I heard that on races that I weren't attending one driver I know (and which asked few weeks ago which esc to buy - SPX Stock Spec of course) were asked what is he running (he was almost as fast as guys with 4.5T and 5cell). He had bought my used LRP X11 Stock Spec as well and he says it's rocket (others doesn't belive it's 10.5T standart motor without tuning). I'm not sure if it's motor - I wasn't on race with him since he got new esc - or esc itself.
Btw can you compare LRP Stock Spec motor (or Nosram) with Hacker?
Haven't yet tried the Nosram with it as the Hacker is going great..... and 'if it ain't broke'
Will be putting the Nosram in for the National next month (Hacker's not on the approved list).
Worringly a guy I race with has now blown 2 of these ESC's using his Prince 13.5
Skiddins
P.S. Beat another of my personal best's today by 9 secs
Maybe there are really some motors that have problems with SPX
Congrats
Pavel Balint
__________________________________________________________________
Schumacher racing UK team driver from Slovakia
Schumacher Cat SX | Schumacher MI4 || XFactory X6^2 | past - Xray T2 009
I got my SPX a couple of weeks ago and had two oppertunities to try some profiles and gearing. I started at profile #6 and FDR was around 3.9 with a Novak 17.5, temp around 145F.Car had more rip than my GTB could ever deliver. Next, I thought I'd try profile #8 and FDR at 3.6. Car had good speed but it didn't last long before it slowed down. Checked the motor temp and it was 210F after about 5 minutes. I smoked the Novak, then I switched to a Speedpassion 17.5, ran it at the same gearing and profile and again had good power at first but it really slowed down after about 3minutes so I pulled the car off the track and checked motor temp. it was 240 F. I guess I screwed up two motors now! I went back to the original profile#6 and FDR at 3.9 and the car had modest power but not the same rip it did originally. Did I ruin the ESC? I checked the temp of the SPX after every run and it was fine! Not sure what to do to bring the rip back from before? Any suggestions!
Thanks in advance
Thanks in advance
If your going up on the profiles, you need to drop your gearing down NOT up!!!
Hotbodies, Speedworld Raceway, Team Sorex USA, Gearchart.com, Team Chipotle...
"When I want the truth I go to the internet because that's the magical place where no one lies"...
Thanks in advance
the ESC is safe, don't worry..........
the reason why you fried the motors is that you went wrong way.......
Higher power profile demands shorter ratio (higher number)........so if you ran at profile 6 geared at 3.9 you should go down 1 or 2 teeth on the pinion to get the motor properly geared at profile 8......
for example.......with 9.5 motor it's fine geared at 6.5 at profile 6.......for profile 7 I must gear at 7.0
Salvadori Racing
www.salvadoriracing.com.br
I have tried last week-end with the latest Nosram 9.5, profile 6 with a gear ratio of 5.9, motor temp was around 70°c, good top speed and acceleration.
Im considering in getting an SPX Stock Spec or the New SXX?
I'll be running 13.5T & 10.5T most of them time but will never know later in the future in wanting to run mods?
Does the SXX have the same power profiles as the SPX on profiles 6,7 & 8?
So which do you guys reckon I should take?
the new SXX looks sweet but has not been released yet, except for TOP drivers who may certainly provide you some information on this one. Post your question in 416 Jilles Grosskamp thread, he is very helpful and is certainly using a SXX
the SPX stock has 8 prog profile and handle up to 5.5t motors if I remind correctly.
if you run mainly 13.5 and 10.5 motors, you can't be wrong with the SPX stock.
I have asked the same question on LRP's forum and emailed Nosram about the Pearl (Same as the SXX only Red ).
Thanks in advance
I think you've cooked the motors.
Remember, lowering the gear ratio means a higher number FDR, 5.0 is lower than 4.1 etc.
You should have gone down to FDR 4.1 or something if you went up the profiles, not the other way around.
For 13.5T & 10.5T deffo SPX. SXX won't have power profiles.
SPX will be still capable to run mod motor (well not those damn stupid fast motors such as 3.5T) but I run in mod 5.5T motor with lipo and it's still fast (6.5T as well).
Pavel Balint
From Adreas Myberg at LRP;
Hi Damian,
The SXX Competition #80900 nore the SXX TC-Spec #80950 won't feature any stock spec software or hardware like the SPX Stock Spec #80710.
/Andreas
There's your answer, if your running in the Stock classes, don't bother with the SXX, get the SPX (Or Nosram's equivalents )
Im thinking of buying an spx. I currently run a losi xcelorin speedo with a 13.5 duo. The losi has adjustable timing so i was wondering if i would see a difference running a spx. Also if i get a spx how should i set timing on motor and spx. My track is 100'-35'. Thanks!
Thanks in advance
nice one max i thought im the only one known for smoking motors see you on saturday!
Sponsored by:
REI | Coleman | Patagonia | The North Face | Camping World
http://video.about.com/camping/How-To-Build-a-Campfire.htm
Motto: A sniper who has a grassy knoll on lockdown.
