lrp spx stock spec
#946
Supposedly Jon Tag said that true 0 degree timing is actually three marks advanced past the long line on the Duo2. With that motor timing, I tried profile 8 at 6.3 FDR with my 13.5 Duo2 and it is fast, but not nearly as fast as the RS with a Duo2.
The new software took the Tekin to another level. Version 203 brought about the first time I felt truly out powered by the RS when using the SPX. 13.5 is no longer like super stock; it's like mod.
#947
v203 is definitely like mod with a 13.5. I got my first taste of it on Sunday and I couldn't keep my jaw off the floor. My hats off to Tekin because that speedo has come a long way.
#948
Somewhere on the RS thread the Duo2 timing is discussed. I also saw it in this document about the RS:
http://rcfaq.weebly.com/tekin-rs--hotwire.html
Max motor timing with the Duo2 is something like 10 degrees.
#949
Hello, have any of you had to deal w LRP warranty department? Just curious about their customer service, and why the form for sending defective product back wants your credit card information. I was changing my motor on my pretty much brand new SPX and my 17.5 started smoking. I took it all apart and found the first pin from the sensor plug on the SPX still in the plug of my 21.5 motor. So now I have to send SPX back to LRP. It was only used for three race nights. Also now I have a fried 17.5 motor (tried in my old GTB its done!). Hope it all goes smooth, I already miss it.
#950
The LRP service in the US goes through Team Associated in California.
Always has been top notch for me...I've made my ESC mistakes in the past...LOL
Bill
Bill
#951
#955
Location: A step closer to where I need to be a step further from where I was
OK guys going to the Birds and will be for now running my SPX. I have a Duo2 and would like to try profile 8 and full or close to full timing on the motor. Track I am running on this weekend has a back straight of approx 60 ft. I know the Birds track is larger but I will adjust when I get there never run profile 8 any ideas on a good starting FDR for this scenario?
Rod
Rod
#956
Rod
Rod
#957
My bad 17.5
Rod
Rod
#958
In 17.5, Full timing in my experience has meant only more heat and fading at the end of the race. My motors sweet spot seems to be 10 degrees. Profile 8 is pretty aggressive profile and I wonder whether that much timing on the can is detrimental to best performance. Id love to hear Reto's thoughts on this.
#959
Kinda what I thought but never pushed the motor that hard with the SPX. Also never ran profile 8 and would rather ask so I don't fry stuff needlessly
Rod
Rod
#960
I ran pretty much the same equipment at Minnreg last weekend, which is the Snowbirds track.
Duo2 17.5 with full timing
SPX set to 1/8/0/0
Team Epic 5000 40c packs
My final was 5.6 and the car was on pace with all the SPX cars, but the Tekin RS cars were blowing us all away. My motor was coming off around 155-165 after each heat and it did fade a little bit in the last minute.
SPX set to 1/8/0/0
