M-nos2days2009%3D110_196_nissanskylinec10_bluebird510coupe_rhfactory.jpg
speedemall is offline   Reply With Quote
Old 04-16-2010, 10:33 AM   #1598
YmeBP's Avatar
Trader Rating: 32 (100%+)
We have cup racers on special this month.
http://www.skyrocketbatteries.com/pr...roducts_id=106
We have a porsche, a 240 and a 510.
www.skyrocketracing.com quality RC gear!
http://www.rctech.net/forum/racing-forum/555071-2011-skyrocket-invitational-blue-diamond-raceway-october-15-16-a.html <- Great race!
YmeBP is offline   Reply With Quote
Old 04-16-2010, 11:54 AM   #1599
Originally Posted by Chimer View Post
I think the speed control you are referring to is the Novak Slyder, go to and see if they have any refurbished ones for sale. The refurbished esc's come with the same warranty as a new one but is cheaper. I think a 13.5 or 17.5 brushless motor would be good enough for drifting, but I am not into drifting. Any 2-cell LiPo would be good, I have had good luck with Reedy, Venom, and True Rc batteries. Any servo would work but a faster servo makes the car easier to drive, I would go with a Hitec HS-625MG, it's $35 and Hitec has awesome customer service.
Thanks for answering my questions, appreciate the help.
Old 04-17-2010, 03:47 AM   #1600
k_bojar's Avatar
Originally Posted by 1555Racing View Post
those are very nice parts, and i have them on my CR - biggest reason? i hated those stupid M3 locknuts that was inside the plastic parts
BUT - that's not the part that everyone breaks..those are for the wheels - the part that breaks goes into the FRONT gearbox, has the center drive shaft on one side and the metal bevel gear (which drives the front diff) on the other side
its the ONE PART that no one has seem to think about making...MikeR metioned a 'work around' fix - but no one has come out with a true replacement/aftermarket part for it (hint, hint mike )
Old 04-17-2010, 03:54 AM   #1601
k_bojar's Avatar
technically, that's the part you asked about...
there is NOT a speedo on the market to 'aid' in drifting...
novak makes their slyder - already mentioned by someone else - that is 'geared' towards the drift crowd...but ANY speedo can be used for drifting...even the box-stock Tamiya speedos that come in a TT01 can be used for drifting
this is what novak has it their site about the slyder:
Though the SLYDR Brushless Drift ESC has one throttle profile, the versatile ESC is completely programmable and packed with nine customizable parameters. Novak’s Throttle Curve gives drivers the ability to experiment with three throttle responses – Linear, Expo-1 and Expo-2 – which range between a quick burst of power to a smoother, more controlled low-end power delivery. In addition, the SLYDR’s Brake Frequency adjustment contains seven degrees of adjustability from a smooth and controllable brake to a more abrupt and grabbier feel. The dozens of adjustments allow drivers to fine-tune their vehicle’s throttle braking for better control and advanced drifting and racing.
the biggest different then this over the GTB?? one throttle profile vs 6 throttle profile on the GTB - the remainder is pretty much the same...
I'm not bad-mouthing the novak stuff - just pointing out there 'technically' isn't a speedo that will aid in drifting, just one designed with adjustments to the features mostly used by a drifter
enjoy your CR either way
Old 04-17-2010, 04:48 AM   #1602
1555Racing's Avatar
Thumbs up my bad.....
thx, for the clarification, kbojar...
I going break my down and adjust my diff. Surprisingly mine has not broken, but those axle cups I broke one on the 1st run.
Old 04-17-2010, 05:11 AM   #1603
speedemall's Avatar
Can anyone answer my questions? I really wanna by this in the next week or so but if I can't get answers I guess I'll by an M05
Old 04-17-2010, 07:49 PM   #1604
bigb11's Avatar
Trader Rating: 59 (100%+)
Send a message via AIM to bigb11
anybody have a good starting point (pinion) with a 17.5 using a stock spur gear.
PHAT QUAD RACING, HPI/HOTBODIES, RATZAS, DARKSIDE MOTOR SPORTS, PARMA, Brown Engineering, ROBITRONICS, RC AMERICA, PANTHER, TEKIN, TEAM HOLY ROLLER, Rev Tech/Epic, RC AFRICA, HITEC www.browneng.org, DE wheels
bigb11 is offline   Reply With Quote
Old 04-17-2010, 08:27 PM   #1605
redzone's Avatar
Hi guys, i have finally (after 2 years of searching) found and purchased a Carson Opel Kadett C coupe bodyshell, same shape as my Holden/Isuzu Gemini coupe 1:1 i own, i want to make a replica of my real car, and i need a chassis for it. at the moment i can only find one chassis to fit it (M04L), as it runs a 240mm wheelbase. the shell is 175mm wide too, anyone know of some wraparound type chrome bumpers that will fit a shell this width also? i looked at the cup racer 510 ones but they'e way too narrow..
as well as that i want to find some slightly dished M chassis size mesh wheels, in 3 piece or a 3 piece copy/style...
anyone that can help me out gets an internet high five
79 mk1 Sand Scorcher, 09 Buggy Champ, TB01 Lancer Evo 7, TL01 Lancer Evo 6, TA02 Castrol Celica, TA02SW Taisan Porsche, TA02W Castrol Supra, TA03F Starion drifter, M06pro Gemini coupe, Tamiya Dyna Storm 5.5t, Stadium Blitzer, Bear Hawk, Baja FAV, Egress!
redzone is offline   Reply With Quote
Tamiya TRF415 JDM_DOHC_SiR Electric On-Road 21094 03-10-2016 11:02 AM
The Future of RC Racing (Your Opinions) rccarracer15 Nitro Off-Road 103 06-10-2011 09:25 PM
Bodies for sale, new, used & painted coastaltony R/C Items: For Sale/Trade 68 01-02-2007 03:45 PM
Belt Driven vs. Shaft Driven Allen Sondej Electric On-Road 69 11-05-2004 07:51 PM
