Old 02-04-2009, 03:36 AM   #1
rcdude8's Avatar
Default Problems
I have just completed my build and started to run my car and some of the problems I have are easily solved but others are really confusing.
One problem is that the direction motor is pulling keeps changing, so for example I will have run and it will be fine and then I turn it back on and when I go to accelerate is reverses. What is causing that because it is very annoying?
Hot Bodies Cyclone S
LRP A.I. Brushless Reverse Digital
Acoms Technisport 2.4 Ghz Radio System
Mazda/Stratus Cross Body
rcdude8 is offline   Reply With Quote
Old 02-04-2009, 05:38 AM   #2
miller tyme's Avatar
I notice in you sig. your listed am LRP AI speed control. That would be you likely problem. My son uses it and it is sensitive to what order you turn radio/car on. double check the ESC instructions and follow them to a 'T' and make sure you do it the same way every time.
Ken Miller
RC America - X-Ray - ORCA - EA Motorsorts - Sweep Racing Tires - TQ Wire - ProOne Racing Tires -
miller tyme is offline   Reply With Quote
Formula 1... Darkseid Chat Lounge 14468 10-16-2016 01:28 PM
Team Tekin New Speedos Drew_Cat Radio and Electronics 1521 10-05-2012 11:35 PM
Spektrum allrc Radio and Electronics 2545 07-17-2012 08:25 AM
New Novak Brusless System danjoy25 Electric On-Road 2688 10-14-2010 08:40 AM
Jammin' X2 Buggy NsideLine Nitro Off-Road 479 09-02-2010 10:36 AM
AMB/Alycat Problems nerdling Australian Racing 20 10-18-2004 12:43 AM
SEO by vBSEO 3.5.0
