Old 03-26-2010, 11:51 AM   #1546
Trader Rating: 47 (100%+)
Thank you.......what a bummer!!!!
Originally Posted by Sydewynder View Post
The Tamiya M chassis cars' wheelbases are:
M03/M05 - 210mm
M03M/M04M/M05M - 225mm
M03L/M04L/M05L - 239mm
The BMW Cooper bodies 2002 and 2006S fit the M03L. I have the 2002 version of the body and its 239mm wheelbase.
Even though Tamiya USA site doesn't say it's 239mm wheelbase for the 2006S body, it does say it's for an M03L.
See the link below from the English language Japanese Tamiya site. Yes the spec said 237mm. Its 239mm.
http://www.tamiya.com/english/produc...er_s/index.htm
jakeg1999 is offline   Reply With Quote
Old 04-01-2010, 11:16 PM   #1547
Trader Rating: 17 (100%+)
I just picked up a CR and will be putting it all together this weekend but I need advice on which servo to run? More speed than torque, more torque than speed, what are good numbers?
omalley72 is offline   Reply With Quote
Old 04-02-2010, 06:16 AM   #1548
PaPeRo's Avatar
For Mini sized cars you don't need much torque. All standard sized servos will have enough torque. In terms of speed sometimes too much speed can make the steering twitchy it really depends on your driving style.
With that said any standard sized servo with a speed of around 0.10 sec@6V is good. Look for quality dual ball bearing metal geared digital servos.
deans - dodgy electrics amps not sufficient
PaPeRo is offline   Reply With Quote
Old 04-04-2010, 09:41 PM   #1549
Mark G.'s Avatar
Default CR for Sale
If anyone out there is interested in purchasing a Cup Racer running chassis only, please let me know by PM. I'll forward pics to those that are interested.
Mark G. is offline   Reply With Quote
Old 04-05-2010, 06:19 AM   #1550
If I try to run RWD what should I do to the front differential to get good performance? Soften? Harden? Lock?
sorry for my english...
David-M is offline   Reply With Quote
Old 04-05-2010, 06:39 AM   #1551
PaPeRo's Avatar
Remove the dogbones and differential drive cups then put small piece of foam in the the holes where the drive cups were to prevent dirt from getting in the differential.
Old 04-05-2010, 08:32 AM   #1552
Oh, thank you, then make everything free?
Old 04-05-2010, 08:38 AM   #1553
Raman's Avatar
Trader Rating: 49 (100%+)
Yes, then it will be 2 wheel drive
Raman is offline   Reply With Quote
Old 04-05-2010, 09:47 AM   #1554
hehe, sure...I'll try to run against m-05
Old 04-05-2010, 09:30 PM   #1555
PaPeRo's Avatar
Disregard what I mentioned earlier as I just remembered that the CR use ball differentials so the drive cups do not/cannot need to be removed from the front differential. What you need to do is remove the front dog bones AND the center prop shaft.
Old 04-05-2010, 10:33 PM   #1556
well, yes, I remove the whole front differential and leave only the box...no?
Old 04-05-2010, 10:37 PM   #1557
PaPeRo's Avatar
No you do not need to remove the front ball diff, all you need to do is remove the two front L/R dog bones and the long prop shaft that connects the front and rear diffs. This way the rear diff works like normal and is completely disconnected from the front diff so there less drive loss. If you leave the prop shaft in it will still work but you lose efficiency because the motor will still have to turn the front ball diff even if it's not connected to the front wheels.
Old 04-05-2010, 11:11 PM   #1558
Thumbs up
This is certainly the fastest and easily reversible solution. I'll start like that, if the car is fine then I can remove the whole front differential to save further weight...
Old 04-05-2010, 11:56 PM   #1559
cannon's Avatar
Trader Rating: 35 (100%+)
I can tell you now that the Cup racer in 2WD is a bag of sh*t.
Hara ran a switch at the TITC event in Thailand. As it was uncompetitive he tried a 2WD Cup racer and it was even worse to the point where he gave up in the final
www.feralbatteries.com ........... new website
cannon is offline   Reply With Quote
Old 04-06-2010, 01:25 AM   #1560
mmm. bad news, although a little I thought it
Tamiya TRF415 JDM_DOHC_SiR Electric On-Road 21094 03-10-2016 11:02 AM
The Future of RC Racing (Your Opinions) rccarracer15 Nitro Off-Road 103 06-10-2011 09:25 PM
Bodies for sale, new, used & painted coastaltony R/C Items: For Sale/Trade 68 01-02-2007 03:45 PM
Belt Driven vs. Shaft Driven Allen Sondej Electric On-Road 69 11-05-2004 07:51 PM
