Many discounts and deals on RC products and parts can be found on UltimateCoupons.com.
Consider visiting BensBargains.net for great discounts on remote control products.
Old 11-02-2009, 06:53 PM   #841
M-Technic's Avatar
It's listed somewhere on their web site. That's where I found it when I had to call about my SPX replacement.
Team Epic/Trinity
M-Technic is offline   Reply With Quote
Old 11-03-2009, 05:15 PM   #842
Hello everyone, quick question for anyone who knows.
I`m gonna be running the spx in a 12scale i cell lipo configeration.
In what profile do i run her? E.g in lipo mode or nimh mode?
Reason i ask is, a couple pages back i read that you had to run the spx in nimh mode, but why? Second, do the spx has a voltage cutoff?
RROL and LOU`s where only real racers race.
Weapons of choice, Serpent 733, Top photon x 2, Crc genx-10.
Futaba 4pk,gq tires,jaco tyres,odonnel fuel,smc batteries, tekin and nova powered.
Don`t blame the car, when you know you can`t drive.
Sponsor, me , myself and I.
nitro ho is offline   Reply With Quote
Old 11-03-2009, 05:26 PM   #843
LOW ET's Avatar
Trader Rating: 24 (100%+)
nimh mode, settings will most likely be 2-8-1-1.
there is a lipo cutoff but for 2s 7.4v only, that's why you have to run the 1s 3.7v in nimh mode.
LOW ET is offline   Reply With Quote
Old 11-03-2009, 06:03 PM   #844
You da man Low et, you da man
Thanks, if you don`t mind, i also got the tq cell booster, how do you hook that up if you don`t mind me asking.
Old 11-03-2009, 06:09 PM   #845
LOW ET's Avatar
http://www.tqcells.com/TQBOOSTER.htm
Old 11-03-2009, 06:20 PM   #846
Thanks bro, as i said before, you da man!!!!!!!!!!!!!
Old 11-03-2009, 06:32 PM   #847
Ffejdat's Avatar
Any opinions on gearing and motor timing, for running this on 12th car, 1s lipo, 17.5 motor? Would you use 0, mid or high physical motor timing, with using profile 8 in ESC? Thanks!
I got more flavors than Fruit Stripe gum!
Ffejdat is offline   Reply With Quote
Old 11-05-2009, 02:21 PM   #848
Trader Rating: 2 (75%+)
Default Engine Supression
Just a quick question regarding engine supression capacitors.
When using the LRP Sphere TC spec on a brushed motor it states in the manual you should use engine supression capacitors. Unfortunatley I am having trouble finding these capacitors.. Is there a capacitor I could get from an electronics supplier.. Anyone know the specs on it?
Also are the capacitors needed on all brushed motors? I was going to sometimes run the ESC in 540 pro & Classics classes and in the manual it states the mabuchi motor needs a capacitor on both the + and - would this be the same with a Johnson 540 J.. as I think this motor has capacitors..
Thanks for any help..
warnos16v is offline   Reply With Quote
Old 11-05-2009, 08:52 PM   #849
Still Bill's Avatar
Sorry warnos; but, you need to find a thread that is related to your post. This thread is about the LRP SPX Stock Spec ESC. Just do a search on the "LRP Sphere TC ESC" to find answers to what you are seeking.
Thanks.
Bill
Who will be the next Matt Francis?
Corally Φ and CRC Gen-X 10 guy
Still Bill is offline   Reply With Quote
Old 11-08-2009, 08:22 AM   #850
Default LRP SPX and 17.5 bl
Hi Plan to do Snowbirds and have no experience of running 17.5 and lipo. Running in the 1/12th circuit .Looking for rollout.
Motor will be either the redline or the duo2 Also what timing would you set the motor too.
thanks in advance
tellan is offline   Reply With Quote
Old 11-09-2009, 04:17 AM   #851
Default spx with speedpassion 3.0 13.5T
hi guys,
i was running my spx with a speedpassion 13.5T last weekend. however, i was experiencing a lack of speed and punch compared to other drivers. since the others were runninng same motor i was wondering about the gearing since this is still a mystery to me. the setup was
indoor high grip 30 m straigt
spx prog 8
sp v3.0 13.5T (timing manually to +10°)
gearing 1:5.0
does the spx actually provide more power when the 10° timing on the motor is applied or not? if yes should die FDR by more like 1:6.0 or even lower to 1:4.5 to get more punch and top speed.
thanks for your help!
cheers
vitomon is offline   Reply With Quote
Old 11-17-2009, 01:35 AM   #852
JJC
I'm currently running a Novak Ballistic 13.5 with a Novak GTB ESC and have hit the sweetspot on the FDR at 4.6.
I now have an LRP SPX SS ESC and I'm looking for advice on gearing for the same motor when running profiles 5,6,7 and 8. Can anybody help me with a starting point? I plan on running profiles 7 and 8 mostly.
Many thanks
JJC
JJC is offline   Reply With Quote
Old 11-17-2009, 04:22 AM   #853
cyanyde's Avatar
Many thanks
JJC
Try FDR 6-7 for those profiles. Only temp and lap times will tell you its the right ratio.
cyanyde is offline   Reply With Quote
Old 11-17-2009, 07:13 AM   #854
dameetz's Avatar
sorry wrong post..
If I ain't drivin' I ll be flyin'
dameetz is offline   Reply With Quote
Old 11-17-2009, 08:10 PM   #855
Default spx rollout
i have a duo 2 13.5 with a spx esc...i need to get a fast rollout...someone give me an idea of where to get..i went to texas and they were super super fast..it will be in a 12r5...help me out people...thanks
obi wun is offline   Reply With Quote
Forum Jump
LRP SXX TC SPEC Stein Tumert Electric On-Road 124 11-12-2009 10:35 AM
10.5 Setups matrix101 Australian Racing 14 06-05-2009 02:27 AM
LRP SPX and TC-SPEC Tral Radio and Electronics 15 04-21-2009 05:07 PM
LRP SPX Brushless Competition StockSpec ESC mazmo Australian Racing 10 02-16-2009 11:44 AM
LRP SPX Bullet Revise Burshless/Brush ESC chappi Australia For Sale/Trade 15 12-31-2008 07:29 AM
Powered By: vBulletin v3.7.4
Content © 2001-2008 RCTech.net | Privacy Policy | Terms of Use Privacy Policy | Terms of Use
SEO by vBSEO 3.2.0
